Old 03-27-2013, 05:05 PM   #1
Dobber's Avatar
2012 25' FB Flying Cloud
Queens , New York
Electrical test equipment
we are setting up the new trailer and i was wondering what types of test equipment do experienced AS'ers think is essential to have on board ?
thanks-in-advance.
Rob.
Dobber is offline   Reply With Quote
Old 03-27-2013, 05:12 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy! A basic analog Volt Ohm Meter (VOM) with alligator clips for holding wires should suffice.
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-27-2013, 05:14 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I would only have a "Kill-A-Watt" for checking incoming voltage and cycles. Also a "Polarity Tester" to make sure the source of power is correctly wired. Nothing else on a trailer this new.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-27-2013, 05:27 PM   #4
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
I would suggest what is refered to as a DVOM in many circles, or a Digital-Ohm-Volt-Meter.
I use a fairly sophosticated Fluke model but you can get meters from many companies.
A/C voltage, DC voltage, low impedience resistance and a good amp meter will get 99% done.
Bruce
Bruce B is offline   Reply With Quote
Old 03-27-2013, 07:18 PM   #5
Images: 59
A Fluke Model 87-V True RMS multimeter, or similar, and a plug in polarity tester is all you need.
Old 03-27-2013, 07:24 PM   #6
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
I have a DVOM and a couple polarity testers. I keep one of the polarity testers puged in all the time so I can just glance at it for a check now and then. I took a silver marker and colored it to match the trailer.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 03-27-2013, 07:27 PM   #7
Central , Mississippi
We couldn't do without one of these...
TriMetric Battery System | Bogart Engineering
We do a fair amount of camping with no hook-ups and this is THE trick to managing battery usage
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 03-27-2013, 08:05 PM   #8
Bruce B's Avatar
+1 !
Bruce
Old 03-27-2013, 08:07 PM   #9
dznf0g's Avatar
Oswego , Illinois
Originally Posted by Bruce B View Post
+1 !
Bruce
+2....and I do carry a kill-a-watt, polarity tester and a DVOM as well.
-Rich-
Old 03-27-2013, 09:02 PM   #10
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
+2
Wayne
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 03-27-2013, 09:12 PM   #11
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
Bruce
Fluke equipment is top notch, but not inexpensive. They call their digital meters DMMs (Digital MultiMeter). I have a Fluke 115 and like it a lot. I also have a Fluke 336 DC Clamp Meter. This meter also has DMM functions so you would be well equipped with this meter alone. No real need for a separate DMM\; I just like having the separate meters
- wayne
AIR #44779
TAC AK-1 !!
Old 03-27-2013, 09:50 PM   #12
Maniacal Engineer
barts's Avatar
Menlo Park , California
+4
This unit is of course permanently connected; photo attachedof our install.
In addition I carry a DVM, and a combo AC meter/polarity tester. I don't take the Kill-A-Watt, since I know what the draw is on my (minimal) AC gear.
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 03-27-2013, 10:50 PM   #13
Hobo
2006 25' Safari
Florence , Oregon
Nearly everyone carries a DVM and a Fluke isn't really necessary although it is the best out there IMO. A couple things not mentioned that I find very useful are a 12vt. automotive type test light. It looks like a ball point pen or small screwdriver handle with about 18" of wire with an alligator clip on the end. There is a light inside that illuminates with voltage. This is much quicker and easier than using a DVM for simple tests. Also, a couple of wires with alligator clips on both ends (called jumpers) are always handy.
voremus is offline   Reply With Quote
Old 03-27-2013, 11:07 PM   #14
mefly2's Avatar
2015 25' FB Eddie Bauer
Vote for the VOM and/or test light ...
