Old 01-14-2014, 06:41 PM   #1
Libo's Avatar
2010 31' Classic
Crestview , Florida
Emergency help! No trailer lights, can't drive at night.
When we hook up our truck to the trailer we keep burning out the fuse that powers the trailer lights. We still have brakes and turn signals but not the lights.
Has anyone had this problem?
Has anyone ever remove lights from a 2010 Classic? There are no screws.
Could it be because we were camping in very wet weather?
Lia
2010 Classic 31 Custom
2013 Silver Toyota Tundra Double Cab 5.7L
Former 2007 Safari 28 2008 Toyota Tundra
Libo is offline   Reply With Quote
Old 01-14-2014, 06:45 PM   #2
AlaskaSafari
AlaskaSafari's Avatar
1997 25' Safari
Fairbanks , Alaska
Send a message via MSN to AlaskaSafari
I actually had the same problem getting ready to leave for this trip... it turned out my alternator was going out. Hopefully your issue is an easier, less expensive fix.
2007 Tundra Crewmax - 1997 25' Safari
AlumiGypsy Adventures Blog | @TheSpouses on Twitter | AKAV8ER on Instagram
You must live in the present, launch yourself on every wave, find your eternity in each moment... ~ Thoreau
AlaskaSafari is offline   Reply With Quote
Old 01-14-2014, 06:55 PM   #3
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Has this trailer/truck combo worked in the past?
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 01-14-2014, 07:04 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Wet weather you mentioned triggered this thought…
Could be a problem with the umbilical cable between trailer and tow vehicle. If so, then water entering the plug could cause a short. Coating the face of the plug with dielectric grease. The contact surfaces fit tightly enough that grease will be scraped off the contacts as you plug in, allowing good contact, but the grease will fill all of the cracks and crevices where water might enter.
Cats and ultraleather Airstream upholstery don't mix!
Old 01-14-2014, 07:04 PM   #5
Libo's Avatar
2010 31' Classic
Crestview , Florida
It worked fine before but somehow after a weekend of rain it happened.
Lia
Old 01-14-2014, 07:24 PM   #6
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I believe you are on the right track to getting at those running lights. I tried to find information on the running light assembly via airstream.com. I only found that they are LED sealed on 2010 Classics. Water in one of them may explain the short and fuse blowing. If the fuses are separated by front or amber/red, etc you may be able to more easily pinpoint it. The only other thing I can think of would be the contacts in the plug shorting out.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 01-14-2014, 07:27 PM   #7
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Could be water in the umbilical connecter, or water in one of the clearance/tail lights. It could even be the license plate light. If you can't track it down yourself, you're going to have to take it to an RV or trailer repair shop, and let them fix it.
