12-14-2010, 05:21 PM
#121
1974 Argosy 26
Morrill
, Nebraska
Good News
And the ceiling light came on!
Fantastic!!!! If you add more DC lights; Just connect the power wire to the same "lights" fuse that the blue wire is connected.
The plug on the UCord won't be a problem, just be careful to match the colors. The screws are ID'd; LT= left turn; RT= right turn; etc. Chris listed the colors and functions on the drawing.
12-14-2010, 06:20 PM
#122
1965 24' Tradewind
Starkville
, Mississippi
Thanks!
Originally Posted by Minno
I've got everything I need to finish up the Ucord but I have a few questions.
1. In my trailer wiring I have 2 green wires - one #16 and one #14, twisted together. These two green wires were connected to what used to be the old Ucord (the stub sticking out of the trailer). Am I to put both of the green wires in one fuse slot and then the new Ucord green to the other side of it? Connect the two green wires from the harness together, and then connect to the fuse block. I tried to show that on the drawing as well – the two green wires coming off the right side of the fuse block.
2. There is a #16 black wire in the trailer wire bundle and it was connected to a black wire from the old Ucord. The only black wire I found during all these tests, etc. was the #16 black wire in the curbside taillight that wasn't connected to anything. It still isn't connected to anything - I just capped the end of it and left it in the taillight hole. Should I go ahead and connect it to the black wire in the Ucord? I don't know what it was for. The taillight works with it as it is. I would leave the back wire disconnected. Cap or tape it so it doesn’t short anything out. I’d run new black wiring from the ucord fuse block to the ganged fuse block.
3. The sheathed blue/white wire that went to the brakes was brittle and banged up so I got new blue/white wire of the same size. My plan is to run it in pvc to the brake connection and tie it in there. The current sheathed wire has the white to the bolt on the tongue and the blue to the blue in the old Ucord. Do I keep the new wiring the same? Will I need to bring them inside the trailer to the fuse box? There is no blue wire in the trailer harness (other than the one that was connected to the yellow Ucord wire and works the ceiling light when connected to a battery). What do I do with the white wire in the new Ucord? Take a look at the new drawing. If that doesn’t answer these questions, let us know. GREAT drawing! I've already printed it up (along with my instructions) and have it ready to take down the hill tomorrow to work on.
4. When I put the trailer wiring harness wires in the fuse box I assume I bring the new Ucord inside the trailer and put the new Ucord wires opposite them on the other side of the fuse box? Yup!
5. Do I need to have a white ground wire inside the fuse box anywhere? Not really. I would bring it inside and then run it back out to your grounding bolt on the frame just to keep the integrity of the ucord intact. If your ganged fuse box for the 12 volt circuits has a ground blot on it, you can use that to connect the white wires together.
6. When I put the connectors on these wires (the 1/4" female that slides on the fuse box male), do I need to use that heat shrink stuff? I don’t think so. I didn’t on Little Girl. You can, and it won’t hurt anything. But since the connector are inside the trailer, it’s not really necessary. Now, any rings to put on the end of wires that will be outside the trailer, using shrink wrap on would be good extra insurance against weather related problems.
I was able to get a longer Ucord but they didn't have the kind with the plug already on it. I have a plug and will put it together tonight. I find that to be knida a pain. You have my sympathy…
Kinda' a pain is right! They certainly don't want those things to get any water or dirt in them, do they? But I got it together and I'm ready to go!
12-14-2010, 06:23 PM
#123
1965 24' Tradewind
Starkville
, Mississippi
plug
Fortunately, the screws were labeled RED, GREEN, BLUE, etc.! So I think I got it right!
12-14-2010, 07:59 PM
#124
1972 31' Sovereign
Lexington
You're very welcome Lindy! Always happy to help - especially now since Little Girl is snow bound...
So, you noticed the pain part of that connector, huh? It's like trying to put a 3/4" thick cable into pin hole, plus squeezing 7 honking wires into the space the size of a cheerio. Not one of my favorite things to replace. But at least your don't have to be hanging upside-down underneath a steering column to replace it (my least favorite position to work in ).
12-15-2010, 08:14 AM
#125
1974 Argosy 26
Morrill
, Nebraska
Brakes
Lindy,
Make sure to remove (or not install) the fuse for the brakes. This entire brake system needs to be checked out before you power it.
