Old 05-21-2016, 12:48 PM   #1
1973 25' Tradewind
Beautiful , Oregon
Electrical Question Which Battery Cable is Positive?
Please help keep me out of trouble. Both of my battery cables are black. I hooked up the black cable to the new battery that was attached to a marine style 45 amp breaker to the positive side of the battery.
The other one just went to one of those blocks with a screw in it. So to me who knows nothing about this stuff seemed logical.
The lights went on just fine. Does this mean I have them hooked up correctly or is a not so fast situation, other dangers lurk about.
Thanks for your help in advance
Tony
Tony S is offline   Reply With Quote
Old 05-21-2016, 01:19 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
The cable with the circuit breaker is most always the positive cable.
Sitting here in NM, I say that you 99.999% have it right.
Superat stultitia.
Old 05-21-2016, 02:02 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Tony, yes you have the connection correct.
MICHAEL
Old 05-21-2016, 04:22 PM   #4
1973 25' Tradewind
Beautiful , Oregon
Thanks guys that is good news.
Just to put a slightly sharper point on it. If I had it backwards what would of happened?
Lights not go on?
Fry converter?
Other?
Thanks again
Tony
Old 05-21-2016, 04:37 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
You'll probably let the 'magic smoke' out of some of your electrical components.
Since it imperative to retain all of this 'magic smoke' within those components at all times, as it's presence is totally responsible for the proper operation of said components, it's a situation that should be avoided at all costs!!! 😁
PS: try wrapping some red electrical tape around the end of the positive cable too.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
Old 05-21-2016, 05:33 PM   #6
1973 25' Tradewind
Beautiful , Oregon
Yes "the magic smoke'.
Red tape applied. Me no make same mistake twice.
Tony
Battery Hold-down Strap Shorting Against Positive Battery Post rel Sprinter and B-van Forum 3 08-13-2013 10:32 PM
WBCCI - One Man's Positive Opinion 47WeeWind WBCCI Forum 29 11-29-2009 10:17 PM
Small Positive Battery Lead Sundance Batteries, Univolts, Converters & Inverters 2 07-12-2007 12:19 PM
Any ST trailer tire that gets positive reviews? 63air Tires 13 08-06-2006 02:39 PM
WBCCI Families & Youth - Positive Reinforcement LuminumTraila WBCCI Forum 44 07-18-2006 10:51 AM
