Old 02-04-2015, 07:37 PM   #1
2015 27' Flying Cloud
maple grove , Minnesota
external charger effect on electronics
When dry camping I use a battery charger plugged in to my generator. Since battery chargers can produce voltages of 14+, I wonder if my trailers electronic stuff could be harmed or does the battery smooth out the high voltage.
thebreezeman is offline   Reply With Quote
Old 02-04-2015, 08:05 PM   #2
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
14-14.5 volts or so for an hour or two is okay and will not harm your electronics. A depleted battery is supposed to go to that charge level for 1-2 hours while being recharged. This is called the absorption stage. After that the charger should maintain the batteries at about 13.2 volts (the float stage) until depleted again. Your charger should be making these adjustments automatically.
You need not worry unless your batteries are staying at 14v or above for extended periods in which case both your batteries and electronics may be jeopardized. If this is happening, disconnect the charger intermittently until you determine the cause such as malfunctioning charger or converter.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 02-05-2015, 07:37 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
An assumption....you are using a stand alone charger 'cuz you don't want to use the on-board single stage converter/charger and risk burning up your batteries.
Most of the quality stand alone chargers will not over-charge or damage any on board electronics.
Converter/Charger vs. Inverter/Charger moosetags Batteries, Univolts, Converters & Inverters 5 11-22-2013 10:21 PM
External charger and battery ? Rousseau Batteries, Univolts, Converters & Inverters 5 09-01-2011 12:55 AM
The effect of using the blue liquid black water treatment on septic fields wacnstac Waste Systems, Tanks & Totes 6 06-01-2006 09:21 PM
solar effect? norbert Our Community 2 06-21-2005 09:22 AM
Adding charger where no charger has gone before Jabba Electrical - Systems, Generators, Batteries & Solar 4 03-08-2003 09:39 AM
