Old 10-09-2003, 06:18 PM   #1
electrical problems
on my 72 a/s does anyone know how inverter works ? has a switch(like light switch in home)hooked to inverter ,can't tell it does anything wont run trailer when 110 hooked up(without battery) and batt. will run down after about 6 hrs.with it turned on or off .i suppose it's on you can hear a buzz, don't know if it came on origional or not. airstream univolt-antomatic batt. charger and power supply-modle t4-345a. any info would be appreciated.
ronnieb is offline   Reply With Quote
Old 10-09-2003, 06:43 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Univolt was the orignal and they have a problem of overcharging the battery and many owners put in a disconnect switch and that sounds like what has happend to yours.
The univolt will hum when it is working. The house type switch is most likely a 15 amp switch the univolt is capable of 45 amps.
I would jumper around the switch to verify the univolt is good or bad. Just make sure you do not have AC pluged in when you jumper around the switch.
Garry
Old 10-09-2003, 06:46 PM   #3
ronnieb
well as you would guess--seems other people have same problem ,should have looked at board .will take univolt out tomorrow if i can figure out how didn't look like a easy job ronnie
Old 10-09-2003, 07:10 PM   #4
71tradewind's Avatar
Ronnie I have done this a few times ,here is a link to what I found to be the problem on 3 of my Univolts http://www.airforums.com/forum...common+problem
I hope this helps Tom
71tradewind is offline   Reply With Quote
Old 10-18-2003, 07:20 AM   #5
thanks everyone ,recived manuals yesterday, found out lots of things i didn't know .,also took out univolt and sure -nuff 2 of the caps. was bad ,now the worse part the caps are 48.99 each (witch won't be bad price to fix) but cheaper is better anyone know another sorce for the caps? went to moltry ga this week for farm show had a great time lots of a/s there (i'm never planning on driving the grayhound again) . ronnie
Old 11-12-2003, 07:33 PM   #6
univolt
thanks again everyone who answered post.fixed univolt today, found caps (ALL THREE)FOR LESS THAN $50 AT ELECT. MOTOR REWINDING BUISNESS. UNIVOLT WORKS FINE NOW. RONNIE
Marker light electrical sealer? TomW Electrical - Systems, Generators, Batteries & Solar 2 01-26-2004 07:22 AM
Electrical Nightmare Repodog Electrical - Systems, Generators, Batteries & Solar 6 11-05-2003 04:53 PM
electrical problems kent osborn 1966 - 1968 Safari 3 09-30-2003 07:18 PM
Electrical Problems Bob Baker Electrical - Systems, Generators, Batteries & Solar 4 06-20-2003 11:31 PM
Electrical problems... DbackFan Electrical - Systems, Generators, Batteries & Solar 9 02-13-2003 10:44 PM
