Old 08-02-2014, 09:15 PM   #1
1975 Argosy 24
Guelph , Ontario
Electrical fire hazard?
So finally doing some work on our 75 Argosy. It has sat for several years in a field before we rescued it. The mice took it over during that time. I want to plug it in to see if the electrical works but my wife thinks it will catch fire. I plugged it in (she didn't talk to me for a few hours) and there was power. Flipped the switch and more lights came on but loud humming. Turned it off right after but is there a possibility of a fire if left on? Do I keep a fire extinguisher handy and see what happens lol? Could/would the mice chew wiring behind the walls?
Kelmac is offline   Reply With Quote
Old 08-02-2014, 09:20 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Maybe. But if the 12V fuses are in place and the correct amperage then doubtful. The circuit breakers will tend to protect the 120 V circuits.
The humming might well have been the converter, if loud, it might be going south.
Old 08-02-2014, 09:24 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Fwiw, I have a 72 and a 75 Airstream, both had a mouse problem, but neither had chewed wires, and in fact both stock electrical systems were in good shape.
Old 08-02-2014, 09:25 PM   #4
1975 Argosy 24
Guelph , Ontario
Good to know. Thanks
Old 08-02-2014, 09:31 PM   #5
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Another source of loud humming might be the air conditioner. If the compressor is faulty, and it was trying to kick on, it would hum loudly.
Old 08-02-2014, 09:35 PM   #6
1974 Argosy 20
Kooskia , Idaho
There is always a possibility of mouse wire damage, but as others have said, it is not very probable. Fuses on the 12 volt side and Circuit Breakers on the 120 volt side in general will protect against serious shorts and fires.
The humming you heard is most likely the old Univolt converter/charger (otherwise known as the buzz box). They make noise, and are something you will need to replace with a more modern unit, but don't catch fire.
Potential Fire Hazard + better safer lighting Hummer Lights - Interior & Exterior 0 12-22-2013 05:31 AM
Garmin recalls 1.25 million Nuvi GPS navigation devices for fire hazard Phoenix Computers, Internet & Satellite 3 08-29-2010 05:05 AM
FiRe, FiRe, FIRE, in the AiRsTrEaM!!!! TheBigRedTruck On The Road... 41 12-13-2008 10:29 PM
Airstream Dometic Refrigerators RECALL (FIRE HAZARD) bbop_96 Refrigerators 12 10-27-2008 10:42 PM
Fire Hazard Buttercup Electrical - Systems, Generators, Batteries & Solar 3 06-27-2005 03:03 PM