12-15-2010, 01:52 PM
#126
1965 24' Tradewind
Starkville
, Mississippi
Progress so far
It's ok to tell me to start all over - I won't get my feelings hurt. But here's what I've done so far and then I stopped because I have more questions.
I ran the new blue/white wires through the 1/2" pvc and then attached those wires at the brakes (THAT was an interesting experience - there's not a lot of room under the trailer). The wires then come out of the pvc at the front and the white goes to the bolt on the tongue and the blue ties in with the breakaway switch then goes into the hole and the UCord fuse box (20 amp fuse).
I haven't set up the battery yet but the other wire from the breakaway switch will go directly to the positive terminal on the battery.
There is another white wire that is connected to the bolt on the tongue that goes inside and is connected to the lug (not sure I have the right one) on the ganged box. A #10 white has been also connected to the bolt and will go to the negative side of the battery whenever I get it in.
I don't like how the wires are from the brakes/breakaway going into the new hole and need to either tie them all together and/or weatherproof them in some way. I tried that heat shrink stuff and it didn't work very well so I gave up after burning my fingers. I can get some of that good tape when I go back to town on Friday and wrap the whole mess in that. Or I'm certainly open to other suggestions. Don't ask why I didn't just run it all inside and connect the wires there. Just didn't think about it until I saw the pictures. Duh!
I cut the yellow off of the blue wire (that controls the ceiling light) and wired it and a ball of green wire together and put them into the 15 amp fuse space in the ganged box. The green wire will be used for the one or two other 12VDC lights that I plan to have.
I hooked the water pump up to the 20 amp fuse in the ganged box. I didn't run the propane detector wire yet but will do so when I decide where I will put it. I haven't done anything with the fridge wire yet either but will run it over to the fridge even if I find that my old fridge still works. I'm sure I'll need a new one at some point in time.
Now for the questions:
1. Do I have the white wires connected to the right lug on the ganged fuse box?
2. What are those connections for on the lower left of the ganged fuse box (where I have the white wires connected to the nut)?
3. Does it look like the fuse boxes are set up ok?
4. The black #10 wire will come in through the new hole then connect to what? The center lug on the ganged box? Then another black wire will be tied in there as well and go over to the Ucord fuse box to the 30 amp fuse?
5. Should the in-line 30 amp fuse box on the #10 white wire from the battery be INSIDE the trailer (before it goes to the ground lug) or OUTSIDE the trailer? The only in-lime 30 amp fuse I could find is wired with #12 wire. The guy at the auto parts place said it would work. Will it or do I need to get another kind?
6. When I wire my interior lights, right now I only have the one green wire coming from the fuse box. If I put in two 12VDC lights can I just tie into that one wire for the 2nd light?
7. What do I do at the other end of the fridge wire? Will it be hard-wired into the fridge or is there some kind of plug that I wire into? What gauge wire should I run for the fridge?
The diagram of the wiring has been INCREDIBLE!!! It made the entire job so much easier. I hope others will use it as well. It is so easy to follow (IF, of course, I did it right!).
So, with the diagram and the written instructions, how did I do? Start all over or keep going?
thankyouthankyouthankyouthankyou..... Or, as Elvis would say "thankyewverrymuch"
12-15-2010, 02:02 PM
#127
1965 24' Tradewind
Starkville
, Mississippi
couple more pictures
Maybe you can tell better about the fuse boxes with these pictures.
12-15-2010, 02:30 PM
#128
1974 Argosy 26
Morrill
, Nebraska
1. Do I have the white wires connected to the right lug on the ganged fuse box? It looks like a common/ground buss, but check it with your meter in the 2K mode to make sure it is not connected to the fuse terminals. Disconnect the wires while testing. If it is the common/ground buss at least one of the white wires should go to the frame.
2. What are those connections for on the lower left of the ganged fuse box (where I have the white wires connected to the nut)? See question #1
3. Does it look like the fuse boxes are set up ok? Yes. If you mean the mounting.
4. The black #10 wire will come in through the new hole then connect to what? The center lug on the ganged box? Then another black wire will be tied in there as well and go over to the Ucord fuse box to the 30 amp fuse? I'll make an educated guess and say the big nut near the center of the block. Both wires.
