Old 10-31-2013, 05:28 PM   #15
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Great Idea from adonh
Originally Posted by adonh View Post
Contact Randy at BestConverter - Converters, Inverters, Electrical Supplies, Electronics. He is a forum commercial member and can probally answer all of your questions and provide you with the proper convertor for your setup. You won't be sorry.
As for Parallax as recommended by Melody Ranch, I am puzzled.
Airstream was installing Parallax converters in Airstreams for a long time, and that is what I took out just as soon as I got our 2007. It was a real battery boiler. I believe that is why they are so readily available on EBay. Perhaps Melody can clarify and and my misgivings can be disregarded.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-31-2013, 05:54 PM   #16
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
OOps ....I meant Progressive Dynamics. I use 'em in all my Airstreams. Never a problem (yet?)
Old 11-01-2013, 08:01 AM   #17
Brevard , North Carolina
I'll start looking
Thanks to everyone for all your help, we will get started on shopping around for a power converter, charger and a fuse panel, hopefully that will fix it. When it comes to replacing the old univolt with the new, can someone walk me through it? Or should I have the RV repairman do it? Again, we are so so new, and have done some plumbing and propane repairs, but nothing electrical. I'll post pics soon of what we have done!
NwilcoxM is offline   Reply With Quote
Old 11-01-2013, 08:09 AM   #18
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
I repeat. Contact Randy at BestConverter - Converters, Inverters, Electrical Supplies, Electronics. He is a forum commercial member and can probally answer all of your questions and provide you with the proper convertor for your setup. You won't be sorry.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 11-01-2013, 08:25 AM   #19
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Yep.....get rid of your 'hummer'.
Our P-lax now resides on the bench, living it's life as a 12v power supply, never to be married to a battery again.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 11-01-2013, 08:33 AM   #20
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
I'll firmly back that up. Call Randy! Loving our IOTA from Best Converter which in turn loves our AGM batteries.
SuperTrouper is offline   Reply With Quote
Old 11-01-2013, 09:18 AM   #21
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
It's a Simple Installation...
But not something everyone will be comfortable doing themselves.
So, if you and/or your husband don't consider yourselves "basic" electricians with some knowledge of 120 volt AC wiring and some knowledge of 12 volt DC wiring, and how the two systems work together,go ahead and have it done.
But don't pay more than $45 for labor. It takes about 30 minutes.
Here in Albuquerque, the RV techs charge a flat $110 per hour, and they love jobs like this since for them it's a "plug and play" you pay installation.
Ken L
1966 Tradewind 24
Old 11-01-2013, 12:52 PM   #22
contacted Randy
I went ahead to ordered as per Randy's recommendations the Powermax Boondocker 60 amp, and 9 position fuse board. We will have our electrical friend install and it and save some money on labor since we went with a more powerful power converter. Hope this fixes our problems!
Old 11-13-2013, 08:29 AM   #23
Help with power converter swap out
I know this is a crazy question, but how do you get to the univolt to remove it? Its surrounded by gas lines and even with long arms, you don't have enough space to do anything. Is there a way to get to it from the outside behind the battery?? Our electrician friend bailed, so we are going to replace it ourselves but don't know where (literally) to begin...
Old 11-13-2013, 08:55 AM   #24
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Is it under the gaucho? Remove the gaucho.
You cannot remove and replace the converter/charger from the outside.
It comes out the way it went in. From the inside. But it went in before the furniture was installed.
Find yourself an "Airstream Buddy" to guide you through the process. I have guided many through the process here in Abq.
Ken L
1966 Tradewind 24
Old 11-13-2013, 09:23 AM   #25
Univolt location
My univolt is under the stove in the kitchen, right next to the door. The only opening is a tambor under the stove, way in the back, behind all the gas lines...
Old 11-13-2013, 02:06 PM   #26
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Ah, I had one like that once.
You take the stove out, not a difficult task.
Remove four screws, disconnect the propane line, and lift the stove up and out.
Know where you are going to set it and protect the floor with a piece of cardboard or a canvas drop cloth.
Be sure to turn off propane tanks.
When you reinstall stove, do a leak check with soapy water.
Ken L
1966 Tradewind 24
Old 11-13-2013, 04:31 PM   #27
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
I had a similar problem on my tradewind the problem turned out to be an automotive type circuit breaker It was located behind the control panel
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
