Old 07-19-2012, 01:00 PM   #1
Jcashcollect's Avatar
1978 31' Excella 500
Kelowna , British Columbia
Electrical current felt through bellywrap skin
Hey guys
I was underneath my '74 International riveting my belly skin, when I noticed a slight electrical current when I touched the skin. The trailer was plugged into 110v at the time. Just wondering if this is just because the fuse box is grounded to the frame, or if I have to search for a wire touching somewhere? I haven't tried unplugging it from the 110v and seeing if I can feel it, but I doubt only 12v would make me feel anything.
TIA
Jcashcollect is offline   Reply With Quote
Old 07-19-2012, 01:11 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
This could be dangerous. There are several forum entries on the subject and what to do to chase the short down.
Old 07-19-2012, 01:52 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Look for a thread by purman. He had the same problem and we helped solve it. If you can't find it look for my handle and check the posts I have made in the last day or two. It will just save me time in re typing the whole thing.
Old 07-19-2012, 02:01 PM   #4
Thanks found the thread. Now to find the light.
Old 07-19-2012, 02:08 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The light is probably not your problem. Read what I wrote about the wiring not being correct. The light simply indicates there is a problem.
Old 07-19-2012, 02:12 PM   #6
HowieE's Avatar
Princeton , New Jersey
Images: 12
The first thing I would check is the source ground at the house and then at the trailer.If those are good I would open the110 panel and make sure the ground connection to the panel is good.
Sound like you have a high resistance in the ground circuit and you are becoming the ground while lying on the ground.
2004 Excursion 4x4
Old 07-19-2012, 02:52 PM   #7
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
I'll bet the source is reversed wires at source (where/what you plug trailer in to).
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
tlavergne is offline   Reply With Quote
Old 07-19-2012, 03:06 PM   #8
HowieE's Avatar
Images: 12
That could be a possibility if he is plugged in with just a 2 wire connection and the ground was floating.
If he has a 3 wire connection it would blow the source fuse as soon as he plugged in because the ground and neutral are connected in the trailer electrical panel thus a direct path to ground.
2004 Excursion 4x4
Old 07-19-2012, 03:13 PM   #9
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Plug tester in and they will know ASAP.
Old 07-19-2012, 04:36 PM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The ground and neutral should NOT be (bonded) or connected together in the trailer. The ground path for your trailer should only be thru the panel in your house or shop. This is the point where the neutral is bonded to the ground.
Old 07-19-2012, 04:45 PM   #11
Thanks. That shore breaker has tripped on me a couple times. Thought it was just the new water heater overloading it. I have a tester. I'll try that and a try plugging into a different outlet, and if it persists on to the trailer. Thanks again for the help. I'll keep you posted.
Old 07-19-2012, 07:43 PM   #12
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I am on the road and it didn't do it at the camp ground. It's either my garage plugs or the plug adaptor I was using. I will try the plug adaptor at the next camp ground. It looks a little melted in one of the sockets.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-20-2012, 08:01 AM   #13
Checked the outlet on my garage with a tester and it was fine so it must be the trailer. It has the factory end on the cord, so that should be fine. And I just bought a new adaptor. I'll check out the trailer tomorrow. I'll check the panel first and then? Then Ill kill one circuit and a time and Feel for the current. And ill open up the junction box in the rear storage area and see if everything looks ok. is that a good place to start?
Old 07-20-2012, 08:03 AM   #14
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
WAIT!! Do not "feel" for a current... or you might never get up from under the trailer! Use a electrical gauge to test for continuity between the trailer and the ground... never use yourself!!!
