Old 02-28-2017, 06:08 AM   #1
1993 21' Sovereign
Winter Haven , Florida
Electrical Short?
Morning All,
Wiring in my new fridge Hot lead to fridge not hot. Checked all leads out of 12v distribution box. All good except top right 20 amp fuse. Moved lead down to a confirmed hot lead two down in panel. Turned on power. Heard a click. Now top right and 3rd one down right no longer hot. Multiple part question
1. The fuses looked riveted in. Can the 20amp fuses in distribution box be reset?
2. Cause of fuse popping can only be a short?
3. Can I track and fix or due to wiring behind riveted panels am I forced to take my trailer to service center?
4. Any suggestions for help with this in or near Winter Haven, FL? or can someone suggest a quality rv/airstream service center strong in electrical?
As always suggestions or advice appreciated.
Darryl
oceanicdb is offline   Reply With Quote
Old 02-28-2017, 06:41 AM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
I think your trailer has breakers that have a reset button. Look closely on the side of each breaker to see if there is a small black button extended. Push the button back in if it is extended to restore power.
My guess is there is a short in the refrigerator, or wired incorrectly.
add edit:
A photo at this web link
https://www.delcity.net/store/Manual...FdcegQodHQsHBw
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 02-28-2017, 06:53 AM   #3
1977 31' Sovereign
2005 30' Safari
1977 28' Argosy 28
North Port , Florida
I would disconnect the 12v at the fridge. Reset, replace or wait for the circuit breaker to cool and try again with the fridge disconnected. If it doesn't pop the issue could be isolated to the refrigerator.
cliffcharb is offline   Reply With Quote
Old 02-28-2017, 07:01 AM   #4
1993 21' Sovereign
Thanks for the replies. Not fridge for sure. Just before buying new fridge i noticed the outside door lamp stopped working as did the couch reading light on that side. Chalked it up to bulbs and put on to do list. Obviously thryboth are wired in series with hot wire to fridge compartment. The new fridge has never had power to it. So with those as given facts short has tobe somewhere is wiring or maybe the lights. Took apart the door lamp. Looked clean and attached properly etc. really stumped.
Old 02-28-2017, 07:31 AM   #5
Gainesville , Florida
JD Sanders, in Alachua just north of Gainesville. Airstream dealer.
Old 02-28-2017, 09:24 AM   #6
Mollysdad's Avatar
No, it might be drawing more power than the fuse allows or circuit breakers getting old and weak.
Electrical help..short or not RandyG Electrical - Systems, Generators, Batteries & Solar 42 04-20-2009 07:53 PM
electrical short? john c Electrical - Systems, Generators, Batteries & Solar 3 03-11-2008 03:28 PM
Short -Short Ramp Lights - Interior & Exterior 0 09-12-2007 04:34 PM
The Dreaded Electrical Short!! lebolewis 1974 - 1979 Sovereign 3 05-15-2007 02:49 PM
The Short, Short Trailer - Spamboree flamingo-kid1 On The Road... 2 04-14-2005 01:41 PM
