Old 01-02-2015, 04:24 PM   #1
Ganado
Ganado's Avatar
Peoria , Arizona
Essentials for Electrical Kit on the road
DISCLAIMER: im have no mechanical aptitude. and I am wondering what to are some essential tools for the electrical kit that other people carry when they travel
Mutltimeter
fuses
What else?
Thanks for your help
Ganado is offline   Reply With Quote
Old 01-02-2015, 06:55 PM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Add in a pocket knife and a small roll of electrical tape.
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 01-02-2015, 06:58 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Mutltimeter
fuses
What else?
If you have no mechanical aptitude, the most essential tool is a print or e-book version of a good manual on RV electrical systems. The key to repairing electrical problems is twofold: (1) knowing how it's not working; (2) knowing why it's not working. If you can answer those two questions, you will know what materials, tools, and skills you'll need to fix the problem. The manual can help with answering those questions.
As a bonus, most good manuals on RV electrical systems will have a list somewhere (usually an appendix) of the most commonly needed electrical tools.
Cats and ultraleather Airstream upholstery don't mix!
Old 01-02-2015, 09:11 PM   #4
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Electrical tester for 120 volt outlets (the kind that has a few lights on it and is the size of the plug on the end of an extension cord)
needle nose pliers
screwdrivers for tightening wire terminals and removing/replacing 110 volt outlets
wire cutter
wire stripper (or pocket knife)
Small spool of 12 gauge stranded insulated wire from an auto parts store
Diagram of the connections on your trailer's umbilical cord (ignore that if you have a moho)
A few wire nuts of different sizes
SSquared is offline   Reply With Quote
Old 01-02-2015, 10:04 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
in addition to the above:
replacement light bulbs of each kind
30 amp drop cord in case pedestal is to far away
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
A W Warn is online now   Reply With Quote
Old 01-02-2015, 11:04 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Test light, test light, test light.
Invaluable for troubleshooting twelve volt circuits.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 01-03-2015, 12:37 AM   #7
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Small soldering Iron and a few sizes of solder and some solder paste. Once in a great while it comes useful, or if you get fancy with some decoration EL wire lighting. You'll probably have a pretty good idea how to use it safely by the time you want to use one.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 01-03-2015, 01:29 AM   #8
Ganado
Ganado's Avatar
Peoria , Arizona
ty appreciate all the contribution
Old 01-03-2015, 01:45 AM   #9
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi,
Test light.
Wire cutters.
Crimp connectors.
Crimping tool.
Roll of electrical tape.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-03-2015, 06:21 PM   #10
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
My kit has:
Volt meter
12v test light (heavy duty with long sharp probe and coiled ground lead with strong alligator clip)
Electrical tape (always 3 wraps around repair)
Crimper/Stripper with plier tip
An assortment of various size and types of connectors
A good utility knife
Fuses
An Electrical schematic of my AS
Heat shrink tubing if you prefer that to tape
book of matches or a butane lighter
NavyCorpsman is offline   Reply With Quote
Old 01-03-2015, 08:18 PM   #11
1971 31' Sovereign
pickering , Ontario
electrics
I always had a continuity tester in my tool kit;
paulwhite is offline   Reply With Quote
Old 01-03-2015, 08:19 PM   #12
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
One spare part that I carry is a 30 amp repair plug for the shore power cord to the pedestal. If you're not comfortable making the repair on a burned up plug, at least you'll have the part and finding a helper in camp is very likely. Just check the polarity.
I also carry a collection of electrical doohickeys and a recent addition is a smart crimping tool. Uses standard insulated crimp terminals but it crimps to a stop and then releases. Makes nice crimps.
As a part of learning my AS I picked up a 120 VAC meter that plugs in to an outlet and a 12 VDC meter that plugs into a 12 VDC cigarette outlet. Both just help monitor actual electrical system voltage.
Yes, I do have a surge protector, much debate, I made my choice.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 01-03-2015, 08:39 PM   #13
Wayward's Avatar
Cary , North Carolina
An AC voltage detector like this one is essential. It detects AC voltage by simply holding it near the wire, receptacle or switch. NO need to mess with meter leads.
I always verify it is working before using it by holding to a known live receptacle.
Very safe tester.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 01-04-2015, 02:53 PM   #14
2007 22' International CCD
One of these has saved my butt multiple times. Check twice on a known hot line to verify its working, then test the circuit you thought you turned off. All the other wires in the box as well. Homes have multiple circuits in one box sometimes. Don't ask me how I know this...
Old 01-04-2015, 03:27 PM   #15
Lock-out/tag-out is a basic electrical safety principle. You check to make sure the circuits are turned off before you work on them. Then you also make sure no one else can turn them back on while you're working on them.
Since RVs aren't really set up for lock-out, you have to rely on tag-out. A big red tag that says something like "Under Repair - Do NOT turn on!" at the switch or breaker or both. The tag stays in place until you personally remove it.
Old 01-04-2015, 04:08 PM   #16
mandolindave's Avatar
Do yourself a favor
#1 Get a volt meter…BUT DONT do what I did.
I got a really good Fluke (brand ) it's a pro tool, love it. But it's for ELECTRICIANS….and it registers in one volt increments, because electricians don't care about tenths of a volt. I need to know my Batt range from 12.0 to 12.8 volts resting, AND 13.8 charging
#2 Get yourself a small plug in AC polarity checker 3 or 4 bucks ? They tell at a glance, which AC wire is broken, which wires are touching, and if the wires are switched. I have had switched polarity at campgrounds, or switched polarity of extension cables. When you touched my camper while barefooted, you got a shock. Luckily, I have an old trailer with a warning light on the outside of the trailer
#3 A cigarette style plug in DC volt meter. You can tell at a glance if charger is on and what your batt voltage is. ( you still need a portable volt meter for checking stuff)
#4 tools- philips and flat head screwdrivers, wire stripper/cutter, knife, electrical tape
mandolindave is offline   Reply With Quote
Transmission Cooler Essentials mstephens Tow Vehicles 41 02-03-2015 06:48 PM
Airstream's List of Essentials. Are they? clicknathan Full-Timing 34 09-13-2013 09:06 AM
LED technology essentials Excellin Lights - Interior & Exterior 10 01-30-2012 11:25 AM
Top 10 Essentials for Road Trip boutdoors On The Road... 41 03-10-2010 09:03 AM
