Old 03-28-2013, 05:23 AM   #15
Wise Elder
Jammer's Avatar
2010 30' Classic
Hi Rob.
The only test equipment I carry on the road is a 12v test light and a cheap voltage indicator that plugs into a 120v outlet. I guess I have one of those 3-light 120v outlet testers in the shore power locker but I don't think I've ever used it.
The running, stop, tail, and turn lights, and the electric brakes, are the most important items and are the most likely to fail. A test light is the best way to troubleshoot those sorts of problems.
I've had my eye on this tester which I think would be ideal for RV work, covering both AC and DC systems:
GTC CM100 1 mA to 100 Amps AC/DC Low Current Clamp Meter : Amazon.com : Automotive
Old 03-28-2013, 06:13 AM   #16
Dobber's Avatar
2012 25' FB Flying Cloud
Queens , New York
Thanks everyone ...
that's a pretty complete list I would say.
thanks everyone for your input.
I've gotta start shopping around.
Dobber is offline   Reply With Quote
Old 05-07-2013, 07:49 AM   #17
Dobber's Avatar
Queens , New York
We couldn't do without one of these...
TriMetric Battery System | Bogart Engineering
We do a fair amount of camping with no hook-ups and this is THE trick to managing battery usage.
is this a DIY install ?
seems like a real necessity. doesn't seem like it would be too
complex to set up.
thx.
"Common Sense is like Common Courtesy,
ain't neither one too common these days"
Old 05-07-2013, 08:13 AM   #18
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Agree with above posts, 12v test light, VO/AC-DC meter etc...
In addition this little guy has been an invaluable inexpensive investment.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 05-07-2013, 09:58 AM   #19
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
complex to set up.
thx.
I'm a real believer in the TriMetric. Whether it is DIY depends on:
  • Your skills and comfort level with working on electrical equipment
  • Access to a few basic tools and some test equipment
  • The location and configuration of your battery bank
  • Where you plan to install the TriMetric
Some important things I learned while installing mine:
  • The connection to the negative side of your battery bank must include absolutely ALL of the current sources. On my rig, there are several negative cables bonded to the outside of the battery box. This required some modifications to my original plan. I mounted the shunt on the outside of the battery box and installed a pass through stud so the connection could be made directly from the negative battery cable.
  • For my rig, I opted for the 100 A shunt vs the 500 A one. Your rig may not allow for the 100A shunt.
  • Bogart support is great. Each time I called I was able to talk directly to the designer, Ralph Hiesey.
  • It is very useful to go to the website and download both the installation instructions and the user guide. Read these carefully and plan your installation.
  • The install isn't as simple as I first imagined and the setup is a little quirky, depending on how deep you want to go into the capabilities of the TriMetric.
  • The routing of the signal cable from your battery bank to the TriMetric panel can involve some "interesting" cable snaking challenges, depending you your rig and where you install the panel.
PM me if you have specific questions and I'll try to help.
Good luck,
Wayne
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 05-07-2013, 11:47 AM   #20
1974 Argosy 20
Kooskia , Idaho
I have had a Fluke VOM for years and years, and it has been a good investment, but then I am kind of an electrical gear head.
I know it may be funny to say this, but if you are not a nut on electrical things, just go to Harbor Freight and get one of their under $10 digital VOM's. That way you have a minimal investment, and you can get readings to report here on the forums for additional help. I have found the HF VOM's are certainly accurate enough for most uses. They are not rugged but if kept reasonably carefully will do very well for the average user.
If you like nice tools though, buy a Fluke. I also like the Kill A Watt meter, but it is icing on the cake, not essential.