5. Should the in-line 30 amp fuse box on the #10 white wire from the battery be INSIDE the trailer (before it goes to the ground lug) or OUTSIDE the trailer? The only in-lime 30 amp fuse I could find is wired with #12 wire. The guy at the auto parts place said it would work. Will it or do I need to get another kind? As long as it is not in the white wire that goes to the brakes. #12 wire is good for 20 amps, so just use a 20 amp fuse, you should be fine. Inside is always better than outside. If you want a 30 amp fuse you need a 30 amp fuse holder.
6. When I wire my interior lights, right now I only have the one green wire coming from the fuse box. If I put in two 12VDC lights can I just tie into that one wire for the 2nd light? Yes If I might ask. Why did you choose green? It's really not part of the tail/marker light circuit.
7. What do I do at the other end of the fridge wire? Will it be hard-wired into the fridge or is there some kind of plug that I wire into? What gauge wire should I run for the fridge? It depends on the fridge. I would run #12 wire. You can always put the proper size fuse in to give you protection, but if you ran a #16 and it was too small, you would have to replace it.
Just wrap tape around the fridge end and leave the fuse out of the circuit until you get a new fridge. Leave lots of wire cause you don't know where it will connect.
So, with the diagram and the written instructions, how did I do? Start all over or keep going? YOU DID AND EXCELLENT JOB!!!! Nice job on the PVC pipe.
Just a suggestion on the 3 wires going thru the new hole. If you were to get a piece of fuel hose long enough 3/8" should be big enough. You could slip it over the wires, then thru the hole into the trailer and tape up the end that is exposed to the weather or use some heat shrink. It would give you more protection than the tape alone.
12-15-2010, 03:03 PM
#129
1974 Argosy 26
Morrill
, Nebraska
Pump
Another suggestion for your pump. Pick up one of those cheap plastic boot trays and put it under the pump (if you have room). That way if you have a leak the tray will catch the water. It works good when you winterize because there is always a little spill when doing that.
OH! You have the ground wire hooked up to the pump. I see a red wire that looks like it is connected to the pump as well; if so that is the wire that goes to the fuse. The black wire is common/ground.
It's that screwed up automotive wire color thing again. Red is positive
Black is negative on the pump.
Just connect the black wire to the common buss where the white wires are connected. Run the Red wire up to where the black is connected in the photo.
12-15-2010, 03:23 PM
#130
1972 31' Sovereign
Lexington
Hi Lindy,
Couple of things.
I think you have the pump wired backwards. Since it has a red and black wire, I would think the red wire goes to +12 volts, and the black wire in the return (ground). Does the label on the pump say one way or the other? Or do you have instructions for wiring the pump?
When you do the rest of the pump wiring, are you going to run from the fuse block to the switch and then to the pump? In other words, have the switch in the +12 volt wire going to the pump? That would make the most sense I think.
The 20 and 5 amp fuses you have are the mini-ATC variety, not the full sized ATC ones. I would replace them with the full size ATC fuses. I think the full sized ones will stay in the fuse block better. My concern would be the mini-ATC fuses vibrating out of the fuse block while traveling.
Since you have an open space in the ucord fuse block, you could use it for a 30 amp fuse for the white wire going to the battery. To do that properly, you would run a 10 gauge white wire from the battery inside to one side of the fuse block. The other side of the fuse block would have a white wire, that is then connected to the ground lug on the ganged fuse block. Also attached to that ground lug would be a white wire to connect to the frame (back outside), and the white wire on the ucord. On the frame bolt you would have the white wire from the ganged fuse block and the white wire for the brakes.
That make sense? Would you like me to update the drawing for you to show these new white wire connections?
Chris
12-15-2010, 03:26 PM
#131
1972 31' Sovereign
Lexington
TG - you updated your post while I was typing!
And yes Lindy, you've done excellent work so far! No need to start over.
12-15-2010, 03:43 PM
#132
1974 Argosy 26
Morrill
, Nebraska
Pump
Lindy;
I forgot to mention that the RED wire on the pump should go to the switch for the pump, then another wire will go from the other side of the switch to the fuse block.
