Old 12-02-2018, 06:09 PM   #1
Al Zeppelin's Avatar
1949 22' Liner
St Petersburg , FL
Electrical Panel Placement Question
I'll be building a platform bed in the rear with a lift up access door for storage. My question is can I put the panel under the bed? Any cons to doing this installation? I don't want to look at the plastic access door on the electrical panel if I can avoid that. Thank you in advance for any response.
Al Zeppelin is offline   Reply With Quote
Old 12-02-2018, 06:26 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
How is the lift up access door held up when you need access to the panel?
Old 12-02-2018, 06:29 PM   #3
1949 22' Liner
St Petersburg , FL
Panel
I'll be installing struts like the one's that hold up a cover on a truck lid or an old hatchback car tailgate, also common on a class A master bed. Should be at least a 4' x 4' access.
Old 12-02-2018, 08:02 PM   #4
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
Not sure if there are any codes to follow for RVís. However common sense dictates, as long as you can get at it easily if needed and any wires leading to it will not be damaged by any storage items that may hit them.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 12-02-2018, 08:04 PM   #5
1949 22' Liner
St Petersburg , FL
That is what I figured. Just needed some assurance.
Old 12-02-2018, 08:14 PM   #6
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
maybe
Really depends on the layout.
I had one like that in a motor home it was a real pain the few times I had to go into the breaker box working on my knees with little overhead room.
Garry
Old 12-02-2018, 08:28 PM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I've had Airstreams that the electric distribution panel was inside the closet (1970's), inside the overhead cabinet above the bed (1999) and behind a wood panel Velcro mounted on the face of the cabinet (2000). All were accessible with little effort.
I do not see why under the bed would not work, but I don't know anything about RVIA standards.
The location has to be easy to get to at a moments notice. A protective cover is needed for the breakers, so they don't get switched on and off accidentally. And really important; the wires that connect to the panel have to be inside a chase, protected from accidental damage.
ps: I'm assuming you are talking about a 120v.
Alan
Old 12-02-2018, 08:32 PM   #8
1949 22' Liner
St Petersburg , FL
Conduit
I was planning on running the "home runs" through flex conduit. Yes 120v sir.
Old 12-02-2018, 08:41 PM   #9
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Are you planning to run the bed front to rear or side to side?
I remember another trailer that had the electric panel and a junction box inside the nightstand beside the bed.
Alan
Old 12-02-2018, 08:47 PM   #10
1949 22' Liner
St Petersburg , FL
Layout
This will be side to side. I've framed up cabinetry on the left and the bathroom on the right both ending at the same "depth" towards the back. The back end will be a raised bed. I'll make a template after the platform is built and will get a queen sized memory foam mattress and will cut it to fit. This is a '49 so I don't have a heck of a lot of room to play with.
Old 12-02-2018, 09:51 PM   #11
1971 27' Overlander
Kansas City , Kansas
As per NEC 551
Shermy1987 is offline   Reply With Quote
Old 12-03-2018, 02:54 AM   #12
2016 30' International
redondo beach , California
Scary idea creeps me out!
How about a better looking door.
Randy and Beth
2015 F250 Titan 50 gallon
2016 30' International ProPride, EasyStart, Michelin 16", 400AH LiFePO4, Victron BMV 712, Orion DC/DC converter, BlueSolar MPPT 100/30, Victron 12|1200 inverter, 300W solar mix, Alpine iLX, Polk MM1, Samsung 42, one small air plant
mythbuster88 is offline   Reply With Quote
Old 12-03-2018, 08:33 AM   #13
1967 26' Overlander
Bugtussle , Oklahoma
If your distribution panel has a built in power inverter, then you need to make sure that you allow for the necessary air flow for cooling.
1967 Overlander International 26ft
2006 Porsche Cayenne Turbo S 520hp 530ft-lbs torque 7700lb towing capacity
mikextr is offline   Reply With Quote
Old 12-03-2018, 09:09 AM   #14
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
<<snip>> the plastic access door on the electrical panel <<snip>>
I did not pay attention to this part of your post.
Mikextr is correct. When I posted I was thinking about a SquareD QO 6 space breaker panel that Airstream has used for 30+ years.
Shermy1987's post of the NEC article jogged my brain!
I was wrong in my prior post, when I said "I do not see why under the bed would not work"! I do see a problem, if the storage area beneath the bed was full of stuff it would prevent quick access. It is not a good idea.
I'll offer a suggestion for an alternate location:
Inside the cabinet beside the bed, the distribution panel could be mounted just above floor level, with a removable shelve above. This would create the enclosure to protect the components and wires. If there is a door on the cabinet, the face of the distribution panel needs to be within 2" of the aisle, per NEC. The bedside aisle can provide the required access distances. The enclosure can be vented into the storage area beneath the bed and/or an opening made in the cabinet into the living space.
Alan
Solar Panel Placement The Colonel Generators & Solar Power 5 02-24-2018 06:42 AM
Technique for Optimizing Solar Panel placement Mattirs Generators & Solar Power 6 04-11-2017 04:40 PM
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 08:24 PM
Smoke detector placement question Skamper1 General Interior Topics 11 11-14-2010 09:02 AM
Question on interior wall placement? cloud55 General Interior Topics 3 03-03-2006 10:11 AM
