Old 04-01-2007, 05:14 PM   #29
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
Why the 10 foot MAXIMUM?
This is the wiring bundle for the trailer and the place were I plan to install the new 6 position (plus Main) AC distribution panel by Blue Sea
The panel is 4.5” x 10.5”. Since it is meant to be installed in a cut out, which I can’t do, I will have a 3” deep surface-mount box built for it.
Blue Sea uses ring connectors so I will ask the electrician to use the same in making connections. I have noted Bernie’s advice about using a good crimper.
The bright yellow cable is flexible strand 10 ga. and is the Main feed.
The other circuits are all the solid copper type, 12 ga.
The Blue Sea panel is beautiful, a work of art.
But it came with two surprises.
In the Blue Sea catalog there are diagrams indicating the MINIMUN DISTANCE from the Power Inlet to the Main Breaker is 10 feet.
The wiring diagram 100% contradicts this. It plainly says, “if the shore power inlet is more than 10 feet, additional fuses or circuit breakers must be installed within 10 feet of the shore power inlet”.
So obviously they meant MAXIMUM distance.
What is the reason for this?
Second surprise: Blue Sea NOWHERE mentions 12v supply in their catalog or literature.
Yet the two small runs of yellow and red wires are labeled “connect to 12v (yellow is negative). These appear to go to circuit boards that back-light the labels on the panel.
I could have neatly supplied 12 volts to this area when we had the wall panels off.
Now we will have to figure out how to do it after the fact.
Anyone have an idea of what the 10-foot requirement is all about?
Sergei
ID:	34979   Click image for larger version
SmokelessJoe is offline   Reply With Quote
Old 04-01-2007, 11:25 PM   #30
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
I'll take a guess on the 10' requirement. If the run is longer than that and there's a short the wire might become the fuse
Bummer about not knowing about the 12V. Makes sense. On a boat (and a trailer) you've hopefully always got 12V from the battery. So hooking up the lights to 12V means you can see/find the switches when the 110VAC isn't hooked up.
If you're going to light the switchs somehow off the 110 the easiest way might be to see if the bulbs can just be switched out? Otherwise you could get a "wall wart" type power supply to supply the 12VDC. Goodwill or some such thrift store always has tons of these around from various electronics. They should all have the output voltage and current marked.
-Bernie
bhayden is offline   Reply With Quote
Old 04-02-2007, 07:54 AM   #31
1976 Argosy 24
Bernie, thanks.
There are no “bulbs” to screw out. The circuit board seems to have little blue/green “nodules” formed into it’s plastic covering. I’m guessing these glow and backlight the signs.
I can run positive and negative wires from where the battery will be on the other side of the trailer but the holding tanks are right in that area and it may be impossible or difficult.
I could have provided the wires easily if the manufacture had published the requirement for 12v.
Like you, I’ve also thought of adding a small transformer to the side of the panel to supply the 12v.
Blue Sea is out west in Bellingham, Washington. I’ll call them after they open.
Sergei
Old 04-02-2007, 09:05 AM   #32
bhayden's Avatar
1978 24' Argosy 24
Originally Posted by SmokelessJoe
Bernie, thanks.
Sergei
Ah, good old B'ham; about an hour north of me. Giving them a call would be a great idea. Sounds like LEDs in the circuit board. Find out if the lights are a separate circuit from everything else, how much current they take and the voltage range they can accept. One thing you might consider if you end up running a decent size pair of wires from the battery is adding a 12V recepticle to the box. Never know when you might want to plug in a cell phone charger or what ever. I'm sure you have them scattered around other places but sounds like there's not 12V near by and the electrical center would be a grand place to have it. Speaking of which I'm surpised there's no monitor there for the battery condition? A really simple volt meter would be nice.
One other thing on the 10' requirement. If I'm right about the reasoning for the length then length is dependent on wire size. So if you're running heavier wire you can run longer, smaller wire (hopefully not) would have to be shorter.
-Bernie
Old 04-02-2007, 09:41 AM   #33
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
size of unit?
Sergei - what's the size of the unit itself? Those wires look like an awfully small size to be taking 120 volts? The distribution center looks more like a 12v one... although I see that it is clearly marked 120 volts on the faceplate. Is there enough room in there to get your wires in?
I'd also ask when you call what is the cooling size that you need around the unit.... put into a wall cavity, I'd suspect it has plenty of cooling room... assuming not insulated. Enclosed (which I assume you will be doing), I think you want some air circulation?..... I did stay in a Holiday Express... but I'm no electrician
I'm with Bernie - I think the 10ft rule is because of the voltage drop with longer runs. Bigger (thicker) wires would let you get away with it.
