12-01-2010, 03:32 PM
#41
1965 24' Tradewind
Starkville
, Mississippi
battery stuff
Thanks for the quick lesson on multi-meters. I don't have the instructions for the meter but will try to find them on-line. It was in my husband's tool box and he doesn't read instructions. I did what you said to do about figuring out what the blue wires are. And BOTH wires coming out at the front are blue, BTW.
The only other blue wire I could find was on the little light in the ceiling. I did the alligator clip to one blue wire in the front and the other end to a screw in the skin. I then undid the light and put the black probe on another screw in the ceiling and the red on the blue wire coming out for the light. The meter read "0" when the jumper wire was connected to the front wire on the left and it jumped all around to different numbers when it was connected to the wire on the right. When I did all this my meter was set to DCV 20. So, does that mean that the blue wire from the light is connected to the blue wire in the front on the left? What the heck is the other blue wire for? And now what do I do?
If I were to connect the two blue wires in the front to a battery (I have an old one in the garage), would that blow up the trailer? Or would I then be able to see if the ceiling light works?
My TV is a Land Rover, not a pickup truck. But I could certainly put an extra battery in a box in the back end of it. We used to do something like you suggested with our 5th wheel (we've had every kind of RV known to humankind) and it came in handy when we spent several months camping.
As for batteries - is it best to get one 12V deep cycle or get two 6V and tie them together? Our truck camper had the 2 6V tied together but I never saw much advantage of having it that way. When they died we just replaced it with one 12V and it worked fine.
12-01-2010, 04:00 PM
#42
1972 31' Sovereign
Lexington
I usually enjoy a good challenge or two every once in awhile… I’ll try and provide suggestions in the order you list your questions & comments.
Fan: My suggestion would be to buy a 12 volt fan or a battery operated fan. We have several battery operated fans we travel with. The one we use most of the time contains rechargeable batteries, and it can also plug into a 12 volt outlet or a 110 VAC outlet. When plugged in to either 12 VDC or 110 VAC, it recharges it’s internal batteries. It also uses 8 “D” cell batteries in case you run down the rechargeable pack and can’t plug it in. If interested, I can get a picture of it for you. I think we bought it at camping world 2 or 3 years ago.
Battery Type: I have no experience with AGM batteries (I’m a die-hard golf cart battery person). But I understand they are quite good from reading about them on the forums, and are probably a better choice for you than a wet-cell battery. MexRay can probably offer some insight on what size might work for you as he’s a battery dealer (I think). I would opt for installing on the tongue as long as the battery will fit, or do what TG suggests if you have a pickup.
I would buy a new fuse box, yes. I bought one from here: http://www.wiringproducts.com/contents/en-us/d136.html. Prices are pretty good, and shipping to me is quick when I order from them. They are where we bought almost all of our 12 volt wire as well.
If you want a solar panel, I would buy that before buying a converter or battery charger. Then, are you use the trailer camping, or while it’s in storage, if you find that you could use another charging source for the battery, you can always add a charger or converter later.
TG gave you a really good lesson on using the multi-meter and tracking down the wires.
I would plan on 4 12 volt circuits:
Fridge
Water Pump
Lights
Furnace (future use maybe)
The smallest fuse block you can get from the web site I mentioned above is a 4 circuit block (part number AF-CFB4). They also sell connectors and fuses. If you look at our thread (http://www.airforums.com/forums/f185...-50967-11.html), post 143 shows the 6 circuit fuse block all connected and fused for our umbilical cord.
Question: Have you thought about installing a propane detector? If yes, that will need to be on its own 12 volt circuit. They must be hard wired in to a 12 volt circuit – there are not any internal battery operated ones available like smoke detectors are. In this case, you can adjust the 4 circuits to be:
Fridge
Water Pump
Lights / Furnace
Propane Detector
Make sense so far?
