Old 05-24-2015, 06:23 PM   #1
2009 25' FB Flying Cloud
Old Orchard Beach , Maine
Electrical short
I have a 2009 25' Flying Cloud. Tried to install new batteries. When I try to make the connection, I get a big flash, and blow both 30 amp fuses under the bed. Also tried w/ battery pack, same thing. Yes the polarity is correct. Need some ideas. Thanks!! Gordy
gordymurphy4 is offline   Reply With Quote
Old 05-24-2015, 08:15 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Gordy... Need to tell us why the batteries failed... Is his a new problem?
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-24-2015, 08:34 PM   #3
richinny's Avatar
2011 34' Classic
are these 6v or 12v batteries?
did you check along the positive cable for the cable touching some metal?
are the batteries charged?
Ricky
Old 05-24-2015, 09:53 PM   #4
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Not much info to go on.
1 or 2 batteries?
6V or 12V
Not long ago some one posted they bought 2 new 12V batteries and when they tried to hook them up they were really 6V.
Garry
Old 05-25-2015, 04:44 AM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Get an ohmmeter and find where the short is.
Old 05-25-2015, 08:27 AM   #6
Question Elec. Short
The original batteries are 6 yrs. old, and planning a trip, don't want any problems. Both new batteries are fully charged. There are no bare wires touching anything. I am wondering if there might be a relay stuck, or maybe a problem w/ the converter. (blows both 30 amp fuses when the terminal is touched to the post) When I try to connect the terminal to the battery, the much more than normal flash occurs.(like all electric devises are turned on) I am very familiar with the 6 - 12 volt systems, as I have been an auto mechanic for 37 years. What I would like to know, has anyone else had a similar problem with their Airstream. Just looking for a place to start. Thanks!! Gordy
Old 05-25-2015, 08:52 AM   #7
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
To answer your question, I have not had that problem, but.....
It is hard to imagine that this problem appeared after simply replacing the batteries. What do the 30A fuses feed? I'm guessing one is in line with the battery and the other is in line with the converter. Leave the battery disconnected. Replace the fuses and plug in the shore power. Does everything running from 12V work normally in the trailer? Try just some lights first. If not, perhaps the converter has failed and was shorting out the batteries. Try the tongue jack. Maybe the cable is pinched somewhere. Measure the voltage at the battery cables. Is the polarity correct? The voltage? Other than a failed converter or reversed polarity, I can't think of anything.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 05-25-2015, 10:55 AM   #8
Question elec. short
Al: Thank you for your info. With the bat unhooked, and connected to shoreline, the fuses do not blow. I leave shoreline connected, both 30 amp fuses connected, battery disconnected, fuses do not blow, nothing works. ( lights, ect.) Shoreline connected, battery connected, both 30 amp fuses removed, everything works. Shoreline disconnected, battery connected, fuses removed, everything works except air con.Touched fuse panel spades with good 30 amp fuse, and I get a heavy arc. I hope this makes sense. Thanks again!! Gordy
Old 05-25-2015, 01:07 PM   #9
elec. short
If the inverter/converter fails, what are the simtoms? Gordy
Old 05-25-2015, 04:19 PM   #10
garry's Avatar
1969 31' Sovereign
You can meter for a short at the 30 amp fuses one side goes to the load and one side comes from the DC distribution panel.
Or go to the DC distribution block you will have two main 12V INPUTS one set from the battery and one set from the converter. From there you can meter for a short coming into the panel or going out.
Normally when the converter fails the batteries go dead since it is the function of the converter to keep the batteries charged and supply +12V when on shore power.
Garry
Old 05-25-2015, 10:09 PM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Electrical short
Where are these 30 amp fuses located?
You stated: shoreline disconnected, fuses removed, battery connected. "Everything Works".
That tells me the wiring is good from the battery(s) to the fuse panel.
If everything works when on battery. And everything works when on shore power without the fuses. Then why the fuses?
I am still leaning toward a reverse polarity situation. And would double check the wiring a wire colors. To make sure everything is of the correct polarity.
Old 05-25-2015, 11:03 PM   #12
Sounds to me like the converter output is shorted. This is one of several possible failures. There is no one answer to your question of symptoms of converter failure.
"With the bat unhooked, and connected to shoreline, the fuses do not blow. I leave shoreline connected, both 30 amp fuses connected, battery disconnected, fuses do not blow, nothing works. ( lights, ect.)." This is not good. If the converter were working, everything that runs off 12 volts should work.
"Shoreline disconnected, battery connected, fuses removed, everything works except air conditioner". This is normal and indicates that the battery wiring is correct and the battery(ies) are supplying power to the distribution panel.
If you can do this, a final test would be to disconnect the converter output and measure the voltage at that point. The best way would be to disconnect the (probably) red wire from the plus terminal of the converter. With the battery connected and both fuses in, everything should be OK. BE VERY CAREFUL WITH THE DISCONNECTED WIRE. IT IS CONNECTED TO THE BATTERY. You should measure positive 12 volts (from the battery) between the wire and ground. If you successfully complete this test, it is probable that your converter is shorted.
The only strange thing is when both fuses removed and shore power and battery connected, everything works. Do you have an inverter? What kind of store switch do you have? Older trailers have a mechanical rotary switch. Newer trailers have a pushbutton that controls a relay. Either a disconnect relay or an inverter could play into this problem.
Al
S/OS #004
Old 05-26-2015, 02:29 PM   #13
elec short
You sound like you have a few years of elec. behind you. Real nice when we ask a question, and someone only talks about the exact problem, instead of the usual boloney. Might you know where the inverter is located, an maybe the shape.? Thanks!! Gordy
Old 05-26-2015, 03:56 PM   #14
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Your inverter is going to be underneath the bed near the front wall, just about in the middle of the trailer. It is rectangular, mounted to the plywood bed support. It cannot be mistaken for any other device.
Larry
lsbrodsky is offline   Reply With Quote
Electrical help..short or not RandyG Electrical - Systems, Generators, Batteries & Solar 42 04-20-2009 07:53 PM
electrical short? john c Electrical - Systems, Generators, Batteries & Solar 3 03-11-2008 03:28 PM
Short -Short Ramp Lights - Interior & Exterior 0 09-12-2007 04:34 PM
The Dreaded Electrical Short!! lebolewis 1974 - 1979 Sovereign 3 05-15-2007 02:49 PM
The Short, Short Trailer - Spamboree flamingo-kid1 On The Road... 2 04-14-2005 01:41 PM
