Old 07-23-2015, 11:57 AM   #1
nickclifford's Avatar
1972 31' Sovereign
felton , California
electrical switch panel housing unit
hi, sorry if this is in the wrong forum, nothing actually wrong with the electrical panel but the plastic housing unit has failed, just gone brittle and cracked. Any thoughts on a replacement unit ? Vintage Trailer supply don't stock this part.
trailer is a 1972 Sovereign.
many thanks in advance, Nick
nickclifford is offline   Reply With Quote
Old 07-23-2015, 01:55 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Try Inland RV and Out-of-doors mart, either might have a replacement in stock, but probably not.
Otherwise your best bet is to repair the plastic by taking the whole thing out and using fiberglass and epoxy on the back.
Old 07-23-2015, 03:07 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you know anyone that does fiberglass work i would remove the unit remove the gauges and fiberglass cloth on the face of the plastic. Fiberglass cloth dries crystal clear. If you want a flat surface you will have to apply additional coats of resin but when done it will be as flat as glass.
Fiberglass also hides the cracks.
The mailbox was glassed before painting
2004 Excursion 4x4
Old 07-27-2015, 06:59 PM   #4
1972 31' Sovereign
felton , California
thanks for the advice everyone..
Tail light housing on '65 Overlander 65 overlander Lights - Interior & Exterior 5 01-20-2013 05:28 PM
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
I am looking for a wheel well housing aprimosch Wheel Wells 3 12-25-2008 09:25 AM
I need a reverse light housing!!! gretchen Lights - Interior & Exterior 1 05-21-2007 08:08 PM
Seeking Replacement Stoplight Lamp Housing AirConditioner Electrical - Systems, Generators, Batteries & Solar 0 02-14-2005 05:46 PM
