Old 08-28-2011, 05:33 AM   #15
Crossville , Tennessee
Hi
We couldn't get it to come on at all no matter how long we waited and we turned it down to 59
Then we turn the light on, at first we were doing it on the light itself then we stareted to use the wall switch. We waited a minute once we turned the light on and then the AC came on and if you turned the light off while the AC was running it would knock the AC out and it would NOT come back on with out that light on. We also noticed when we switched the light on if the fantastic fan was running and you switch it on it would bog down for a second or two
We can't get it back into service until October
Thanks for your suggestions.
starshipcruz is offline   Reply With Quote
Old 08-28-2011, 06:55 AM   #16
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by starshipcruz View Post
Hi
Starship,
Now that description sure sounds like the thermostat 12v is wired to that wall switch.....will the AC run with the wall switch on and the light off at the fixture?
It's not likely, but it could be factory, any mention in the manual or during your orientation? Anyone else here have the same concern?
Easy solution...control the light with the fixture switch and keep the wall switch on when using the AC.
POI...the AC draws a lot of power on start-up so the FF slow-down is not unusual.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
12 volt
Potential Problem? Pictures included palmtreegirl 1990 - 1993 Excella 51 08-12-2013 10:50 PM
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
Having and electrical problem with TV maybe toastie Batteries, Univolts, Converters & Inverters 4 07-30-2011 12:06 PM
1960 Electrical 110V & 12V question Lothlorian Electrical - Systems, Generators, Batteries & Solar 19 05-08-2011 11:58 PM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
