Old 07-18-2014, 04:45 AM   #1
1959 17' Pacer
pottstown , Pennsylvania
electrical schlematic
im looking to update a 1959 airstream pacer and would like to know how the original wiring system is installed and how they ran the wires i want to update electrical wiring thru out
botech is offline   Reply With Quote
Old 07-18-2014, 07:56 AM   #2
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Finding a schematic for this old of trailer might be next to impossible. If you are taking the inside skins down, I would replace all of the wiring and make your own schematic.
That way you are sure of two things-you have upgraded wiring and you know where everything goes along with having an accurate drawing.
This is what I did with mine.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 07-20-2014, 06:08 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Excellent advice... you must strip the interior sheet metal to gain access. Then, rewire.
You have simple 12VDC and 120VAC circuits... don't cross the streams..
Peace and Blessings..
Channing
WBCCI# 30676
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
I have made many electrical changes FrankR Electrical - Systems, Generators, Batteries & Solar 4 10-03-2008 08:53 AM
Electrical changes 120 volt ac FrankR Electrical - Systems, Generators, Batteries & Solar 5 03-13-2005 06:20 PM
New electrical in position FrankR Electrical - Systems, Generators, Batteries & Solar 5 05-18-2002 11:47 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 07:39 PM
