Old 09-21-2008, 03:27 PM   #1
on the hunt
osolow's Avatar
riverton , Kansas
Send a message via Skype™ to osolow
Question electrical outlet problem?
OK i am hopping someone can help me out i removed the front panels in my A/S to fix a dent and some floor rot.
well aim going back together and cant remember how my two electrical outlets on the sides go back together there are two holes in the panel on the direct top and bottom. but the mounting screws for the outlet face are off center. i thought that it had some sort of bracket that held them in from the back side, but i cant seem to find anything in my parts that i removed.
any suggestions?
osolow is offline   Reply With Quote
Old 09-21-2008, 03:57 PM   #2
soldiermedic's Avatar
Florissant , USA
D,
Post pictures...It is bound to help.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 09-21-2008, 04:21 PM   #3
on the hunt
osolow's Avatar
riverton , Kansas
alright i will go get some
and post them back later
Old 09-21-2008, 04:21 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are talking about the plastic boxes for the 110 receptacles you should find 2 small plastic wings that fold out of the side of the box as you tighten the screws at the top and bottom. Make sure the screws are far enough back out that they will allow the wings to swing out and clear the back side of the wall as you tighten the screws. Once the wings go out they will hold the box in place.
If this is not what you are asking about yes a picture would help.
2004 Excursion 4x4
Old 09-21-2008, 05:08 PM   #5
on the hunt
osolow's Avatar
riverton , Kansas
plastic wings are correct
HowieE
you are correct while i was out taking pic's i found one on the ground. how it got there and i miss placed the other three is beyond me.
i tryed (anyway) to put all screws and brakets in in ziplock bags and marked what they were. trying to keep this from happening, hopfully lowes will have what aim looking for.
Name:	airstream teardown 010.jpg
Old 09-22-2008, 06:55 AM   #6
HowieE's Avatar
Images: 12
You should be able to use the 4 you have.
If the one wing is too loose on the screw just slip a sliver of a match stick in along side of the screw to tighten things up. As long as you don't do chin ups on the cords as you pull them out of the socket that will work.
2004 Excursion 4x4
Old 09-23-2008, 11:43 AM   #7
Dan@LED4RV's Avatar
Denton , North Carolina
pictures
Originally Posted by osolow View Post
HowieE
taking pic's
Osolow
There is a little flower icon on your camera, or should be. That is for close-up pictures and may help you pictures turn out sharper.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 09-23-2008, 04:45 PM   #8
on the hunt
osolow's Avatar
riverton , Kansas
thanks for the info, i bought that camra a year or two ago and i still havent figured it all out but every once in a while i take a nice pic.
on the wings i found one more i will have to go to lowes and hopfully they will have a couple more for me. if not i will go out to colaw and see if they have them.
Help With Faulty Electrical Outlet GStephens Electrical - Systems, Generators, Batteries & Solar 9 09-29-2008 10:29 PM
Electrical problem - 1965 Dr JJ 1965 - 1969 Globetrotter 3 06-17-2008 12:13 PM
Electrical outlet on 27FB gowyn 2007 Safari 4 12-16-2007 01:39 PM
Exterior electrical outlet cover airstream4 Exterior Restoration Forum 1 12-05-2004 01:37 PM
electrical problem Gunnyusmc Electrical - Systems, Generators, Batteries & Solar 5 08-13-2003 07:26 AM
