Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 08-27-2009, 07:33 PM   #1
Profile:  Currently Looking...
epping , New Hampshire
Electrical problem
87 345 No shore power after running Gen.
Located two relays, one under bed nad the other under seat. Now what?
sailsman1 is offline   Reply With Quote
Old 08-28-2009, 02:09 AM   #2
87MH's Avatar
Profile:  1978 31' Sovereign
Katy , West Planet Houston, Texas
Images: 231
If I were you I would get a voltmeter and start checking for voltage inward from the shore power plug in.
Did you check the breaker box? It's located in the rear streetside overhead. First easiest place to check for voltage.
Problem could be in the shore power plug or in the reel connection - both have been known to fail.
The relay under the bed switches the load from the genny to the external power.
The relay under the couch switches (controls) the power going to the front AC. Power for the front AC (or is it the rear?) comes from the selector switch above the sink overhead OR from the "second leg" of the genny.
Welcome to the Forums - lots and lots of systems questions and answers in the Motorhome section. Best to use the Forum "google" search (under the "search" pulldown) when searching specific questions.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Electrical problem-Help! mimiandrews Batteries, Univolts, Converters & Inverters 6 07-26-2009 09:25 PM
Electrical Problem QuietWater Airstream Motorhome Forums 11 06-22-2009 12:06 AM
greetings and electrical problem wdm1 Member Introductions 2 12-18-2006 03:02 PM
Electrical Problem NASCAR345 Airstream Motorhome Forums 15 03-13-2003 07:23 PM
HELP! Electrical problem FranceyS Electrical - Systems, Generators, Batteries & Solar 4 11-11-2002 06:27 PM
