10-26-2014, 04:04 PM
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo
Extra male plug, what is it?
I have been living with this plug that is located on the port side bulkhead, forward of the side couch. The PO denies any knowledge of this and I've avoided plugging it into the electric to see what would happen. There appears to be a significant amt of length tucked into the wall. All ideas greatly appreciated.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
10-26-2014, 04:20 PM
2009 23' FB Flying Cloud
Canmore
, Alberta
Interesting. Heat tape on the freshwater tank?
10-26-2014, 04:27 PM
Mantua
, Ohio
Water heater? Jim
10-26-2014, 04:42 PM
1974 Argosy 20
Kooskia
, Idaho
Guess here, but Television or DVD player. My 2014 has TV and DVD plugs that can be plugged into either the regular or inverter circuits. Although I don't see anything but a regular outlet in your rig, others with an inverter may have had multiple places the TV could be plugged into.
10-26-2014, 06:06 PM
2005 30' Classic
Burlington
, Ontario
Strange - it doesn't look like something that would have been original. Is there no way to follow it to see where it leads? Could be some sort of additional signal amplifier?
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
10-26-2014, 06:09 PM
Overland Adventurer
2009 34' Panamerica
Telluride
One way to find out!
Post back later and update us!
Some of will loose sleep over these things...
10-26-2014, 06:47 PM
Biloxi
, Mississippi
Curious as to what you think that one way is.
MICHAEL
10-26-2014, 06:50 PM
Southwestern
, Ohio
Plug it in! Once upon a time known as the "60 cycle AC smoke test".
10-26-2014, 06:52 PM
Overland Adventurer
2009 34' Panamerica
Telluride
Yes plug that bad boy in....
It's going one of two ways!
10-26-2014, 07:00 PM
Remember, Safety Third
Catfish Corners
, Georgia
That was gonna be my suggestion as well. Plug it in and see if it "lets the smoke out of anything."
10-26-2014, 07:03 PM
Overland Adventurer
2009 34' Panamerica
Telluride
Come on, what's the worst thing that could happen? A leak in the shell? A rotten spot in the floor?
10-26-2014, 08:09 PM
2004 31' Classic
lubbock
Plug-it-in!
Plug-it-in!
Plug-it-in!
Plug-it-in!
10-26-2014, 08:16 PM
Overland Adventurer
2009 34' Panamerica
Telluride
Isn't that an air freshener jingle?
10-27-2014, 03:51 AM
2011 30' Classic
1993 32' Excella
Largo
We're attending a local AS rally this weekend in Dade City at Travelers Rest RV Resort so I'll put off the "plug in" remedy till this is over just in case something happens. Wouldn't it have been nice if the PO owned up to what the plug was for? Oh well...
Thanks for all the advice,
>>ron<<
10-27-2014, 04:21 AM
1993 34' Excella
York
, South Carolina
Keep pulling on it till it stops, you may be able to look inside with a flashlight, see what, if anything, it is connected to. The grommet in the wall doesn't appear to be large enough for the plug to pass through. The other end likely the same. The cord would need to be cut, inserted into the hole, then connected to something on the other side, requiring access to that back side.
Might be a factory install.
Any mention in the owners manual?
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Uncle John's Band
10-27-2014, 04:25 AM
Retired.
, At Large
That is the 120v lead and transformer to the old television. The transformer was hidden in the wall, and couldn't be removed. The television was replaced because it was analog only, and would not pick up digital tv signals.
10-27-2014, 04:42 AM
2014 25' Flying Cloud
Cuddebackville
, New York
Interesting that the one chanting "plug it in" is named "jump"....
2019 Ford Expedition Platinum
