Old 11-04-2008, 05:51 PM   #1
Vernal , Utah
External outlets needed
Hello. I have a 63 Overlander and am looking for 3 or more exterior 110 volt outlets with a water tight cover (screw on?) that will look nice? Any suggestions? Thanks.
GKP4570 is offline   Reply With Quote
Old 11-04-2008, 06:54 PM   #2
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
I guess it depends on where you plan to mount the boxes. Do you mean something like this? Or a "while in use" box like this?
I guess my thought would be to mount the outlets somewhere relatively convenient but not terribly obvious.
hampstead38 is offline   Reply With Quote
Old 11-04-2008, 07:15 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are looking for the OLD SCREW ON receptacles they have all but vanished.
I have even gone so far as to ask electricians working with older homes at the shore to be on the look out for old ones as they rewire homes. They were very common in shore homes before the war there were 2 on my front porch as a kid. Just forgot to remove them when I sold the house.
2004 Excursion 4x4
Old 11-04-2008, 07:27 PM   #4
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
there's also this:
Vintage Trailer Supply - Vintage travel trailer parts and supplies!
(kind of pricey, I'd want to hold one in my hands (look at it closely) if I was going to pop for one)
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 11-04-2008, 07:28 PM   #5
Vernal , Utah
round screw on
I was hoping to replace the three exposed single gang outlets with a screw on cover type. I want to keep the outside looking vintage.
Old 11-04-2008, 07:35 PM   #6
jpeterman's Avatar
1972 27' Overlander
Graham , North Carolina
we have used the screw on type plugs and recepticles that howie was talking about in the fire service for fans and other plug in equipment that we needed to be water tite.
check with you local fire equipment dealer or call your fire dept. and see if they can get them
"AIR 17559"
wear it out, don't rust it out
Jerry
jpeterman is offline   Reply With Quote
Old 11-04-2008, 07:54 PM   #7
1989 34' Limited
toronto , ontario
Dont forget that all exterior recepticals require GFI recepticals at $10 to $15 each that is if your unit isnt GFI protected already.
letsgo123 is offline   Reply With Quote
Old 11-04-2008, 08:01 PM   #8
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
letsgo123 has a good point. If these outlets are for occasional use & not heavy duty, all 3 can be protected by a single 20 amp GFCI breaker.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
12-volt outlets Steve & Susan Lights - Interior & Exterior 1 09-17-2008 06:21 AM
hooray! the outlets work! bookman Electrical - Systems, Generators, Batteries & Solar 2 08-07-2008 08:29 PM
110V outlets cookeville34 Electrical - Systems, Generators, Batteries & Solar 2 09-17-2006 07:15 AM
Missing Electrical Outlets gklott 2001 - 2005 Classic 2 04-21-2004 01:03 PM
warm outlets markus Electrical - Systems, Generators, Batteries & Solar 5 11-29-2003 04:06 PM
