Old 12-11-2019, 11:31 AM   #1
2004 25' Classic
Hanahan , South Carolina
Exposed wire behind stove
I see an exposed wire behind my stove without tape or wire nuts?
What do you think it was for and what are your recommendations?
Picture is from under my sink looking towards the stove and front of the trailer curb side.
Planenut is offline   Reply With Quote
Old 12-11-2019, 12:33 PM   #2
newsgauger's Avatar
1976 Argosy 28
Milton , Ontario
First, have you owned your Classic since new (2004/5)?
If not, I would try to pull the wires forward, so that you can test them for voltage/ground. Once determined if either lead is connected to +/-, I would cap them all.
If you have, then these might be extra wires pulled in for accessories that you did not order. Go back to fuse panel to see if there are wires without fuses installed.
In either case, IMHO, these should be capped and taped.
Good luck in your investigation.
Chris
newsgauger is offline   Reply With Quote
Old 12-11-2019, 02:36 PM   #3
2004 25' Classic
I Purchased it about 4 weeks ago. Working through getting it in shape for the spring.
Chris
Old 12-11-2019, 02:43 PM   #4
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I have a 2013 25FB: different year, different model. But on mine, the propane oven is standard and a microwave is optional. The microwave, if ordered, replaces the propane oven. And Airstream designates a dedicated circuit breaker in the breaker box, and runs a 110V cable to the space under the oven, even when the trailer is built with the propane oven.
You trailer might be the same way.
SSquared is offline   Reply With Quote
Old 12-11-2019, 06:31 PM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I’d bet on solar prewire for charge controller. Yellow and green are plus and minus for panels (on my trailer the other end is in the outside fridge compartment) and red and black are near the batteries (on my trailer coiled up behind the sofa).
Neither other end is connected to anything.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 12-11-2019, 06:45 PM   #6
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
+1. Looks like a prewire to me. For peace of mind, I would expose enough of each conductor and use a crimp connector to cap it off. Wire nuts will eventually work themselves loose. If you have any floating wires in your 120v ac panel, you could do a simple continuity test to see if indeed those wires go to the panel. If they do, make a note for future electrical needs in that area.
mayco is offline   Reply With Quote
Old 12-11-2019, 07:54 PM   #7
2004 25' Classic
That would be cool if it was pre wired for solar.
I need more time to Check out all these things. Hopefully around the Christmas holidays.
On another note, are any of my 110 outlets powered by the battery and an inverter? 2004 classic 25Ē.
Old 12-12-2019, 11:37 AM   #8
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
I would cap it off until you figure out what to do with it ... just don't like exposed wires and metal trailer bodies ��
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 12-12-2019, 09:04 PM   #9
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Are all your lights working in the trailer including storage areas? The reason I ask is because 6 of my interior and storage lights went out in the trailer. I traced the circuit to a wardrobe cabinet next to the sink. Underneath I found a red wire that didn't go to anything and was coated in green verdigris. I couldn't seem to find the other end of the wire connection. I had already tested and found it to be a 12 volt DC source. Two feet of wire was never found between there and the nearest connection in the wardrobe. I spliced in a two foot piece of wire and bingo, all lights came back on. I'm not saying the same thing happened in your case but if a 12 volt DC source then I'd be looking for where it goes.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 12-13-2019, 06:51 AM   #10
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
edited:
The answer is on page G34 in your owners manual
https://www.airstream.com/wp-content...manual-106.pdf
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 12-13-2019, 09:38 AM   #11
2004 25' Classic
I had seen that in the manual however, Are they on both sides of the galley or split up?
Mine are behind the stove on the curb side and the manual talks about the refrigerator that is on the road side..
Originally Posted by A W Warn View Post
edited:
Old 12-13-2019, 10:41 AM   #12
edited:
Or you could see my post, #5 above.
Al
S/OS #004
valve behind heater? water pipes behind refrigerator? daa1111 Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 4 05-22-2018 05:45 AM
1988 Running Light Exposed Wire vhariable Lights - Interior & Exterior 2 06-25-2011 09:56 PM
Propane Gas lines exposed - 1968? Randy Gates 1965 - 1969 Globetrotter 5 03-06-2011 12:25 PM
Exposed battery terminals nickcrowhurst Batteries, Univolts, Converters & Inverters 7 12-20-2008 02:51 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 12:09 PM