Chris: We must get on the computer at the same time of day. I went away and then thought about the switch on the pump. Went right to the bottom to write this, then scrolled back up and saw your post. Good catch!
12-15-2010, 04:51 PM
#133
1972 31' Sovereign
Lexington
TG, Just so people don't start thinking we're married to each other!
12-15-2010, 08:40 PM
#134
1965 24' Tradewind
Starkville
, Mississippi
1. Do I have the white wires connected to the right lug on the ganged fuse box? It looks like a common/ground buss, but check it with your meter in the 2K mode to make sure it is not connected to the fuse terminals. Disconnect the wires while testing. If it is the common/ground buss at least one of the white wires should go to the frame. Huh? When I test it, what do I test? Where do I put the probes and what # am I looking for?
4. The black #10 wire will come in through the new hole then connect to what? The center lug on the ganged box? Then another black wire will be tied in there as well and go over to the Ucord fuse box to the 30 amp fuse? I'll make an educated guess and say the big nut near the center of the block. Both wires. Got it!
5. Should the in-line 30 amp fuse box on the #10 white wire from the battery be INSIDE the trailer (before it goes to the ground lug) or OUTSIDE the trailer? The only in-lime 30 amp fuse I could find is wired with #12 wire. The guy at the auto parts place said it would work. Will it or do I need to get another kind? As long as it is not in the white wire that goes to the brakes. #12 wire is good for 20 amps, so just use a 20 amp fuse, you should be fine. Inside is always better than outside. If you want a 30 amp fuse you need a 30 amp fuse holder. I will be able to put it inside. My in-line fuse holder came with a 30 amp fuse in it but it says on the pkg. that it is #12 wire. Seems that they shouldn't make it for 30 amps if #12 only handles 20 amps.
6. When I wire my interior lights, right now I only have the one green wire coming from the fuse box. If I put in two 12VDC lights can I just tie into that one wire for the 2nd light? Yes If I might ask. Why did you choose green? It's really not part of the tail/marker light circuit. Because I had it? Because I like green? I thought since its all going to be hidden anyway, it wouldn't make any difference. I can exchange it for another color if that is better - yellow? I have a lot of old yellow wire laying around in the trailer.
Just wrap tape around the fridge end and leave the fuse out of the circuit until you get a new fridge. Leave lots of wire cause you don't know where it will connect. Will do. I have a 15 amp fuse in it but will take it out and save it for when I get a new fridge.
So, with the diagram and the written instructions, how did I do? Start all over or keep going? YOU DID AND EXCELLENT JOB!!!! Nice job on the PVC pipe. Thanks! I had a LOT of help from my friends!!
Just a suggestion on the 3 wires going thru the new hole. If you were to get a piece of fuel hose long enough 3/8" should be big enough. You could slip it over the wires, then thru the hole into the trailer and tape up the end that is exposed to the weather or use some heat shrink. It would give you more protection than the tape alone. I must be doing something wrong with the heat shrink. Can you give me a quick "how to" lesson? Do I just twist the wires together then slip the tube of heat shrink over it then heat it? I have been putting the wires together with connectors and the dang heat stuff won't go over it.
I will check the instructions for the water pump tomorrow. I thought it said that the red went to the switch and the black to the battery.
But you said I connect the black wire to the common buss (that's the lug with the white wires on it?)? Fortunately, I still have the instructions that came with the thing.
12-15-2010, 08:43 PM
#135
1965 24' Tradewind
Starkville
, Mississippi
Well, you WOULD make a very productive couple at least!
12-15-2010, 09:10 PM
#136
1965 24' Tradewind
Starkville
, Mississippi
Hi Lindy,
Couple of things.
I think you have the pump wired backwards. Since it has a red and black wire, I would think the red wire goes to +12 volts, and the black wire in the return (ground). Does the label on the pump say one way or the other? Or do you have instructions for wiring the pump? Yes, I'll check the instructions tomorrow. It even has pictures!
When you do the rest of the pump wiring, are you going to run from the fuse block to the switch and then to the pump? In other words, have the switch in the +12 volt wire going to the pump? That would make the most sense I think. So, looking at the picture of the back of the switch (I've posted it again), I come into the switch from the fuse box to one of the yellow wires then do I connect the other yellow wire to the black wire of the little light then go from the other black wire back to the pump?
