Old 01-27-2017, 11:06 AM   #1
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
Fan Speed Controller for inline HVAC booster
I have 2 blower fans (normally used to vent engine compartments on boats of fumes before starting engine) installed as inline HVAC airflow boosters. I know, I know... for all the HVAC people out there they will notice right away that this is a poor method of trying to boost airflow. Needless to say, my options were limited at the time and this was the best available method to increase airflow from the furnace to colder areas of our AS.
Name:	2017-01-27 13_04_27-Amazon.com _ Attwood Quiet Blower (White, 4-Inch) _ Boat Blowers _ Sports & .jpg
https://www.amazon.com/Attwood-Quiet...attwood+blower
I currently have a voltage regulator installed on each of these fans to allow for some control over the speed of each fan:
Name:	2017-01-27 12_59_17-Amazon.com_ DROK LM2596 Numerical Control Voltage Switching Regulator DC Buc.jpg
Unfortunately, they aren't rated to handle more than 3A and one of them has already failed due to the draw of the fan it's attached to. I am looking for a replacement.
I was wondering if anyone could recommend a voltage regulator or fan speed controller on Amazon.com that would service this purpose. Wondering if this one would suffice:
Name:	2017-01-27 13_02_03-Amazon.com_ Yeeco 9-60V PWM DC Motor Speed Controller Pulse Width Modulation.jpg
https://www.amazon.com/gp/product/B0...A2PMIWMSUTAYGS
trekerboy is offline   Reply With Quote
Old 01-27-2017, 11:57 PM   #2
Redwood , New York
I don't know how much current your in-line fans draw, but a 20A speed control should certainly be more than capable of handling the job. In your picture they look similar to computer "muffin" fan motors, and those typically draw less than an amp at full speed.
Just a note -- a PWM speed controller does not work by regulating voltage. PWM stands for "Pulse Width Modulation" the motor is always being supplied with the full 12 volts, but the feed is electronically pulsed. The longer the width of those pulses, the closer to full speed -- the shorter -- the slower. They are far superior to the old variable resistance controllers because they to not used wasteful resistance to control voltage.
Tom
motthediesel is offline   Reply With Quote
Old 01-28-2017, 06:41 AM   #3
timmaah's Avatar
1999 25' Safari
On , the road
The electronics crapped out on one of our expensive MaxxAir fans. I fixed it in 20 minutes with one of these. Cheap and works awesome.
Our Adventure.. http://www.watsonswander.com/
timmaah is offline   Reply With Quote
Old 01-28-2017, 07:44 AM   #4
dznf0g's Avatar
Oswego , Illinois
Here is my answer to the same problem:
http://www.airforums.com/forums/f427...ase-74624.html
Post #29 has a link to a good , electrically quiet, PWM controller. A Bit pricey, but I had to buy 2 or 3 different ones until I understood what it took for the noise to stop.
This part of the project was to provide more heat to the tanks. Another old thread covered duct additions and changes to provide more heat to the bedroom.
-Rich-
Old 02-01-2017, 09:28 AM   #5
trekerboy's Avatar
Thanks for the replies everyone!
So... can you use a PWM controller with ANY type of fan? Or does the fan have to support PWM?
Reason I ask is because the fans I have only have a positive and a negative wire coming from them. There's no 3rd wire like you'd see on a computer case fan or something that allows speed control...
Old 02-02-2017, 10:45 AM   #6
trekerboy's Avatar
For those following this thread, I went with this fan speed controller (really just an adjustable voltage regulator):
Name:	2017-02-02 12_43_05-Amazon.com_ DROK Numerical Control Voltage Regulator DC 6-40V to 0-32V 5A Bu.jpg
My last one burned out, but this one has heatsinks, so hoping that will make 'em last a little longer. Was hoping just for an analog thumb dial version, but couldn't find one of those for a reasonable price. We'll see how these turn out!
Old 02-14-2017, 10:17 AM   #7
trekerboy's Avatar
It works!
Added the voltage controller noted above and the setup works nicely. The unit itself is pretty over-kill for my application (would have just preferred a simple thumb-dial) but it works exactly how I needed it to.
Fan-tastic Vent 3000BT Fan 110 Volt, 3 Speed, Smoke Dome top, Built in Thermostat? stc cigar Airstream Classifieds 0 02-19-2014 08:45 AM
Help an HVAC noobie out... can I combine the furnace and A/C t-stat? Taylormade Furnaces, Heaters, Fireplaces & Air Conditioning 10 05-16-2012 02:13 PM
Generator--HVAC Question Tideair Generators & Solar Power 10 03-14-2012 09:24 PM
Airstream - Free Standing HVAC anglev Winter Living 8 12-04-2011 07:20 AM
2 speed wiper switch has no low speed rdm Mechanics Corner - Engines, Transmission & More... 6 01-09-2003 08:47 PM
