Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 03-04-2006, 05:17 PM   #1
dsmith
Profile:  victoria , british columbia
electrical question
im a new airstream owner have a 22ccd 2005 and i am having some problems can someone tell me if it is normal to have a 12.75 voltage reading on one of the 7 pin trailer connection.
david
dsmith is offline   Reply With Quote
Old 03-04-2006, 05:33 PM   #2
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
Yes and No. Look at the picture I posted in this thread: http://www.airforums.com/forum...ing-18941.html
One line (#4) is called 12 volts. On my truck that line is only active when the key is on. This line goes to the trailer battery, by controlling it with the ignition switch it keeps the trailer from draining the truck battery when you are parked.
Richard
Charter Member Four Corners Unit
Old 03-04-2006, 05:35 PM   #3
driftwood
Remember Burma Shave!
driftwood's Avatar
Profile:  1985 25' Sovereign
1965 22' Safari
Excursion V-10 , S.Florida
Images: 35
Rivet Center Pin
You are probably reading your battery in the charged state. No current flowing in. See attached for a possible lead to explain yours. On your vehicle, with engine running, the charging terminal will probably show 13.7 (+-), sometimes more.
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 03-04-2006, 05:47 PM   #4
azflycaster
Phoenix , Arizona
Images: 58
Originally Posted by driftwood
If it is the center pin, then it is reading your battery in the charged state. No current flowing in. See attached. On your vehicle, with engine running, it will probably show 13.7 (+-), sometimes more.
My center pin (#7) is for the backup lights and is normally 0 volts.
Richard
Old 03-04-2006, 05:51 PM   #5
driftwood
driftwood's Avatar
1965 22' Safari
Images: 35
Wink Whoops!
There ... I fixed it!
NORM #3305
Old 03-04-2006, 05:54 PM   #6
Mike Lewis
Profile:  2006 30' Classic
Farmington , New Mexico
Images: 14
david
If you're talking about the plug connector thats on the trailer pigtail the answer is yes. One pin is connected to the battery of the trailer. When plugged to the tow vehicle this is how the trailer battery recieves it charge from the tow vehicle while traveling.------Pieman
Mike Lewis is offline   Reply With Quote
Old 03-04-2006, 05:59 PM   #7
azflycaster
Phoenix , Arizona
Images: 58
Norm,
I just noticed your mention of the Burma Shave signs. Here in Arizona they use signs like those to warn people about the Elk. Here is one example.....
I saw an Elk
Oh what a thrill
until I smashed it
on my grill
Richard
Old 03-04-2006, 06:09 PM   #8
dsmith
electrical problem
yes i meant the trailer plug the, reason i asked because when i turn off my car and the trailer is plugged in, the instrument panel lights in the car will not shut off and the rear wiper operates for about 1min, when i remove the plug all is well if i then re-insert the plug with the car switched off again all is well the problem only happens when i switch of the engine and leave the plug in, if i disconnect the trailer battery -all is well - therefore power must somehow be coming into the car from the battery, i checked the plug and the plug from the airstream ,one is always 12.75
thanks
david
Old 03-04-2006, 06:12 PM   #9
azflycaster
Phoenix , Arizona
Images: 58
Did you TV come with a factory installed tow package?
Richard
Old 03-04-2006, 06:17 PM   #10
dsmith
electrical problem
yes it came with a towing package, i just dont know if i should blame the trailer or the suv.
david
Old 03-04-2006, 06:30 PM   #11
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
David,
Sounds like you are getting some sort of feed back in your TV that is causing your 12V+ trailer recepticle power to get into other TV circuits. Does your TV have a battery isolator/serarator installed? It would also be a good idea to wire your 12V+ power lead thru a relay connected to an ignition switch controlled circuit. This will give your T/T power only when your TV ignition is switched on.
As far as blame......try the vehicle manufacturer for a start. Have them verify and tell you where and how that 12V+ gets its' power and where the connection is.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 03-04-2006, 06:37 PM   #12
dsmith
electrical problem
im afraid i carnt answer your questions the airstream is a 2005 ccd 22ft so i dont know what it has i would imagine that at least it should come with the right equipment. so you are saying that it is normal to have a voltage on the trailer connector, it is on the black pos wire.
david
Old 03-04-2006, 06:50 PM   #13
azflycaster
Phoenix , Arizona
Images: 58
The black wire connects to the trailer battery and is present on my older unit. I don't know if the newer units isolate this from the TV. When I shut the engine off on my Toyota that line then isolated from the TV, most likely by a relay. If the only line you have power on is the 12 volt line (#4), I would talk to my car dealership about the problem.
Richard
Old 03-04-2006, 07:10 PM   #14
dsmith
electrical problem
pardon mt ignorance but what is TV it is my airstream which has the plug on it which is alive and is feeding my landcruiserm the powerm if there should be power there .that is one thing if there shouldent be power there then it is the airstream
david
Electrical problem--99 safari Andrew Carey Electrical - Systems, Generators, Batteries & Solar 2 11-16-2002 02:04 PM
Wiring for electrical horn on 310 shelocta Airstream Motorhome Forums 3 09-03-2002 09:40 PM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
Propane and Electrical Line Protection Tamara Electrical - Systems, Generators, Batteries & Solar 7 06-27-2002 09:42 PM
Electrical System Question 1985air345 Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 07:39 PM