The 20 and 5 amp fuses you have are the mini-ATC variety, not the full sized ATC ones. I would replace them with the full size ATC fuses. I think the full sized ones will stay in the fuse block better. My concern would be the mini-ATC fuses vibrating out of the fuse block while traveling. I will take them back and get the right kind. Gene liked those because they light up when they're blown. Oh brother!
Since you have an open space in the ucord fuse block, you could use it for a 30 amp fuse for the white wire going to the battery. To do that properly, you would run a 10 gauge white wire from the battery inside to one side of the fuse block. The other side of the fuse block would have a white wire, that is then connected to the ground lug on the ganged fuse block. Also attached to that ground lug would be a white wire to connect to the frame (back outside), and the white wire on the ucord. On the frame bolt you would have the white wire from the ganged fuse block and the white wire for the brakes. OK - I already have the white wire from the frame bolt and the white wire from the Ucord connected to the ganged fuse block nut. If I put a 30 amp fuse in that bottom space in the Ucord fuse block then I wouldn't need the in-line fuse holder, right? I would come in on the right with the #10 white wire from the battery and opposite that would have a #10 white go from there to the lug with the other two. Right?
Chris
If I interpreted it right then I don't need another drawing. If I didn't get it right then another drawing would be great. I am, needless to say, a very visual learner (and also slow...)
12-15-2010, 09:33 PM
#137
1974 Argosy 26
Morrill
, Nebraska
Put the meter on 2K, then touch the metal piece where the white wires connected with the RED probe, hold it there and touch one of the places you hooked the individual wires to (like for the pump) with the BLACK probe. If the reading is "1" they are not connected, therefore the terminal where you have the white wire is in fact the common/ground terminating point. The lug in the center is the power lug where you will connect the battery etc.
5. Should the in-line 30 amp fuse box on the #10 white wire from the battery be INSIDE the trailer (before it goes to the ground lug) or OUTSIDE the trailer? The only in-lime 30 amp fuse I could find is wired with #12 wire. The guy at the auto parts place said it would work. Will it or do I need to get another kind? As long as it is not in the white wire that goes to the brakes. #12 wire is good for 20 amps, so just use a 20 amp fuse, you should be fine. Inside is always better than outside. If you want a 30 amp fuse you need a 30 amp fuse holder. I will be able to put it inside. My in-line fuse holder came with a 30 amp fuse in it but it says on the pkg. that it is #12 wire. Seems that they shouldn't make it for 30 amps if #12 only handles 20 amps. I think you should skip the inline fuse and go with Chris's idea of using the spare space on the UCord fuse block.
No need, I was just curious. As long as you know what colors are for what it's OK.
If you don't have heat shrink big enough to go over the barrel lugs you can solder the wires together, then slide the heat shrink over the splice. Remember to put the heat shrink over one of the wires before soldering. Are you using barrel connectors to connect the wires or wire nuts? I see a wire nut on the new wiring going into the front of the trailer. If you have a hair dryer that gets pretty hot you can use it to heat the tubing to shrink it down.
I will check the instructions for the water pump tomorrow. I thought it said that the red went to the switch and the black to the battery. I am sure the red wire on the pump is the positive wire. Which will go to one side of the switch along with one of the wires from the light. The other side of the switch connects to the fuse block. The other side of the light goes to ground/common. Does that make sense to you? I would take all of the old wiring off of the switch and run new, it looks like the switch has spade connectors like the fuse block.
But you said I connect the black wire to the common buss (that's the lug with the white wires on it?)? Fortunately, I still have the instructions that came with the thing. Yes the Black wire on the pump goes to the common/ground lug along with the whites. If you like I see you have extended the black wire from the pump with more black wire, you could cut the black you put on off and connect a white wire to the black from the pump and then connect it to the common/ground bus with the other whites. That way they would all be white.
