02-19-2018, 08:50 PM
2011 27 FB International
Tucson
Electrical Gurus - 50 to 30 amp dog bones
I have a 50 amp pedestal on my property and when other ASers visit I use a 50 to 30 dog bone.
If I need to remain hooked, or if I have two needy visitors at once, I'm wondering how dangerous, fatal, hair-brained (or what ever term suits your fancy) the following idea is:
The standard 50A pedestal is wired Ground, Hot "A," Common, Hot "B." If I create a "double dog bone" by wiring two 30 A females into one 50 A male, how much trouble am I looking at? I'm looking at Circuit "A" using "Hot A," shared common and shared Ground; and Circuit "B" using "Hot B," shared common and shared ground, realizing that "A" and "B" are 180 degrees out-of-phase. Similar to this:
https://www.amazon.com/Epicord-Adapt...ogbone+adapter
Why won't this work, bearing in mind I don't want to make crispy critters out of my friends?
Your views are appreciated.
02-20-2018, 07:11 AM
1974 Argosy 26
Morrill
, Nebraska
Looks like the female ends are 20 amp.
It would be difficult to run AC's. Other than that, it should work.
02-20-2018, 07:28 AM
2002 25' Safari
Dewey
This is what you want.
https://www.amazon.com/dp/B073WB5LBY...a-350338554146
We used 100+ of these at the Escanaba International Rally last year. Running AC was not a problem.
Richard
02-20-2018, 07:44 AM
Green Cove Springs
Originally Posted by azflycaster
Yep, use to carry one of these on my boat. I had two 30 amp inlets on the boat and used one of these to tap the 50 amp outlet at the marina. Worked like a champ for years.
Breathe In, Breathe Out, Move On
02-20-2018, 07:48 AM
2002 30' Classic S/O
Fleming Island
In essence, that is what happens inside a trailer with 50A service, as long as it doesn't have 240V loads like a home stove or clothes dryer. It should work just fine, but get 30A receptacles, or buy the one suggested by Azflycaster.
Al
02-20-2018, 09:47 AM
Tucson
That's perfect. I thought I had searched Amazon and only found the 20 amp version. That's why I was thinking of making one up. This is ready made and costs less than the components bought individually.
Thanks!
02-20-2018, 10:46 AM
1985 31' Excella
st. Paul
, mn
Bad math , the 1st link gave 2 x 15amp = 30 amp outlets from 1 - 50amp .
The second link 2 x 30amp = 60amp , from 1 x 50 - overloaded by 10 amps .
85 Excella , 31' , electric brakes , R. twin [ would like it to be a single ] , future upgrades , composting toilet [ replace black water tank with a 2nd fresh ] , solar power , instant hot water heater .
Tow 94 Dodge Ram , 4x4 , Cummins , AT .
02-20-2018, 11:05 AM
Fleming Island
Nope - Each leg of the 50 amp service is rated at 50 amps.
Al
02-20-2018, 11:59 AM
2019 25' Flying Cloud
Greeneville
, Tennessee
Yep
Right on!
02-20-2018, 06:07 PM
2004 25' International CCD
NEW ORLEANS
, Louisiana
Its done all the time, but you should be aware that you and/or your friends won't be properly protected electrically. You'll have a 50AMP breaker protecting a 30 Amp cable. Not really idea or to NEC code. If you swap out the 50Amp double pole breaker with a 30Amp double pole breaker it would be much safer (and meet code).
02-20-2018, 07:19 PM
2022 27' Globetrotter
Asheville
, North Carolina
Please read what dfbroussard said again.
The breaker exists to protect the wires. Not the equipment.
If you downsize the wires you need to downsize the breaker.
02-20-2018, 07:47 PM
2002 25' Safari
Dewey
You do have 50 amps available at the pedestal, but the mainline breaker at the trailer is 30 amp.
Richard
02-20-2018, 08:02 PM
1974 Argosy 26
Morrill
, Nebraska
There is no protection of wire between the pedestal and the panel inside the trailer.
The breaker in the trailer only protects what is downstream.
02-20-2018, 08:46 PM
1999 34' Excella
Hillsboro
the power is there... why not just add the two 30 amp receptacles? only don't use the 50 if using any 30?
Peace and Blessings..
Channing
WBCCI# 30676
02-20-2018, 08:57 PM
2007 22' International CCD
Corona
He may not have room in the box he has....
02-21-2018, 05:50 AM
Asheville
, North Carolina
Just for fun, check the size of the wire your pedestal was wired with. My RV panel has 50, 30 and 20 options. Could be they sized the wire for more and it’s just the panel that’s restricted.
02-21-2018, 07:57 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
A RV power panel with 50-30-20 outlets has at least 80 amp wire coming in as the potential maximum load could be 80 amps on one leg and 70 amps on the other.
The 50 amp socket is in reality a 240Vac socket. However, an Airstream treats it like there are two individual 120Vac 50 amp outlets. For convenience, say one is leg A and the other is Leg B. In the typical panel, the 30 amp incoming power would be on Leg A and the 20 amp power would be on Leg B.
Thus if one has maximum load of 50 amps on both lets A and B, then adding a 30 amp load to leg A means the wiring upstream is seeing 80 amp power draw. Leg B is seeing a 70 amp power draw.
Most parks may have these panels wired with 100 amp capacity wiring coming into the box to help with voltage drop over distance.
