Old 09-06-2017, 05:39 PM   #1
1979 31' Excella 500
Cheyenne , Wyoming
Excella 1979: how do I change the fuse?
I can't seem to pull them out to change there are screws but I assume they are for the wires to the fuse. I'm a newbie at this. I have various cabin lights that are not working and I suspect it is the fuse. I have the manual for what fuse is to what. I also need to repair a light but I am unable to pull out the the grey fuse that would stop the electricity flow to the cabin lights so I can repair the light toggle. So how do I pull out the fuse and change it. It's the original fuse box. with glass fuse tubes.
sjhexcella is offline   Reply With Quote
Old 09-06-2017, 08:35 PM   #2
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
Google 'glass fuse puller'
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 09-06-2017, 08:36 PM   #3
1974 Argosy 28
Images: 37
https://www.walmart.com/ip/BikeMaste...&wl13=&veh=sem
Old 09-06-2017, 11:48 PM   #4
Cheyenne , Wyoming
Thank you!
Old 09-07-2017, 10:47 PM   #5
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Go to an auto parts store and get a light type tester probe. Ground the clamp and touch the hot side of the fuzes from the supply sides. When you touch the supply side the tester should lite up. If i doesn't, you have an open feed. In that case DC power is not getting to the bus. On the feed side to the circuits if one fuze does not light up you have a blown fuze. Sometime fuzes can be bad, but the open is not visible.
guskmg
Old 09-20-2017, 01:14 PM   #6
Cheyenne , Wyoming
thank you, very helpful.
Excella vs Excella II vs Excella 500 vs Excella 1000 ElCamino Man Trailer Values 5 03-21-2013 03:32 PM
1979 Airstream Argosy Astrobus :: 1979 Airstream Astro Bus shaunamadre Airstream Registry Discussions 1 08-14-2012 12:56 AM
NT-30MA to NT-30SP furnace change '79 Excella 500 SafeHarbor 1978- 1979 Excella 500 17 08-22-2007 09:36 AM
Ideas to change the floor plan / interieur of a 1979 Safari Hans General Interior Topics 0 12-23-2002 11:58 AM
