Old 07-27-2016, 11:46 AM   #15
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by Reza View Post
Thanks for all the replies. Got a new battery and the lights and power jack work so I'm hoping everything else is fine once I plug in to an RV outlet somewhere.
Cool, you can check it with an adapter at your house, you don't have to wait until you're at a campsite.
Got an electrician to look at it and he suggested what everyone else has said which is to replace the connector plug. He could not find the circuit breaker box however which kind of surprised me. We looked in the rear driver side section and he found what may be called a junction box but not circuit breakers. He thought a previous owner may have removed them. Does that make any sense?
I guess nothing involving ill-advised changes to trailer wiring surprises me any more. The breakers are important for safety. If they were removed, new ones should be installed.
Perhaps someone with the same year and model of trailer can comment as to the usual location of the breaker panel. They can be hidden behind stuff, and for some years they are part of the 12v converter.
Old 07-28-2016, 06:53 AM   #16
Retired
tvketchum's Avatar
2008 30' Classic
Livingston , Texas
Most battery isolation switches are located near the 12 v fuses, and usually, these are fairly close to the batteries. Our rig, this is under the sofa in front.
Tom
TVKetchum
Tom
AIR 71620
WBCCI 5809 Reg 5 Unit 041
2008 Classic 30'
2013 F150 Ecoboost
tvketchum is offline   Reply With Quote
Old 07-29-2016, 12:43 PM   #17
McDave's Avatar
2014 23' Flying Cloud
Fair Oaks , California
You didn't mention this as a specific problem, but whenever I connect the Airstream to house power, I find that the weight of the adapter and AS power cable pulls down on the adapter where it is plugged into the wall and tries to unplug it. For the adapter to stay solidly plugged into the wall I need to support it with something so it doesn't have a downward force on it where it plugs into the wall.
McDave is offline   Reply With Quote
Old 07-30-2016, 08:41 AM   #18
HowieE's Avatar
Princeton , New Jersey
Images: 12
The prongs in the receptacle have relaxed and will not hold the plug in place. Replace the receptacle as that issue over time will cause a burn on the prongs of both the plug and the receptacle and cause heat at that connection.
2004 Excursion 4x4
Old 07-30-2016, 11:27 PM   #19
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I have a heavy 50 AMP Cord and plug..whenever I plug in at home or campsite....it takes a bit of force to "seat" the plug into the recepticle... Or I do not use that recepticle... Lesson learned a while back....
Peace and Blessings..
Channing
WBCCI# 30676
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 08:24 PM
Shorepower Problem SteveandSam Batteries, Univolts, Converters & Inverters 7 01-16-2012 11:01 PM
Use or Store button(Batteries/Shorepower Devoman Batteries, Univolts, Converters & Inverters 4 09-26-2010 11:18 PM
Newbie with an electrical question Whistling_Gypsy Electrical - Systems, Generators, Batteries & Solar 3 12-28-2003 07:24 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 08:39 PM