12-01-2010, 07:50 PM
#43
1974 Argosy 26
Morrill
, Nebraska
Continuity test
When you do the continuity test the meter should be set to the 2K position. That's about 5 o'clock on the dial. Select that mode then touch the red and black probes together. You need to have a good battery in the meter for this to work. You should see the reading go down to zero or close. Then get your jumper with the "A" clips; connect it to one of the blue wires coming out of the wall then connect the other clip to the screw in the skin. Go up to the light fixture and touch the black probe of the meter to the skin, then touch the red probe to the blue wire. If it goes to "0" it's the same wire. Test both wires coming out of the wall. If you identify one of the wires going to the light fixture then chances are the other wire goes back toward the power panel. Let me know what happens.
OH! By the way you have the leads on the meter reversed. Black should always go to common. It really doesn't effect the meter reading it's just that when you read 12 volts it will show a minus sign. You should get in the habit of using the black probe to touch the skin of the trailer and the red probe to the wire or device you are testing in the DC volt mode..
Is that a shelf below the point where the 2 blue wires come out of the wall?
Can you find a blue wire in the fuse panel? It's possible that both blue wires are power wires to different devices; one wire comes from the fuse panel to provide power to the old water pump; the other wire provides power to the light fixture. If so they need to be connected together for the light to work.
But you still need to find the other end of the opposite blue wire. Where is the old pump switch located? Maybe near the sink? I find it odd that there is no sign of a box or any thing around the 2 blue wires.
12-01-2010, 08:28 PM
#44
1974 Argosy 26
Morrill
, Nebraska
Danger!!!!!
NEVER CONNECT ANYTHING DIRECTLY TO A BATTERY!!! ALL DEVICES CONNECTED TO A BATTERY SHOULD BE PROTECTED WITH A FUSE. IF THINGS GO WRONG YOU COULD BLOW UP THE BATTERY. IF YOU ARE ANYWHERE CLOSE IT COULD RESULT IN SERIOUS INJURY. YOU COULD ALSO MELT THE WIRES INSIDE THE WALL OF THE TRAILER. RENDERING THEM USELESS.
This is the reason I recommend using a battery charger as a power source for testing DC circuits. Most if not all have a current limit function and will shut down "crowbar" if overloaded. When using the charger the BLACK clip goes to the skin.
12-01-2010, 09:37 PM
#45
1965 24' Tradewind
Starkville
, Mississippi
so far...
Well, it made sense until I looked at the pictures of your umbilical connector. It's so tidy! The white wires are the ground/neutral bus? Does that come with the fuse box or do I need to be sure to order it separately. Not at all what mine looks like as you could tell from the picture I posted. And there is nothing on the inside of my trailer where the cord comes out. I'm assuming the wires run between the floor and the bellypan? But when we took the rotted floor out in the front I didn't see any wires.
So. Do I just drill holes for the battery wires to come inside the trailer and go to the fuse box? The patch I took off looking for the connector was a hole about 2" around so I guess I could use that if I pad it well so it won't cut the wires? Or would it be best to just cut some smaller holes and run the battery wires through those? One hole, one wire or not? And what do I do with the blue mystery wires? Cut them off and pretend they're not there?
In your photo it looks like the colorful wires of the umbilical come into the fuse box and then go back on the other side into the inside of the skin. I'm not sure how I can access the umbilical wires from the interior. I can run the new wires along where the 110VAC new wiring is which will be hidden by the dinette, etc. but how do I get to the umbilical wires? My wires look much fatter than yours and some are just barely sticking out of the trailer. In fact, one or two aren't even connected to the cord because there's not much to connect to. Is there any rhyme or reason to the colors? Do the colors mean anything or are they just colored to be able to distinguish them and where they go?
I'll get started researching and ordering stuff. I'm going to the "big city" on Friday and will check into getting a battery and battery box that will fit on the tongue then we'll take it from there.
This seems a LOT more complicated than the 110VAC!
Needless to say, I'm glad you like a challenge. And you're a heck of a distance-learning instructor.
