Old 02-26-2013, 05:36 PM   #1
1985 31' Excella
Birmingham , Alabama
Electrical Question?
Can I use my 30 amp shore power in order to use the 110 outlets to do work in our '85 Excella with the battery out and the converter out? With all the rain and cold I would rather not use an extension cord thru the door or window unless I have no other choice. Definitely do not want to fry anything.
Tartimisi is offline   Reply With Quote
Old 02-26-2013, 06:17 PM   #2
1986 31' Sovereign
Miami , Florida
Can't imagine any reason why you couldn't. You will need a good 115vac work light but other than that...
Mike
n2916s is online now   Reply With Quote
Old 02-26-2013, 06:29 PM   #3
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
The 110 Outlets are fed by power cables direct from circuit breaker box, and not through the power supply, so they should be OK.. As Mike noted, ALL of the interior lights run of 12V, so you won't have any lighting beyond what you bring with you, but should be solvable problem...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 02-26-2013, 06:33 PM   #4
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Yes, delfinitely.
Old 02-26-2013, 07:50 PM   #5
Maniacal Engineer
barts's Avatar
Menlo Park , California
This works fine - I did exactly this when replacing our converter.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