I know this can be a little confusing, but think of the pump like you would the battery in your TV; Red is positive and Black is negative.
lucymcdog View Public ProfileSend a private message to lucymcdogSend email to lucymcdogFind More Posts by lucymcdogAdd lucymcdog to Your ContactsView BlogView Gallery Uploads
Today, 08:43 PM # 135 lucymcdog
lucymcdog
Profile: 1960 18' Traveler
Saguache , Colorado Posts: 88
12-15-2010, 10:00 PM
#138
1965 24' Tradewind
Starkville
, Mississippi
I will check the instructions for the water pump tomorrow. I thought it said that the red went to the switch and the black to the battery. I am sure the red wire on the pump is the postive wire. Which will go to one side of the switch along with one of the wires from the light. The other side of the switch connects to the fuse block. The other side of the light goes to ground/common. Does that make sense to you? I think so. Red pump wire to yellow switch wire and include one of the wires from the light. Black wire from switch to fuse block (20 amp). Other wire on light to ground. Can it be grounded like it was with that bare wire screwed into the wall or should it go back to the fuse box and be grounded with the other grounds? That grounds the switch/light only? I still need to do what you say below from the pump to the ground buss?
Now I get to dream about wiring again all night...
12-15-2010, 10:08 PM
#139
1974 Argosy 26
Morrill
, Nebraska
The 2K test
Lindy: When you do the test for the ground/common lug on the fuse block make sure you have the fuse installed. But disconnect the wires during the test.
I will check the instructions for the water pump tomorrow. I thought it said that the red went to the switch and the black to the battery. If it says to the battery it is probably the negative terminal, look closely.. I am sure the red wire on the pump is the postive wire. Which will go to one side of the switch along with one of the wires from the light. The other side of the switch connects to the fuse block. The other side of the light goes to ground/common. Does that make sense to you? I think so. Red pump wire to yellow switch wire and include one of the wires from the light. Black wire from switch to fuse block (20 amp). Other wire on light to ground. Can it be grounded like it was with that bare wire screwed into the wall or should it go back to the fuse box and be grounded with the other grounds? That grounds the switch/light only? I still need to do what you say below from the pump to the ground buss? You can use the bare wire or even better just run a new white wire from the light to the place where the bare wire is connected to the skin. As I said earlier I would remove all of the old wiring from the switch and run new. Yes this only provides the common/ground for the light, you will still need to connect the black wire from the pump to the ground/common terminal where the other whites are connected. You don't have to put it under the bolt just put a spade lug on it and push it on to one of the spades sticking up next to the bolt. It's all the same thing.
I know how that goes with dreaming about wiring. It's hard to get it out of your mind when you are on a roll.
12-16-2010, 06:50 AM
#140
1972 31' Sovereign
Lexington
I'm dreaming of a white wire...
Kay and I both end up dreaming about Little Girl, or other household projects when we're working on them. One of the hazards of working on things we care about.
From before: Since you have an open space in the ucord fuse block, you could use it for a 30 amp fuse for the white wire going to the battery. To do that properly, you would run a 10 gauge white wire from the battery inside to one side of the fuse block. The other side of the fuse block would have a white wire, that is then connected to the ground lug on the ganged fuse block. Also attached to that ground lug would be a white wire to connect to the frame (back outside), and the white wire on the ucord. On the frame bolt you would have the white wire from the ganged fuse block and the white wire for the brakes. OK - I already have the white wire from the frame bolt and the white wire from the Ucord connected to the ganged fuse block nut. If I put a 30 amp fuse in that bottom space in the Ucord fuse block then I wouldn't need the in-line fuse holder, right? Right - no need for the inline fuse now. I would come in on the right with the #10 white wire from the battery and opposite that would have a #10 white go from there to the lug with the other two. Right? Yup - you've got it!!!
I'm with TG on the pump switch and light - replace the wiring with new. Would you like that wiring added to the drawing, or do TG's instructions make sense to you?
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
12v Electrical Issues
Clyde-2 |
Batteries, Univolts, Converters & Inverters |
5 |
10-25-2009 08:12 AM |
Univolt or 12v System Gone Wrong
AustinAir |
4 |
04-09-2009 11:10 PM |
63 Overlander 12V system
rvnpikes |
Electrical - Systems, Generators, Batteries & Solar |
2 |
10-09-2008 09:53 AM |
12V Electrical Questions
Airstream 65 |
4 |
06-07-2007 03:24 PM |
12V System....Sudden Death! Help, please
Alan and Mardel |
6 |
12-13-2003 11:04 AM |
