Old 08-09-2014, 04:00 PM   #1
rp709's Avatar
2015 30' Flying Cloud
Ventura , California
Lightbulb Factory inverter
The newer factory inverter installation uses a dedicated circuit for inverter power. The outlets have a blue label identifying them. Has anyone connected that circuit to shore power using a transfer switch?
rp709 is offline   Reply With Quote
Old 08-09-2014, 04:24 PM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Why would you do this? All the inverter outlets in the factory package are next to shore powered outlets. So what would you gain?
Bob Martel
WBCCI# 5766
Old 08-09-2014, 04:46 PM   #3
1974 Argosy 20
Kooskia , Idaho
More outlets, and not having to move plugs from line power to inverter power when you are not hooked up.
To the OP's original question, it could be done with a transfer switch, as you note. It is too bad that the transfer switch already built into the WFCO inverter is not activated and cannot be accessed without opening the unit up (removing rivets etc) and voiding the warrantee. I know, I looked on my 2014 FC 20'. It apparently was an option that Airstream opted out of when specifying the inverter. Even the power cord is in place to use it, but it is not hooked up internally.
Old 08-10-2014, 03:23 PM   #4
rp709's Avatar
Value
I guess 95k for a FC 30 doesn't leave enough room for profit and a transfer switch, not to mention a 3 way converter. The Airstream way requires you to unplug and re-plug the TV and DVD when using the inverter and doing the same when moving to hookups. I installed a WFCO transfer switch when I added an inverter to my Safari. My plan is to put a transfer switch linking shore power to the inverter circuit, and no unplugging of the TV's. Also coming will be a smart converter (and quiet water pump).
Old 08-10-2014, 06:00 PM   #5
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Why not just leave the televisions plugged into inverter outlets and run inverter even when on shore power? It's sort of the long way around but I don't think it would hurt anything or use excessive power.
2012 Dodge Durango Hemi/AWD
Old 08-10-2014, 09:27 PM   #6
lewster's Avatar
Naples, FL , Hood River, OR
Why not just buy a QUALITY inverter like the Magnum MMS1012 that already has in internal transfer switch, just like all if the other Magnum products ? It also gas a 4-stage automatic charging system........one of the best available.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 08-10-2014, 10:42 PM   #7
rp709's Avatar
Switch
Leaving the inverter on would be too simple and not nearly as fun as installing a transfer switch! However, I haven't listened to the factory 1,000 watt unit, but my 400 watt Xantrex inverter could be heard humming when things were really quiet. I have low tolerance for humming noises as well as noisy fans. It reflects casual engineering in my opinion. We'll see how it works next month.
Old 08-10-2014, 11:12 PM   #8
lewster's Avatar
'Casual engineering'? It reflects CHINESE engineering!
Magnums are engineered and built in the USA.
Old 08-10-2014, 11:44 PM   #9
2013 25' FB International
simi valley , California
If you have the factory inverter it has built in transfer switch it was one of the first things I hooked up it took only 1 hour skill level easy my inverter had a line cord already installed
Rick stream is offline   Reply With Quote
Old 08-11-2014, 12:24 AM   #10
1974 Argosy 20
Kooskia , Idaho
Unfortunately, the factory inverter even with power cord on mine does not have the internal transfer switch hooked up, even though it looks like it is all set up for that feature. A careful reading of the WFCO manual shows that the switch is an "option" and at least on mine, does not operate. I sure wish it did. I tried.
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 09:23 AM
About to buy new airstream (23D)with no factory 600W inverter... Wishing Boondocking 14 07-12-2013 11:54 AM
Factory WF 600T inverter died silverback Batteries, Univolts, Converters & Inverters 7 12-05-2008 05:16 PM
Alternatives to Factory Converter & Inverter shovelbum Batteries, Univolts, Converters & Inverters 17 04-04-2008 11:14 PM
Inverter sizing for factory convection/microwave oven? myoung Electrical - Systems, Generators, Batteries & Solar 11 10-03-2005 07:24 PM
