Old 10-01-2003, 12:08 PM   #1
Electrical diagram
Does anyone kow where I can get a electrical diagram for my 1958 Globetrotter?
Additionally, there is a 12 V plug (female) on the passenger side front corner of the trailer. A small plate indicates that it's to plug the 12 V Tow Vehicle system into the trailer. This is round three prong (arched prongs) plug. Does any one know where I can get the female plug?
1958 Globetrotter is offline   Reply With Quote
Old 10-01-2003, 03:01 PM   #2
Images: 59
Electrical plug
I might have one. Depends on whether I saved it when I packed away everything for my reconstruction. I was planning to replace my 6 wire umbilical with a 7 wire (the extra wire was to be the 12V feed), so I may have thrown it out along with the socket. How soon do you need it? The stuff I packed away is at a remote site. Are you doing a restoration? If you just want a functional system, I would go with a 7 wire conversion and not have an extra plug and cord set to worry about.
markdoane is online now   Reply With Quote
Old 10-01-2003, 06:58 PM   #3
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
12 Volt Plug
Welcome 1958 Globetrotter - I have that same plug, as does Mark it seems. I found the inside wires have light blue insulation. Funny thing was, a PO put an in-line fuse from one blue wire to the other and back into the wall. This made no sense to me. One night I got gutsy and hooked one of the wires up to a 12 battery. Whalah...the overhead 12 volt lights came on; the one in the galley and the one in the bathroom. When I got my trailer, it didn't have any type of 12 volt system or any lingering evidence of ever having one. I never did figure where the other wire went. Any ideas? These lights were originally intended to get power from the tow vehicle.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 10-01-2003, 07:07 PM   #4
Images: 59
Further Electrical
The 12V wire goes to a double fuse block. One line is for the house power, and the other is a switched line for the water system air compressor. There is an additional in-line fuse between the wall switch and the compressor. I couldn't figure out why the second fuse, unless to protect the wall switch.
Old 10-01-2003, 07:57 PM   #5
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
My Trade Wind didn't have a 12 volt pump or any 12 volt lights with the exception of the two 4 inch round overhead fixtures. No other evidence of ever having a battery anywhere. All light switches are accounted for and operate a 110 volt light. I've not seen another trailer of this vintage that has a set-up like this. All of the others seem to have both 110 and 12 volt lights.
FF
PS: the ceiling now looks much better than in this photo.
Old 10-01-2003, 08:22 PM   #6
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Hehe You should see the way ours was wired. Had a current umbilical that is spliced into the the last 3 ft of the original umbilical just before it went into the body. At that junction was a peice of armorred cable running up to that plug for the 12v charge feed.
I'm replacing the whole umbilical again with the 12v feed from the umbilical making it's connection on the inside.
I do plan to retain that plug for a few reasons. I'll make a jumper so that if the tow rig is nosed up to the coach I can lift the hood and charge the battery. I can also use that jumper to charge off a Generator. You could also use that juntion to pull 12v from the coach to run something else. Maybe put a cig plug end on it to run 12v stuff like fan or a small compressor to fill kids blow up stuff.
Now where to find one: Hubbel(sp?) is a company that makes a lot of simular plugs. I bet they have one that size as well.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Need wiring diagram for a 1975 26 ft Argosy ... Hayseed Airstream Motorhome Forums 9 10-06-2006 10:17 AM
electrical diagram for a 1966 Ambassador 28 foot ups guy Electrical - Systems, Generators, Batteries & Solar 2 09-10-2004 04:24 PM
Marker light electrical sealer? TomW Electrical - Systems, Generators, Batteries & Solar 2 01-26-2004 07:22 AM
Wanted: Electrical Genius jthew1 Our Community 15 12-14-2003 08:35 AM
electrical system diagram duckrunner Electrical - Systems, Generators, Batteries & Solar 3 10-22-2003 07:53 PM