Lindy
12-01-2010, 09:53 PM
#46
1965 24' Tradewind
Starkville
, Mississippi
testing, testing...
After it warms up enough tomorrow, I'll go try the test again with the meter set up right. I'll let you know what happens.
I don't have a fuse panel. I've posted a picture what was there and it was screwed into the wall just above the two blue wires. The little fuse panel had a couple of broken fuses in it but it wasn't connected to anything except the water pump to the left of the old water tank. Yellow wires connected the pump to the fuse box. There was also something else that looked somewhat like a water pump but somebody said it was a pressure pump. It had thin blue wires coming out of it but wasn't connected to anything.
The two blue wires come out of the wall just above the floor, not a shelf. The pump switch (and a little light) were on the panel in front of the sink but they, too, were not connected to anything. They're just sitting there. There were some thin yellow and white wires curled up under the sink but they, too, were not connected to anything. Seems that the PO decided to just unhook everything and leave me in the lurch.
Thank goodness for the forum!
12-01-2010, 10:00 PM
#47
1965 24' Tradewind
Starkville
, Mississippi
I TOLD him!
It was my HUSBAND who wanted to hook up the battery directly to the blue wires. Fortunately, I was able to hold him off until I could get some more info from you! THANK YOU THANK YOU THANK YOU!
Not to worry - I will NOT hook a battery up to the wires!
We do have a battery charger that I can use. Can I use it to see if the ceiling light works? Hook the red up to the blue wire (should I connect the two blue wires?) and the black to the trailer?
I will wait to hear from you before I do anything!
Thanks for saving my trailer, my life, and my marriage (in that order!)
12-02-2010, 06:30 AM
#48
1972 31' Sovereign
Lexington
Hi Lindy - just something real quick this morning. The fuse block I suggesed yesterday won't work very well for you. You need one of the ganged fuse blocks listed on that web page. They provide a single power input to supply all the fused circuits. The Ganged Fuse Panel with Ground Bus is probably a good choice since it comes with a built in ground bus. Otherwise, you'll need a separate one. I'll catch up on the rest of your posts later today.
12-02-2010, 07:51 AM
#49
1965 24' Tradewind
Starkville
, Mississippi
This one?
Ganged Fuse Panel With Ground Bus
Bussman brand fuse panel has an additional ground bus that is a good choice for use on boats or to eliminate ground noise in your circuits. Available in 6, 8, 10, and 12 positions. The panel can be used with ATO or ATC automotive fuses or ATC style DC circuit breakers. One stud provides common power to the fuses, and separate stud provides for a common ground.
What size wire should I get for the various applications?
From battery to panel - 10 gauge?
From panel to fridge
From panel to water pump
From pump to switch & light
From panel to lights/furnace
From panel to propane dectector
15 amp fuses? or larger?
12-02-2010, 11:56 AM
#50
1965 24' Tradewind
Starkville
, Mississippi
meter info
[QUOTE=TG Twinkie;922692]
OK - this is what happened when I hooked up everything like you said and then set the meter on the 2K position:
Touching probe to probe: 0
Left blue wire: .001
Right blue wire: 1.
Blue wires together: .000
I searched again for more blue wires in the trailer and couldn't find any. Since the trailer has been gutted except for the fridge/furnace cabinet, it wasn't hard to look. But there is no wiring in the fridge/furnace cabinet - the furnace doesn't have a blower and the fridge is the original Norcold propane only.
Now what? Do the numbers tell you anything? How do I hook up the battery charger to check out the light? Black to skin and the other to one blue wire or the two blue wires together?
#51
1974 Argosy 26
Morrill
, Nebraska
Testing the light
I would first check the light fixture itself. It looks like it is a metal fixture. So put an 1141 bulb in it. Disconnect the blue wire from the single black wire in the fixture. Connect the black lead (clamp) on the charger to the metal part of the fixture; then connect the charger red lead to the black wire. Don't forget to push or rotate the switch if it doesn't come on. Make sure the socket you plug the bulb into is not corroded. Oh be sure to plug the charger in. Let me know what happens.
