On my l961 Overlander I can get no
12 volt lights to work, all lights and recepticals work on 120 V.
I have 2 reds and a green leads in the btry box with inline fuses, I can not find any other box of any kind in the trailer except the breaker box for the 120 volt system. I have a on/off switch over the sink that I think goes to the pump, it has a line in the box the same color as the line going to the pump. I removed the furnace from the trailer and cut the wires from it, it had 2 wires for 120V and 2 wires for
12V and 2 wires to the thermistat. the 2-120V are hot. I can get nothing from the
12V. one
12V wire is a ground going to the trailer wheel well. the other the same color as the one at the pump, I hooked a 12V light bulb between the two, no light and nothing from the switch over the sink. I disconnected the 120V from the trailer thinking this may be the reason, no luck. I've read the other forum problems such as this, seems there is a box or breakers that I can't find for this 12V system.
I have to light sockets at each light fixture, 1-120V and a 12V I would think. I am using 12V bulbs to check the 12V system. Can someone please give me a starting place to work with this problem. I can not find a 12V hot wire anywhere in the system other than after the inline breakers going into the wall.
Someone please tell me something. I need help....Thanks...Dave...
