Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-23-2008, 09:08 PM   #1
Profile:  1973 31' Excella 500
Marysville , Washington
Electrical schematic?
I'm looking for insights to the elctrical system(s) '73 Excella. I'd like to inspect everything before I apply AC power for the first time. I'd rather do that than simply plug-in and look for sparks as I have a lot of bare wires throughout. Are there any schematics or even block diagrams available?
Not Done is offline   Reply With Quote
Old 04-23-2008, 10:11 PM   #2
VAC Membership Chair
Buttercup's Avatar
Profile:  1977 27' Overlander
1954 26' Romany Cruiser
VC Highlands , Nevada
Well, it may not be any help but I could offer a schematic for our '77 Overlander.
If not, you could always unplug everything then plug the trailer in with all Circuit Brakers in the off position. Then cut them in one by one. Once that is done you coulse use an outlet tester to check each outlet.
My guess is that unless the trailer went to hell and back and looks obviously damaged, all will work just fine....
Don't let the IBT Scuttle the WBCCI - Just Vote NO! Save Wally!
Buttercup Web site Looking for a unit? Check out the SaveWally Unit Guide.
2008 Mouse count =
WBCCI # 17330, VAC Membership Chair, CAC Member
Buttercup is offline   Reply With Quote
Old 04-23-2008, 10:15 PM   #3
Anything you can provide would be greatly appreaciated. Thanks!
Old 04-23-2008, 10:32 PM   #4
Profile:  1966 26' Overlander
Weaverville , North Carolina
No advice for you, as I'm on a similar quest. But for a '66 Overlander. If I find out where to get one, I'll let you know for sure.
XO,
Starr
An Inherently Sovereign Being, Following Her Highest Excitement
Check out the Travelblogue! http://sadhanastarr.squarespace.com
starr is offline   Reply With Quote
Old 04-24-2008, 05:29 AM   #5
Profile:  1973 31' Sovereign
ocean , New Jersey
not done
pm me with a fax # and i will send wiring diagrams from 73 service manual
jim.
cuyd is offline   Reply With Quote
Old 04-24-2008, 12:17 PM   #6
cuyd
Thank you so much. Mine is even a center bath!
John
Old 04-24-2008, 07:08 PM   #7
ocean , New Jersey
not done
yup i sent rear and center bath,
there is also one for canadian version.
jim.
Pingbacks are On
frame schematic not2tacky Repairing/Replacing Floor &/or Frame 7 02-17-2008 06:28 PM
71 globetrotter schematic Aerowood Electrical - Systems, Generators, Batteries & Solar 4 09-07-2006 09:09 AM
Plumbing schematic of 55 FC NorCal Bambi Plumbing - Systems & Fixtures 2 08-05-2006 09:55 AM
schematic needed! john hd Electrical - Systems, Generators, Batteries & Solar 7 04-07-2003 11:09 AM
'63 Safari Plumbing Schematic? petefundis Plumbing - Systems & Fixtures 1 09-18-2002 06:56 PM
SEO by vBSEO 3.1.0