About the switch for the pump near the sink. What color are the wires if any?
Sounds like the left blue wire goes to the fixture. Do the test I mentioned above and if the light works, leave the switch in the "on" postion. Mount the light back on the ceiling and hook it up to the blue wire. Then take the charger connect the black lead to a screw and the red lead to the left blue wire on the wall and see if it works. Let me know.
12-02-2010, 12:37 PM
#52
1974 Argosy 26
Morrill
, Nebraska
Oop!
I meant to say reconnect the black and blue wires in the fixture then mount it back on the ceiling.
When you have the meter set to 2K and you don't have the red and black probes touching does it read "OL"?
When you read 000 on the blue wires were you reading between the blue wires or did you have them connected together and read them?
12-02-2010, 01:26 PM
#53
Wise Elder
2010 30' Classic
South of the river
Originally Posted by lucymcdog
I have finished rewiring the trailer with 20 amp service. I've attached pictures of what I've done to see if I pass inspection.
Inspector Jammer here with a stack of red tags.
There are a number of minor items for you to consider.
1) Other posters brought the need for a 20a main breaker to your attention.
2) Every metal junction box should be grounded. They sell ground screws with a 12 gauge pigtail on them already, that you can use.
3) The cable clamps must always face outwards away from the box. Also, be sure the clamps are tight and the lockrings secure. It is usually necessary to tighten the lockrings with a screwdriver and hammer for them to get tight enough.
4) Be sure you're complying with the minimum wire size for the large terminals in the breaker box. It should be listed on a somewhere on the breaker box. You may need to use larger wire for the jumper between the two hot buses. If you're using the large lug for the neutral, and it requires a larger wire size, you can just move the wire to one of the smaller holes - they're equivalent except for the wire sizes they accept.
5) I believe the bathroom junction box is overfilled (too many wires). I wouldn't necessarily change it now unless the wires rub on the cover when it's closed, but in general you need an extra-deep 1-gang box or a 4x4" box to join three pieces of 12 gauge romex. (If you add the ground wire that may push it over the edge. You can add an extension ring to the top of the box if that happens if you want to avoid having to redo the cable clamps)
Jammer
12-02-2010, 04:09 PM
#54
1972 31' Sovereign
Lexington
Yes, the white wires are the ground/neutral bus. Eventually, I will connect that to the frame and skin, once I decide where the ground bus and fuse panel will be mounted. I was going to avoid talking too much about your umbilical cord right now, and just let you focus on the rest of the 12 volt system. But since you’re asking…
The umbilical cord goes into the void between the inner and outer skins. On our trailer, there was an access panel, which covered the round hole you could see in my post pictures. That’s what I was hoping you would find. It’s directly on the inner wall where the umbilical cord comes in through the outer skin. You may need to create your own access by cutting the inner skin away so you can see where the wires all go. In Little Girl, they all run inside the walls. What you can see in my picture is the umbilical cord connects to one side of the fuse block, and then the wires go inside the wall to the left in the picture. They feed up the front, and along the middle of the ceiling to reach all the running lights. The exception to that is the brake wire, which goes out a hole in the c-channel and floor, and will run inside the belly pan to the axels There is a blue wire for 12 volts and a white wire for the neutral that goes to the brakes. You can see them in the same post 143. I have them feeding through a piece of pex pipe through the frame. The red and white wires that come back out through the front of the trailer alongside the umbilical cord will eventually connect to my batteries on the tongue.
If you work on replacing the umbilical cord at the same time you’re doing the rest of the 12 volt wiring, you can use the same hole to run wires to the battery that the umbilical cord will run through. I bought a watertight connector at Home Depot for my cords to run through.
