Old 08-15-2013, 01:17 PM   #15
Olroy
1976 29' Ambassador
1986 34.5' Airstream 345
Barbourville , Kentucky
olroy who don't know how to post a new question
Originally Posted by Inland RV Center, In View Post
No, they are different.
Andy or anyone else who has ran a 50 amp cable into an old airstream. How do you get it thru the back bumper into the compartment where the panel box is 76 ambassador, hole is too small for 50Amp cable. I'm an electrician , I can wire it if I can get the feed into the compartment from outside without screwing up my airstream. roywest1114@msn.com for answer I think.. Roy West in Hills of KY
Olroy is offline   Reply With Quote
Old 08-15-2013, 02:42 PM   #16
Images: 59
Originally Posted by tonyp View Post
What is the maximum distance allowed between electrical inlet and breaker box? Apparently on sailboats it is 3 meters, are RV regulations the same? Thanks
Correct answer is 450mm (18 inches). NEC 551.30.
Old 08-15-2013, 03:01 PM   #17
daveswenson's Avatar
2012 28' International
Issaquah , Washington
551.30 refers to generator installations, and the 18 inch limit does not have to be to the breaker board. Ie a junction box with a blank cover would satisfy the requirement.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 08-15-2013, 03:01 PM   #18
richinny's Avatar
2011 34' Classic
mark with all due respect.... my '94 34CL and the '11 34CL do not seem to meet those specs.
Ricky
Old 08-15-2013, 03:04 PM   #19
richinny's Avatar
2011 34' Classic
nor does that one.
i'll guess it to be 5' in my trailer.
Ricky
Old 08-15-2013, 03:05 PM   #20
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
It's a little more than double that on my Interstate. I believe the 18-inch requirement is for the distance from an installed generator to the panel board, not for a shore power connection. My genset's outlet is less than 18 inches from the panel board, but my shore power inlet is farther.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-15-2013, 04:19 PM   #21
HowieE's Avatar
Princeton , New Jersey
Images: 12
We are talking about 2 completely different things. Marine requirements have different considerations, water.
There should be no limit on the distance from the point of entry to the trailer to the breaker box. That wire is sized and protected by the fuses or breakers in the box of the campground.
Now from a practical point of view the breaker panel wants to be in the area of entry just because of the cost of the cable versus the cost of the wiring, small gauge, used within the trailer
2004 Excursion 4x4
Newbie Electrical Question Stonew98 Batteries, Univolts, Converters & Inverters 4 12-13-2011 11:42 AM
Newbie Electrical Question Stonew98 Batteries, Univolts, Converters & Inverters 11 12-04-2011 06:00 AM
Electrical Question TikiPatrick Vintage Kin 7 08-27-2011 08:48 PM
Steel / Aluminum wheel question polarlyse Wheels, Hubs & Bearings 12 05-29-2011 07:49 PM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
