Old 05-25-2014, 05:06 PM   #1
SLO , California
Electrical out in back half of Airstream
I have a 1980 excella and the power to the back half of the trailer has gone out.
All was working fine until recently. There was a blow dryer plugged in to a 110 outlet that I think was the culprit.
12v lights and plugs in the back half have stopped working. I tried flipping the breaker but that didn't solve the problem.
Could it be a blown fuse?
gitrokr is offline   Reply With Quote
Old 05-25-2014, 05:22 PM   #2
SLO , California
Replaced a couple broken fuses, but that didn't solve the problem. 12 volt lighting and outlets in the rear half are still out.
Old 05-25-2014, 05:47 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I don't think the blow dryer could have affected the 12 volt system in most reasonable circumstances.
Look those 12 volt fuses over again. A test light is better than a visual.
Old 05-25-2014, 05:48 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Electrical out in back half of airstream
I reread you original post;; questions,
The 120 AND 12 volt are out in the rear half?
Was there a burnt smell when the blow dryer was used?
Old 05-25-2014, 05:53 PM   #5
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
The only way I can think that the use of the blow dryer would cause the 12v to go down is if a 120 wire burned and as a secondary effect burned a 12v wire that was very close or touching.
This would not be a typical occurrence but possible.
120 wires seldom burn in the middle of a run, usually this happens in the jct box .
Old 05-25-2014, 08:18 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If the circuit for the blow drier is the same as the one for the converter, then the 12 volts will be out if your battery is low. Check the large fuse from the battery. There may me one on the negative side.
When resetting circuit breakers you must flip them to the off position, then to the on position:
Half my Electrical is Down - Help Cmonster77 Electrical - Systems, Generators, Batteries & Solar 7 07-07-2014 03:00 PM
repairing back half of a '75 Tradewind CMSmith General Interior Topics 13 06-17-2012 05:15 PM
Interior power out in half of argosy. Cognito Electrical - Systems, Generators, Batteries & Solar 2 09-25-2011 11:49 AM
2005 AIRSTREAM 28' INTERNATIONAL Low Miles HALF PRICE eBay Watch Airstreams on eBay 0 05-02-2009 05:10 AM
2005 AIRSTREAM 28ft INTERNATIONAL Low Miles HALF PRICE eBay Watch Airstreams on eBay 0 04-23-2009 10:40 PM