Regarding the blue mystery wires, I’m thinking that once you have access to the umbilical cord inside the wall, you’ll find the other ends of those wires. They look heavy duty enough to be for a battery connection, but blue is typically used for the brakes in the umbilical wiring, so maybe they are connected to the brake wires. If that’s the case, and the brake wires are still connected to the brake magnets inside the hubs, that would explain why you see “0” readings when you check both of them. Crawl under the trailer, and see if the brake wires are connected to the brakes. If they are, try disconnecting all of them, and do the test on the blue wires and lamp again.
This one?
Yes, this is the one. You can pick the size you want. 6 circuits would do you fine.
You’ll need a separate fuse block, like I installed, for the umbilical cord.
From battery to panel - 10 gauge is good, yes. This can fused for 20 or 30 amps.
I used 14 gauge for all the other circuits, except the propane detector, which is 16 gauge, and the water pump which is 12 gauge. 20 amps for the water pump, 15 amps for the lights and fridge, and 5 amps for the propane detector will be ducky.
Tomorrow, I’ll go over the umbilical cord wiring in more detail. Kay’s home, and we’re heading out to dinner and shopping.
Chris
12-02-2010, 04:44 PM
#55
1965 24' Tradewind
Starkville
, Mississippi
1) Other posters brought the need for a 20a main breaker to your attention. Done!
2) Every metal junction box should be grounded. They sell ground screws with a 12 gauge pigtail on them already, that you can use. Done!
3) The cable clamps must always face outwards away from the box. Also, be sure the clamps are tight and the lockrings secure. It is usually necessary to tighten the lockrings with a screwdriver and hammer for them to get tight enough. Done!
4) Be sure you're complying with the minimum wire size for the large terminals in the breaker box. It should be listed on a somewhere on the breaker box. You may need to use larger wire for the jumper between the two hot buses. If you're using the large lug for the neutral, and it requires a larger wire size, you can just move the wire to one of the smaller holes - they're equivalent except for the wire sizes they accept. Done!
5) I believe the bathroom junction box is overfilled (too many wires). I wouldn't necessarily change it now unless the wires rub on the cover when it's closed, but in general you need an extra-deep 1-gang box or a 4x4" box to join three pieces of 12 gauge romex. (If you add the ground wire that may push it over the edge. You can add an extension ring to the top of the box if that happens if you want to avoid having to redo the cable clamps) I'll switch it out to a 4x4 box tomorrow!
Jammer
Do I pass now, Inspector Jammer?
12-03-2010, 08:10 AM
#56
1965 24' Tradewind
Starkville
, Mississippi
Bingo!
The light works AND, when I hooked up the charger like you said, it works in the trailer with the left blue wire. It does nothing with the right blue wire.
That's good news, right?
When I have the meter set to 2K and don't have the probes touching it reads "1", not "OL"
When I read 000 on the blue wires I got the reading with the wires connected together.
I haven't crawled under the trailer yet to disconnect the brake wires - or to see if the wires are even there. I'll try to get to that this weekend. With a dirt floor it is a dirty job. Perhaps the right blue wire is for the brakes?
12-03-2010, 08:54 AM
#57
1974 Argosy 26
Morrill
, Nebraska
That is good news!
I don't think the right blue wire is for the brakes. Do you know if the trailer had a breakaway switch for the brakes? It might have been for that though.
How may 12 volt lights are in the trailer? It is possible that a battery sat near where these wires came out of the wall and that all of the hardware associated with a battery; like a fuse panel and or converter could have been removed by PO.
But I am thinking that the other blue wire must have gone to a place where there was DC power. Don't know why these wires came out of the wall unless this is where the battery was. We know now that the left blue wire is for the light. The right blue wire should be the 12volt power for the light. The light having it's own switch, it would make sense.
I can't remember if you said there was a place for or even an old converter or DC fuse box in the trailer. Do you know if there ever was a battery in the trailer? Maybe it just used the TV battery.
