Old 08-04-2014, 10:22 AM   #1
1975 31' Sovereign
electrical issues > Tow Vehicle pin out not matching Trailer receptacle
We recently purchased a 75 Sovereign in really good shape.
When we went to tow for the first time, we hooked up our 2010 Nissan Armada to the Airstream with the provided wire harness (from rear bumper compartment), the tail lights didn't work. I replaced the bulbs with brand new ones and it still didn't work.
I'm thinking the pin outs from the Armada aren't matching the pin out on the Airstream.
Can anyone lead me in the right direction and tell me if i'm on the right track?
Some threads that I found indicated that the standard back then was different and that the receptacle needs to be removed (or replaced) and so that the wiring pinouts match the newer tow vehicle receptacle pinouts.
Thanks in advance,
Tadd in Austin, TX
taddilack is offline   Reply With Quote
Old 08-04-2014, 10:36 AM   #2
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
Use a 12v tester and map the TVs 7-pin output. Then you can buy a new umbilical, or rewire the one you have.
arktos55343 is offline   Reply With Quote
Old 08-04-2014, 10:36 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Post a pic of your trailer connector.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-04-2014, 11:21 AM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Chances are good you will need to rewire the trailer plug to match your TV. The color codes and pin outs were different back then.
You will need 6 of the 7 pins (without backup lights) to make everything work.
Tail/marker lights
Left turn/brake
Right turn/brake
Common/ground
Charge line
Electric brakes
Go to etrailer.com
They have pics of the pin out.
Good Luck
Matching Polished Tow Vehicle Sneakinup On The Road... 5 11-04-2013 06:29 AM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 07:09 PM
Electrical Help - Splitting a receptacle COArgosy78 Electrical - Systems, Generators, Batteries & Solar 4 07-03-2005 03:57 PM
Electrical receptacle in storage compartment Kistler Our Community 4 06-27-2003 07:18 PM
Matching Airstream & Tow Vehicle elpasodon Our Community 10 03-11-2003 07:57 PM
