Old 09-05-2011, 10:51 AM   #1
2004 19' Bambi
Johnston , Iowa
Electrical problem..
Took our trailer out for the 2nd time this weekend. 19ft 2006 Bambi. Everything worked fine Friday night, Sat morning the outlet above the dinette on th sink/stove side did no work and the outlet on the outside by the door did not work. Later in the day we noticed the light above the toilet stopped working. I have looked at the fuses and all seem to be fine, all other outlets/lights work. Would these 3 items all be on the same fuse? Seems odd since at opposite sides of the trailer
tmsprout is offline   Reply With Quote
Old 09-05-2011, 11:02 AM   #2
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
I'll bet these are all on the GFI. You need to switch the breaker totally to the off position and then back up to on. It will NOT reset if you just move it from the middle position to the top position...you must go to full off then up to the top position.
SilverCottage is offline   Reply With Quote
Old 09-05-2011, 02:38 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Ditto...on the outlet above the vanity and the one outside the door...this has happened to us...
On the bathroom light...make sure it is not turned off at the fixture...if it is, it will not come on when you hit the switch for the vanity/bathroom lights.
TB & Greg and Abbey Schnauzer
#3954
Old 09-05-2011, 07:08 PM   #4
2004 19' Bambi
Johnston , Iowa
Just got home from our long weekend and just read your posts. That may be the problem, since I posted originally I found that the GFI breaker was off but would not take. Did not completely turn off then turn on though, thought that the breaker was bad. Will try tomorrow and get back to you, too damn tired to start messing with it.
Thanks for your responses!
Potential Problem? Pictures included palmtreegirl 1990 - 1993 Excella 51 08-12-2013 10:50 PM
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
Electrical problem AC related to 12 volt? starshipcruz Electrical - Systems, Generators, Batteries & Solar 15 08-28-2011 06:55 AM
Having and electrical problem with TV maybe toastie Batteries, Univolts, Converters & Inverters 4 07-30-2011 12:06 PM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
