Old 10-21-2007, 09:37 AM   #41
C Johnson's Avatar
1965 17' Caravel
1968 28' Ambassador
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Originally Posted by doglickfarms
I am new to the Aistream forums. I am completely remodeling a '72 Overlander and I am doing away with the gas and going straight electical, since I am not going to be boondocking. Can I do everything in AC and get rid of all those wires that are in the camper or do I need DC as well? Any and all adive would be welcome.
You will need D/C for things like vent fans, refer control panels, water heater controls, tank sensors, etc.
My opinion is to run your wire for your electric appliances and install a good converter for the 12v side such as the intellipower.
Your resale value will be much much less with out the 12v in there. Even if you didn't want to use it I would leave it.
My .02
AIR # 7276, WBCCI # 7276
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
HELP! Electrical problem FranceyS Electrical - Systems, Generators, Batteries & Solar 6 08-03-2010 02:57 PM
Electrical problem--99 safari Andrew Carey Electrical - Systems, Generators, Batteries & Solar 2 11-16-2002 02:04 PM
Wiring for electrical horn on 310 shelocta Airstream Motorhome Forums 3 09-03-2002 09:40 PM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 07:39 PM
