Old 08-06-2008, 04:27 PM   #1
1966 17' Caravel
Silverton , Oregon
Electrical mysteries
I'm working on a 66 Caravel and have a couple of question (as will become clear, I am NOT an electrician!). With help from this forum and elsewhere I will be upgrading to an Intellipower converter. As I start into the electrical system, a couple of questions: There are two detached dead end "romex" type wires in the clost near the 110 breaker panel. I found one dead end romex in the area behind the furnace when I removed the appliances, etc. (which I assume is the other end of one of the mystery wires) From other posts I've read here I get the impression maybe the factory put in extra unused wiring during assembly just in case they were needed in the future. Any confirmation of that--or other thoughts/ideas on this? I want to replace the original gas only refrig. with a gas/electric, so I'm hoping maybe the dead ended wire I found behind the furnace can be used for the refrig.
Also, above the sink there is a duplex outlet and a "light switch". From other photos of Caravels, looks like that's standard. I have not checked, but assume the outlet is a 110, for whatever kitchen appliance (toaster, etc.) I have no idea what the switch is for. Anyone?
Finally, there is a shroud and vent and terminated wiring above the stove that obviously was for an exhaust fan that appears to have been operated by a pull chain. Fan and motor are missing. Has anyone dealt with this, i.e., are replacements or after-market substitutes available that will work?
Thanks in advance for any and all help.
Mark
mrauch is offline   Reply With Quote
Old 08-06-2008, 04:31 PM   #2
Mark
Call me tomorrow after about 8am, and I will help you.
800-8777311.
Old 08-06-2008, 06:37 PM   #3
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Hope this is of some help. It is very basic but it's a start. You need photos of an existing 66 Caravel - let me know and I can go out and take some. Mine is 99% original.
Mike
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
New electrical need help BB 55 Bubble Batteries, Univolts, Converters & Inverters 9 10-14-2007 09:57 PM
GVWR Mysteries ljmiii Axles 7 05-21-2007 03:28 PM
Electrical all over again Melody Ranch Electrical - Systems, Generators, Batteries & Solar 6 04-17-2006 10:34 PM
electrical kent osborn 1966 - 1968 Safari 13 05-08-2005 08:09 AM
electrical help. poorboycjs Electrical - Systems, Generators, Batteries & Solar 1 09-16-2003 08:53 PM
