Old 06-07-2009, 03:45 PM   #1
rollin home's Avatar
1992 36' Land Yacht
Oroville , California
Electrical - this cord goes into a green box
(electrical) the box is similar color to the Onan generator,
and is mounted just in fromt of it...what is the cord for?
I have a 36' land yacht motor home, and am
wondering about an electric system component
i have....it is a power cord located in front of the generator..
but not attached directly to it. the 3 prongs are a bit different from the 30 amp cord that connects to the rear (main) electric connection.
it has 3 prongs, and one is round, the other two are slanted (not parallel with each other.
o
sort of like this...if the spacing comes thru in the post.
the main plug looks more like this
_
with a little "j" prong on the lower element.
i am too far from the power source for the power cord to reach the back of the rig, and wonder if
i can plug in the cord that comes out of the mid-
section, but want to make sure what it is prior to doing that.
Laurel
rollin home is offline   Reply With Quote
Old 06-07-2009, 03:48 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It may be for the motor home to plug into the generator. There should be a female plug on the wall of the generator compartment, is there anything plugged into that?
Old 06-07-2009, 09:06 PM   #3
1992 36' Land Yacht
the generator does power the coach, and so i do not think this is for sending power
to the systems...it has a male plug (that may determine which way current flows thru)
the small box has a label that says SWITCH, Plano, TX and it has a 30 amp cord.
I took some pix..i will try to figure out how to post them...(go advanced??)
this "switch" box is wired to a junction box (i think that's what you call 'em)
a 4 " square metal box that has a wire that seems to go to the back of the generator.
Old 06-07-2009, 11:10 PM   #4
1992 36' Land Yacht
some pix here..of the switch box, the generator and the electric box the wire goes into..
Old 06-08-2009, 11:09 AM   #5
1992 36' Land Yacht
where'd the pix go--try again
two pix of electric system components--
1.) generator and green switch box
2.) metal box on top side of Onan compartment
ID:	81884   Click image for larger version
Old 08-13-2009, 11:29 AM   #6
1992 36' Land Yacht
still wondering what this plug is for...
is has what i believe you would call a 30 amp male plug on it
it is the cord coiled on the left side of the picture
cord, electric, plug, power
Old Green Lloyd Goree Member Introductions 8 03-16-2008 09:08 AM
1963 Bambi Electrical Box? lpifly Electrical - Systems, Generators, Batteries & Solar 4 09-10-2007 01:10 PM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
I'm seeing green till Our Community 1 10-14-2004 08:18 PM
Need help!-Finding thread about electrical cord. WayWard Wind Our Community 5 03-25-2003 07:37 PM