Try using the same troubleshooting method you did for the light. Jumper the right blue lead to the screw in the skin. Then with your meter on 2K see if you get a "0" reading on any of the wires in the umbilical cord. Touch the black lead to the skin; make sure it's on a shiny spot then touch each of the wires for the umbilical cord. Of course it should not be connected to the TV. Look for a lonely blue wire on the tongue that might have gone to a breakaway switch.
I'll be gone on Saturday and Sunday, but will check back as soon as I can.
12-03-2010, 09:17 AM
#58
1974 Argosy 26
Morrill
, Nebraska
Another thought.
If there are other 12volt lights in the trailer that don't work check to see of the right blue wire might go to it or to the pump switch or any light switch in a wall etc. If so use the battery charger to check them out.
In the pics of the umbilical cord exiting the trailer. Where does the blue wire form the TV go? It goes off to the left in the pic and is taped together with another wire. It that the breakaway switch?
I have another idea on how to identify all of the circuits that are associated with what is left of the umbilical cord that comes out of the trailer. I just put a note here to remind me so I can help you out more when I get back to the computer in a couple of days.
12-03-2010, 11:09 AM
#59
Wise Elder
2010 30' Classic
South of the river
You get a Gold Star and an official Airforums Occupancy Permit.
Jammer.
12-04-2010, 09:52 AM
#60
1972 31' Sovereign
Lexington
Umbilical Wiring:
I bought a prewired umbilical cord with a molded on 7-pin connector for Little Girl. The umbilical wiring is a standard wiring scheme, where each wire is color coded for its function. When I rewired Little Girl, I used the same color coding for the wiring in the trailer, except I switched the Black wire on the umbilical cord to a Red wire in the trailer. This is the +12 VDC feed from the TV, and it will connect to the battery. Here’s the wiring diagram I used for the umbilical wiring on Little Girl.
little girl umbilical wiring.pdf
All of the wiring runs inside the walls, except for the battery and brake wires. Those run under the floor, inside the belly pan.
On this picture, the umbilical cord is on the left of the fuse block, and the trailer wiring is on the right.
In looking at the stump of your umbilical cord, it looks likes you have the right colored wires going into the trailer (red, brown, white, blue, green, & yellow). I would start by verifying that the white wire is indeed ground/neutral. Use your multi-meter to see if the white wire is connected to the frame & shell by checking for a zero reading on the 2K ohm setting. If it’s ground, then connect the negative lead on the your charger to the white wire, shell, or the frame, and then connect the positive lead on the charger to each colored wire, one at a time, and see if the corresponding light(s) come on. For example, the yellow wire should light up the back-up lights. The green wire should light up the running lights. Skip the blue wire for now.
If those all check out ok, then the umbilical wiring inside your trailer is basically good.
Now for the blue wire. First, make sure it’s NOT connected to the frame with the multi-meter (same test you used for the white wire stub). Next, see if it’s the same wire as one of the two blue wires inside the trailer. You’ll probably need an extension wire to lengthen the lead on the multi-meter. Clip one lead to the right or left wire inside the trailer, and then check for a 0 reading on the 2k ohm setting by connecting the other lead to the outside blue wire stub. I’m betting that one of those wires indise the trailer is connected to this blue wire. The question is: which one? The one that also connects to the light, or the one that isn’t?
The outcome of these tests will determine what we need to do next.
Chris
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
12v Electrical Issues
Clyde-2 |
Batteries, Univolts, Converters & Inverters |
5 |
10-25-2009 08:12 AM |
Univolt or 12v System Gone Wrong
AustinAir |
4 |
04-09-2009 11:10 PM |
63 Overlander 12V system
rvnpikes |
Electrical - Systems, Generators, Batteries & Solar |
2 |
10-09-2008 09:53 AM |
12V Electrical Questions
Airstream 65 |
4 |
06-07-2007 03:24 PM |
12V System....Sudden Death! Help, please
Alan and Mardel |
6 |
12-13-2003 11:04 AM |
