Old 07-04-2006, 11:24 AM   #1
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
ELECTRICIANS (or others knowledgeable) please help.
These are photos of the MARINCO Easy Lock power INLET used on current AIRSTREAMS.
We will install the same device on my 1976 Argosy.
The Marinco cordset , which you run from here to city or park power, is rated 30A 125v 2 pole, 3 wire.
My question is this:
What type wire should I run from the back of the device, thought the trailer, and up to the Main Breaker?
(The wiring will run through the belly pan and up through a closet to the Main.)
Same wire as the cordset? What gauge?
Somebody suggested #8 Cab Tire, 4 wire. Too much or correct?
Thanks for helping.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 07-04-2006, 11:40 AM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
three conductor 10 gauge type SO or equivilent would work well. very similar to the cord set.
don't forget a strain relief clamp where it enters the breaker box.
john
you call them ferrets, i call them weasels.
Old 07-04-2006, 02:53 PM   #3
1976 Argosy 24
Thanks John.
The suggestion for #8 cab tire, 4 wire came from an electrician friend who hasnít seen the trailer.
Iím guessing that is overkill. Am I right?
Could there be any advantage to it?
Sergei
Old 07-04-2006, 03:01 PM   #4
Originally Posted by SmokelessJoe
... from an electrician friend who hasn’t seen the trailer?
You consulted a good electrician. He did not see how far your extenstion cord would need to be, and recommended the safest thing for your Airstream. He might go with John if he/she thinks the distance is not too far.
BTW, my extension cord is 8 gauge.
joatmon is offline   Reply With Quote
Old 07-04-2006, 03:03 PM   #5
Originally Posted by john hd
three conductor 10 gauge ...
Home improvement stores sell it as "two conductor with ground"
Old 07-04-2006, 03:06 PM   #6
.. 4 wire came from an electrician friend who hasnít seen the trailer.
Iím guessing that is overkill. Am I right?...
4 wire is a good idea for future expansion, but only two conductors plus ground will be used for your current Airstream.
Old 07-04-2006, 03:22 PM   #7
1976 Argosy 24
Joatmon:
Thanks for all the information.
Things electrical baffle me and Iím getting confused again.
From the laymanís perspective, if the 30A cords MARINCO sells to fit their 30A inlets are 10 gauge (they are, apparently) what then would be the advantage of going #8 from the inlet box to the Main Breaker?
You are suggesting that John meant to write 2 CONDUCTOR, 3 wire, #10; not 3 CONDUCTOR, right?
Thanks again for the help.
Sergei
Old 07-04-2006, 03:37 PM   #8
Voltage drop
... what then would be the advantage of going #8 from the inlet box to the Main Breaker?
If an extension cord is too long, the electricity will suffer a voltage drop. This voltage drop could hurt your air conditioner if not accounted for. You have not posted the distance your Airstream is from shore power, so I can not comment on the right wire gauge. Your electrician friend probably has a similar sentiment. Post distances, and you may get better answers.
John is a Lineman, and knows what he talking about. Although he is a better reference than me (he does this stuff for a living), I stand behind my wording of "Two conductors plus ground".
Old 07-04-2006, 04:25 PM   #9
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
No disagreement on the wire. Never hurts to go heavier but I can't see that you need it. The big question is what sort of insulation. I assume you're going to run stranded wire and not solid? Extra insulation is I think a prudent measure in this application. I think your choices are going to be 300V and 600V and I'd go with the 600V. For extra protection and just to make life easier you might want to go with a "cord set" type wire where there's insulation and some additional mechanical strenght containing the wire bundle. The reason for the extra insulation is the movement it's going to see via flex and vibration. Chances are you'd be doing this more as a favor for the next owner but your piece of mind over the next few decades is worth something.
bhayden is offline   Reply With Quote
Old 07-04-2006, 04:50 PM   #10
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
that would be correct!
phase neutral ground... 3 wires 2 conductors and a ground.
john
Old 07-04-2006, 06:19 PM   #11
lewster's Avatar
Naples, FL , Hood River, OR
john
Sergei,
I would go with a marine grade cable. The stranding is finer, providing more surface area for the electrons to fow and it is softer and easier to work with than the standard household wire that you get at the big box stores. I agree that 8 guage is overkill and not necessary. If you plan to run an outdoor cord longer than 50', I would consider going to 8 guage for that cord to deal with the voltage drop. I have tables to calculate the drop for different wires and I can look it up if you like. Let me know.
Old 07-04-2006, 07:54 PM   #12
1976 Argosy 24
Mission accomplished
Thanks to everyone for your help with this. Combining your advice, Iíve been able to see what I should do.
Most of you understood that I was talking about REWIRING my trailer, not an extension cord. I plan to buy a MARINCO cordset to fit the new inlet.
Tomorrow Iím going to buy #10 Cab Tire, 3 wire. Iím wondering now whether ďcab tireĒ might be Canadian usage for what you are calling 600V or SO.
Itís a heavy duty, flexible, rubber covered, indoor-outdoor, waterproof kind of wire, something like welderís cable.
I should have you all know that Iím only running the wiring through out the trailer. I donít want to waste an electricianís time with that and I want poking through the aluminum shell done my way.
In the end, I will have a Master Electrician come by to connect the outlets and hook up the panel.
Many of the interior panels have been removed so he/she will be able to see the runs.
Thanks again to everyone. Mission accomplished in one day.
(I wish the wiring would go as fast).
Sergei
Old 07-04-2006, 10:09 PM   #13
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
that is perfect!
john
Old 07-04-2006, 11:23 PM   #14
bhayden's Avatar
1978 24' Argosy 24
Welding Cable
Welder's cable is very good stuff. You may want to check out a welding supply outfit. Likely as good or better price than a hardware store and you'll get top quality stuff like Carol/Belden/etc. Welding cable is fine stranded for extra flexibilty and the insulation is designed to be tough and impervious to all manner of solvents.
Help! Resistor on fan switch Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 22 12-20-2003 08:01 AM
Safe from Lightning in an Airstream? maggieairstream Our Community 21 07-22-2003 04:18 PM
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 07:14 PM
