Old 02-13-2015, 04:51 PM   #1
AdvantageAir's Avatar
2014 25' Flying Cloud
Grosse Pointe Farms , Michigan
Everything is dead!
Help! We are packing up our 2015 Bunk to head to Florida from Michigan. The plan is to leave at 6AM tomorrow. 20 mins ago both the 110 and 12v systems shut down. Nothing works at all. I have tried to reset the GFI and nothing. Does anyone have any idea about what may be going on? We have only had the trailer for a two weeks and I have no clue about anything electrical.....
AdvantageAir is offline   Reply With Quote
Old 02-13-2015, 05:18 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
It sounds like it has to be a breaker or breakers of some sort. Also check the USE/STORE switch and make sure that the red light is on.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 02-13-2015, 05:31 PM   #3
Never mind. I'm an idiot.
Old 02-13-2015, 05:32 PM   #4
Thanks for the reply. Five minutes with a cool head and some light reading and I got it...
Old 02-13-2015, 05:42 PM   #5
Wayne&Sam's Avatar
Cuddebackville , New York
Images: 21
That was going to be my suggestion.
really- please take this as a joke.
2012 Dodge Durango Hemi/AWD
Old 02-13-2015, 05:44 PM   #6
2005 30' Classic
Burlington , Ontario
Glad you got it sorted, big relief I am sure!
We too are leaving early tomorrow for Florida, Who knows,may see you on the road!
(we are leaving from the Toronto area - dan cold here today and I imagine the same for you!
Brian.
Old 02-13-2015, 05:49 PM   #7
moosetags's Avatar
Please tell us.
Brian
Old 02-14-2015, 03:57 AM   #8
I had a 30amp outlet installed in our garage late last summer for our 27'. The new trailer is 50amp so I used a cheap step-up that I got from a neighbor who was moving. The 30 to 50 step-up must be bad. It was causing the polarity to reverse and nothing in the trailer would work. I changed to the step-up that came with the trailer and all is well.
Old 02-14-2015, 05:29 AM   #9
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
It's so awesome when it's an easy fix! Hope y'all have a great trip!
-Red, keeping it simple...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 02-15-2015, 05:14 PM   #10
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Exclamation Center Power Out - Cold Tonight
Interesting to see this thread start. We just pulled into camp, about 40 degrees in South Carolina. Everything was working as normal, then SNAP and the center of the trailer is dead = no over sink light, no over stove light, no over dinette light, no furnace, no water heater, no pump. Shore power is working. 120v lights which require shore power are on. Front of trailer on - back bedroom on.
All breakers have been switched off and on again - no joy.
Water heater connections have been pulled, cleaned and replugged - no joy.
Eating supper now, but will be mighty cold in the morning. Help???
Linda Heuer. Past President Shen. Valley Unit
Greg Heuer, 1st VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 02-15-2015, 05:31 PM   #11
1994 34' Excella
Warren , Manitoba
Do you hear your converter humming? If "yes", check your 12 volt panel. There are resets on the panel. It is behind the front couch on my '94. If converter is not humming, try plugging in on the other side of the outlet. If all alse fails, get to a Walmart and get a 120V heater to keep you warm till morning. Good luck!! Chris
WBCCI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 02-16-2015, 05:48 AM   #12
2011 31' Classic
Images: 8
That was IT, Chris. Thanks so much. I've never poked around in the 12 V panel behind the couch. One quick press with the tip of a screwdriver and all is well (and warm).
This Forum is AMAZING.
Old 02-16-2015, 07:23 AM   #13
1994 34' Excella
Warren , Manitoba
Glad things worked out. I would check to see if there was a reason the 12v breaker poped. Keep and eye on things!! Have a good trip to the warm country. It's snowing here and calling for 18 below tomorrow. EH! Chris
WBCCI #7394
dead dead bolt Jim from SB Doors & Locks 3 09-09-2012 11:32 AM
Dead ...really dead Melody Ranch Batteries, Univolts, Converters & Inverters 17 06-13-2007 12:23 AM
for the pet who has everything - except an Airstream bake315 The Pet Forum 1 06-06-2005 06:11 PM
Everything in the 1976 Caravanner works! BabyStreamer General Interior Topics 2 01-19-2004 07:53 AM
New to everything!!! k9s2go Our Community 9 09-10-2002 08:24 PM
