Old 10-28-2012, 11:11 PM   #1
1959 22' Flying Cloud
Bishop , California
Electrical Question
What is the maximum distance allowed between electrical inlet and breaker box? Apparently on sailboats it is 3 meters, are RV regulations the same? Thanks
tonyp is offline   Reply With Quote
Old 10-29-2012, 04:39 AM   #2
No, they are different.
Old 10-29-2012, 05:46 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
On my Airstream they are about 12" apart. You will need to find a copy of the RVIA standards (I believe that is the correct one). Also there most likely will have been a change in standards between 1959 and today.
Aaron
WBCCI #XXXX AIR #2495
Old 10-29-2012, 06:34 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I don't think my "64 was built to any kind of electrical standards.
MICHAEL
Old 10-29-2012, 09:31 AM   #5
Bishop , California
I could not find a direct answer in the RIVA regs. Andy, you said they are different, do have have a more definitive answer? Mine (10 AWG) runs up the wall directly across the ceiling and half way down the opposite wall, its about 18-20'.
Tony
Old 10-29-2012, 09:40 AM   #6
Tony
RV's were "what's that thing" 63 years ago.
Standards basically did not exist.
Today is a very different story, thanks to technology and attorneys.
I would suggest you call Airstream at 937-5966111.
Old 10-29-2012, 09:54 AM   #7
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I don't believe you will find a hard fast regulation. RV shore power is not like a dwelling, in that the source of power is already protected by circuit beakers rated for the maximum current. As far as AC power is concerned, a RV is more like an appliance than it is a dwelling. Therefor the only consideration needs to be ensuring the conductor size must be sufficient to carry (in most cases) 30 amps for the distance you chose. There are readily available tables to determine the conductor size.
Here is an example.
http://www.djsociety.org/Wire.htm
The proceeding is my opinion, not a statement of fact or regulation.
Ken
Old 10-29-2012, 11:24 AM   #8
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Ken
I completely agree with your assessment.
I don't believe there is distance requirement on a dwelling either, as long as there is a circuit breaker protecting the wire from the meter to the inside panel box.
Dan
Old 10-29-2012, 09:56 PM   #9
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Given that the electrical inlet is the end of the shore power cable, and given that most shore power cables are 25-feet in length, when you add the run through the wall to the breaker box, in my unit it comes to about 30 feet.
I had previously had a LY motorhome. One of my buddies undertook the project to convert the shore power from 30-amp to 50-amp. As part of due diligence, he called CSA to check on the requirements, and there was no mention of the maximum length of cable - so he installed a 100-foot shore power cable, and I never needed an extension cord.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 10-30-2012, 05:15 AM   #10
richinny's Avatar
2011 34' Classic
now a 100' 50A cord HAS to cut into the payload a bit!
Ricky
Old 10-30-2012, 09:13 AM   #11
Bishop , California
Thanks for all the great replies.
Old 10-30-2012, 02:51 PM   #12
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Nope, it didn't. Remember that it was #10 wire. Once the mod was done, I never had any issue with shore power. I also didn't get caught with insufficient wire to reach some of the pedestals installed in Ontario provincial parks, where they have driveways with a number of pull-thru sites with trees and bushes between the sites and the pedestals are set up between 2 sites and require a minimum of 50 feet of cable.
VE3JDZ
AIR 12148
WBCCI 8080
Old 10-30-2012, 05:21 PM   #13
lewster's Avatar
Naples, FL , Hood River, OR
Interesting:
Every motor home or trailer that I work on with 50 amp shore service uses 6AWG from the plug that connects to the pedestal to the breaker box, or thru the transfer switch and then to the breaker box. Same with the big generators. IIRC, that is the current (no pun intended! ) RVIA specification.
Old 10-30-2012, 10:09 PM   #14
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Lew, the actual amount of current is only 30-amps. As you know, the 50 amp service is really 220-volts, one half at 30 amps and the other at 20 amps (as per the breakers). Thus, there is no more than 30 amps going through the red or black sides of the wire. The RVIA code in this respect is much more stringent than the normal electrical code.
Thus the same size wire gauge as is used for 30-amp 110-v service can be used for 30-amp 220-volt service. Before the wiring was changed in my motorhome, my friend, who builds and services commercial kitchen equipment for hotels and restaurants, called CSA to confirm that his plans met their specifications.
The original schematics showed that the ATS switches also switched the neutral (white) wires. CSA told him that it was overkill and was not required. Thus the revised circuit to upgrade the shore power from 110-volts 30 amps to 220-volts 30-amps (known in the RV world as 50-amps) was able to also use the existing ATS switches, but rewiring them to function for 220-volts. In the course of the 6 years I had that motorhome, the only thing components that did not crap out on me was the shore power circuit.
I found that motorhome repairs were insanely expensive (mine was a '94 LY diesel pusher), and the breakdowns and repairs during the 6 years I had it (and serviced it regularly with Cummins) were:
- harmonic balancer came apart, taking the fan, fan housing, serpentine belt with it;
- the ECM (electronic control module AKA the computer) for the Allison tranny failed;
- two alternator failures,
- twice having the Bosch fuel injector pump rebuilt (each time was $3,500)
- chassis air conditioning system crapped out - even the dash control failed
- Rear engine seals leaked and needed to be changed
No repair was ever straightforward. Parts were available, but never stocked, so any repair meant I lost the use of the motorhome for weeks - try sitting in a field outside a garage in Fort Stockton TX for a week waiting for parts to come in to repair the harmonic balancer and its collateral damage. Last year I sold the motorhome and bought what I now have - a 32-ft Excella and a Dodge 3/4 ton truck. Best combo I've ever had - reliable, comfortable and easily serviced.
VE3JDZ
AIR 12148
WBCCI 8080
Newbie Electrical Question Stonew98 Batteries, Univolts, Converters & Inverters 4 12-13-2011 11:42 AM
Newbie Electrical Question Stonew98 Batteries, Univolts, Converters & Inverters 11 12-04-2011 06:00 AM
Electrical Question TikiPatrick Vintage Kin 7 08-27-2011 08:48 PM
Steel / Aluminum wheel question polarlyse Wheels, Hubs & Bearings 12 05-29-2011 07:49 PM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
