Old 08-21-2004, 08:18 PM   #1
1 Rivet Short
krowsea's Avatar
Smile Entry point for phone / other cables?
Since I'll be living in my A/S fulltime in the near future, I've got phone service being hooked up and eventually some type of internet service. Where (how) do I bring the cables into the trailer itself, without affecting the integrity of the unit, and not creating any leaks? Is there a place for cable entry on the trailer, or do I need to make my own?
Thanks!
John-Boy
Sarchasm (n): The gulf between the author of sarcastic wit and the person who doesn't get it.
1975 31' Sovereign
2004 Dodge Ram 2500 'Laramie', HEMI
krowsea is offline   Reply With Quote
Old 08-21-2004, 10:19 PM   #2
JohnG's Avatar
There a few mentions on the forums, but I think you have to be creative on where it will best suit you to have it enter your trailer.
Just adding my 2˘ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 08-21-2004, 11:33 PM   #3
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
I came in through the bottom of my trailer. When I redid the plumbing there was a hole left over where the relief valve was.
I also notice a small circle about 4" where there is a screen that goes right through. Don't know what its for but it could work as well.
Look under your trailer and see whats already there.
Good luck!
-Tim
theVAP - Airstream Podcast
Old 08-22-2004, 04:51 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Mine goes in thru the fridge compartment vent. The one on the underside. We installed a phone jack in the fridge compartment then will be running the cables behind the credenza to a jack in the stero compartment or close to it. All you do to hook up the cable is open the fridge compartment and feed the wire thru the screen in the floor. No new holes necessary.
Tim, would that small round screened area happen to be the bathroom vent?
Aaron
WBCCI #XXXX AIR #2495
Old 08-22-2004, 05:40 AM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
john boy
my excella has a cable and phone jack factory installed in the electric cord bay.
you could do the same with some inexpensive parts from radio shack. keep in mind that anywhere is good to install the entrance for these items, -but- if you keep them on the streetside rear of the trailer your cords will not need to be so long.
most camprounds or parks i have visited with cable and phone hook ups usually have them within a couple of feet of the electrical hook up.
john
you call them ferrets, i call them weasels.
Old 08-22-2004, 11:20 PM   #6
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Aaron
Don't think so. Its under the street side twin bed near the water heater.... Don't know what it's for.
Here's a picture of my phone and cable tv hookup.
-Tim
Old 08-23-2004, 03:11 AM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Tim,
Bet that is what it is. That is the aproximate location of the outlet for our little bathroom fan.
Aaron
Old 08-23-2004, 06:18 AM   #8
WayWard Wind's Avatar
2004 25' Safari
I believe that little round hole is meant to be a combustion fresh air inlet , most likely for your water heater gas burner.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 08-23-2004, 10:17 AM   #9
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Learn something new everyday.
Thanks Guys!
-Tim
Where to get keyless entry code? 0557 Our Community 23 10-08-2017 10:42 PM
Keyless entry grogan Doors & Locks 2 04-20-2004 12:16 PM
Hole at the Jack lift point odfarley Jacks, Stabilizers, Lifting and Leveling 4 12-26-2003 12:30 PM
