Old 08-12-2003, 07:33 AM   #1
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
electrical problem
Last night it rained for the first time in weeks, and now the 12 volt interior lights & water pump on the street side of my 1973 Argosy won't work. Any idea's!!
Gunnyusmc is offline   Reply With Quote
Old 08-12-2003, 07:39 AM   #2
FireFighter's Avatar
bay city , Michigan
there is a fuse panel somewhere it is in the bathroom for me. inside of one of the cabinets, i would check here first, also i might wonder if wires are getting we what else is.
FireFighter is offline   Reply With Quote
Old 08-12-2003, 08:00 AM   #3
jaiman's Avatar
Images: 32
Are you saying that some of your 12 volt lights are still working? Odds are it is a fuse. Dont overlook the large main fuses on your inverter either. Perhaps your batteries are low because the inverter is not working either.
jaiman is offline   Reply With Quote
Old 08-12-2003, 08:05 AM   #4
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Fuses
it was a loose fuse!! Thanks to all.
Old 08-12-2003, 09:19 AM   #5
mkeith54's Avatar
1976 26' Argosy 26
New Florence , Missouri
Send a message via AIM to mkeith54 Send a message via Yahoo to mkeith54
Fuses
Hey Gunny,
It could have been corrosion in the fuse clips as well. There is a product called Deoxit that is a spray that removes the corossion and applies a protective film to the contacts and fuse. I also use it on the 7 way connector and light bulb outlets. I use 5% CAIG DEOXIT DN5 5.5 OZ CAN SPRAY available here http://mcm.newark.com/NewarkWebComme...0&QText=deoxit also www.newark.com carries it as well. It is a tad pricey but it really works.
Mike Keith
75 Argosy 26'
96 Ford F-250 PowerStroke
mkeith54 is offline   Reply With Quote
Old 08-13-2003, 07:26 AM   #6
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Spray
Thanks Mike, I'll get a can.
electrical problem ALANSD Mechanics Corner - Engines, Transmission & More... 23 09-13-2015 07:20 PM
HELP! Electrical problem FranceyS Electrical - Systems, Generators, Batteries & Solar 6 08-03-2010 02:57 PM
electrical problem kent osborn 1966 - 1968 Safari 3 09-27-2003 05:30 AM
AC electrical problem lbf78SvgnInt31 Electrical - Systems, Generators, Batteries & Solar 2 07-26-2003 06:44 PM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