Where is you 12v distribution panel and converter going to go... I'm assuming this feedline is already fished? If not, i'd say pull your 12v line back along the 120 volt one back to this panel?
Marc
Old 04-02-2007, 10:35 AM   #34
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
4 conductor wire (3 plus ground) #8 would be good for 220/240V 2 phase 50 Amp service.
3 conductor wire (2 plus ground) #10 would be good for 120V single phase 30 Amp service.
Michelle TAC MT-0
Sarah, Snowball
Old 04-02-2007, 02:35 PM   #35
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
The '10 foot' rule may be for Coast Guard requirements - remember boats are like airplanes in that if something gets bent dramatically, the vessel must be able to continue floating-flying.
If I was at the stage you are now I'd be adding a lightning arrestor and some basic surge protection. I've browsed ebay for a Blue Sea 3 place 12VDC panel, 450A A-B battery switch and another battery cutout switch and a kohler shore-generator switch plus a DC lightning arrestor - I think the 12V provision is for illuminated circuit labels, the lamp kit is a seperate accesory..
Old 04-02-2007, 08:50 PM   #36
1976 Argosy 24
Bernie, Marc, Wabbiteer
I spoke to Blue Sea this afternoon.
The Minimum /Maximum conflict regarding the 10 foot rule was a printing error in their catalog, which they have now corrected.
The installation literature calls for the breaker to be within 10 feet of the power inlet because they must meet the strict membership standards of the ABYC.
Wabbiteer is right. Codes are very strict in boating. The reasoning behind the rule is that only 10 feet of your boat can supposedly catch on fire this way.
The panel's position is perfectly safe for me. Trailers don’t need to meet boating codes.
They understood my comment about the lack of information on the 12v supply situation and apologized. They said they would take note and update their literature.
The reason behind their oversight was that backlit signage was until recently an option. Now it’s included with the panel. The technical designers are ahead of the graphic designers.
I considered mounting an $18 transformer for this but 12v from the battery is better. That way the panel is lit even when I’m not on shore power.
Phil and I poked a feed to that area in about 10 minutes tonight.
They said the box I will have built for the panel does not need to have cooling.
I will have the box built tomorrow over at Wiltsie’s.
Now I hope my local electrician will not be afraid of this sophisticated looking equipment.
Sergei
Old 04-18-2007, 08:07 AM   #37
1976 Argosy 24
Blue Sea update
This is the box that I had built for the Blue Sea panel, which we plan to install tomorrow.
For a full update on how it is progressing, check my main thread at:
http://www.airforums.com/forums/f227...-18448-16.html
Sergei
Old 04-25-2007, 05:52 PM   #38
martinez , California
Wire
The NEC requires 10 AWG conductors if a 30 amp circuit breaker is used. If the run is very long (over 50 feet) you might want 8AWG to minimize voltage drop.
UJ
Uncle Jack is offline   Reply With Quote
Old 04-26-2007, 08:57 AM   #39
1976 Argosy 24
110v completed; moving on to 12v distribution
This is the completed Blue Sea 110v distribution centre.
The toggles on each breaker move with a quiet but solid “click”. LED lights indicate power. There is even a built in Reverse Polarity Indicator.
The circuit nameplates remain constantly backlit with 12v power. You can come into a pitch dark trailer and read the labels. I really like that feature.
The 4455Tc Paramode Converter/Charger with TempAssure in on it's way and we will shortly order a Blue Sea 12v distribution panel and battery shut-off.
Sergei
Old 04-26-2007, 09:22 AM   #40
1976 Argosy 24
sorry, photo above missed
Blue Sea distribution panel 4" by 10", 5" deep. State of the art.
Old 04-26-2007, 05:37 PM   #41
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
looks good joe, sorry i did not get back to you sooner.
this week has been a bit hectic.
john
you call them ferrets, i call them weasels.
Old 08-26-2007, 12:56 PM   #42
1976 Argosy 24
This is the original terminal strip in the 1976 Argosy, connecting the umbilical cord to the trailer’s 12v system.
IS THIS MERELY A TERMINAL STRIP OR ARE THE CONNECTORS FUSED?
Is so, for how many amps?
Is there something better on the market, thirty years on?
Sergei
Help! Resistor on fan switch Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 22 12-20-2003 08:01 AM
Safe from Lightning in an Airstream? maggieairstream Our Community 21 07-22-2003 04:18 PM
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 07:14 PM
