Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Prev Previous Post   Next Post Next
Old 08-12-2002, 12:46 PM   #1
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Electrical problem resolved
I think that with the help of forum members I have resolved my 110 v. electrical problem. I believe it started with a 30 amp plug which had loose blades and they somehow were arching inside the head of the plug. This was what was tripping the GFI system at the campground. One of the individuals helping me was an electrician parked in the next site. While diagnosing the problem, I believe he hooked a jumper wire from the ground bar to the neutral bar in the circuit breaker box, an acceptable practice for a nonGFI circuit according to several sources on the forum. No matter what we did after that, it would trip the GFI breaker at the campground box. Once I got home, a new plug was put on but I believe I checked it on a nonGFI circuit at the house because there was no problem when I tested it. When I checked it the other week, it was kicking the GFI at the garage breaker box. Since there was no reference in the service manual regarding the jumper wire, I removed it. That solved my problem. I have checked continuity on all wires and there is no crossing over. I have to isolate the ground bar to check it but it looks like everything is OK (I hope). Every plug and every system in the trailer has been checked with a meter and an instrument that verifies whether there is an open, fault, etc. and everything checks out. AC even checked out for a quick run of one minute.
Thanks for the help.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Strange Electrical Problem DaveJ Electrical - Systems, Generators, Batteries & Solar 5 11-11-2003 01:00 PM
electrical problem kent osborn 1966 - 1968 Safari 3 09-27-2003 06:30 AM
AC electrical problem lbf78SvgnInt31 Electrical - Systems, Generators, Batteries & Solar 2 07-26-2003 07:44 PM
HELP! Electrical problem FranceyS Electrical - Systems, Generators, Batteries & Solar 4 11-11-2002 06:27 PM
electrical problem ALANSD Mechanics Corner - Engines, Transmission & More... 22 08-22-2002 10:47 PM
