Old 12-22-2010, 10:21 AM   #169
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Originally Posted by lucymcdog View Post
IT WORKED!!!
Blinkers, running lights, turn signals, brake lights, license plate light. YEA!
The formica is down but it isn't my favorite thing to mess with. One boo-boo but it was fixable...
WooHoo!!!! Fantastic job Lindy!
Chris
Old 12-22-2010, 12:12 PM   #170
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
Is this the one?
Progressive Dynamics Inteli-power RV Converter PD9245
New PD9245C Camper 12 volt 9200 series intelli-power
In order for it to be near the fuse box it would have to go under the dinette seat. We could put a grill on the face of the seat - would that work? Sounds easy enough to do since I also have an outlet right there.
lucymcdog is offline   Reply With Quote
Old 12-22-2010, 01:05 PM   #171
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Yes that is the one. It looks like they have increased the shipping cost by $3.20; must be for the holidays. I paid $9.60 for shipping.
The grill idea sounds good, especially if you could locate the Converter so that the air blows out the grill. I'm pretty sure that the fan on the back of the unit will pull air acrossed the unit and blow it away, rather than force air thru the unit; but that's only a guess.
I believe this is the same location that your water pump is located. If so, I would recommend installing a shelf to set the Converter on. Maybe 4" high, incase there is a water leak. Also some kind of diverter to deflect any water away from the Converter if the discharge hose or fittings spring a leak. I would put the shield so it is over the pump and fittings not the Converter.
I just noticed that the one you selected is from a different vendor. I got mine thru a place called RandP Carriages. I'll look to see if I can find the web site address. I was afraid this would time out since I'm editing the message.
TG Twinkie is online now   Reply With Quote
Old 12-22-2010, 01:35 PM   #172
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Lindy; go to www.randcarriages.com Then to Electrical Controls on the left; Scroll down the page, you will find it on the right hand side. shipping is $9.60
I'm not sure what it means when it says 5+ hours. I guess that's the time left to buy the thing.
Old 12-22-2010, 02:14 PM   #173
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Lindy: Here is the same one for $127.00 including shipping.
PROGRESSIVE DYNAMICS INTELI POWER 45 AMP RV CONVERTER - eBay (item 140492394818 end time Dec-29-10 12:10:39 PST)
Old 12-22-2010, 08:48 PM   #174
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
Originally Posted by TG Twinkie View Post
Thanks! I bought it and will let you know if I need any more help when I get it. Sounds like it will be pretty simple to install.
Old 12-28-2010, 01:50 PM   #175
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
Converter question
I got my converter in today and have just a couple of questions. I can't do anything until I can get some #6 or #8 wire so I have plenty of time.
It's pretty straightforward - I put the white #6 or 8 in the negative hole and tighten it down and the black wire in the positive hole.
Do I need to put solder on the wires before I put them in the holes or can I just poke them in and tighten well?
Do you know what the "remote pendant" is for? There is an accessory port on the side and a little remote control looking thing that says "manual overide" on it. The connection is with a telephone wire and squeeze connector. Is this something that should be exposed so that I can get to it easily?
ID:	118139   Click image for larger version
Old 12-28-2010, 02:41 PM   #176
Minno's Avatar
1972 31' Sovereign
Hi Lindy,
New toys are always nice, aren't they?
I don't think you need to solder the ends of the wires before you stick them in the holes and tighten them down. I wouldn't unless the instructions that came with it specifically said to do that, so you may want to double check the installation instructions to see if they recommend soldering the ends or not.
The remote pendant is a remote monitor for the converter. The intention of it is to be mounted in a visible place so you can see what the converter's doing - that is, what mode it's currently in. I honestly don't know why you would ever want to manually change the mode of operation. It change modes automatically based on the charged state of the battery. I think you could mount it anyplace that makes sense to you, even inside the cabinet that will house the converter, since I doubt you'll really check it that much. Personally, if I had a blinking light inside the trailer that was visible all night long while I was trying to sleep, I'd disconnect it...
Chris
Old 12-28-2010, 04:57 PM   #177
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Hi Lindy;
No need to solder the wires. I installed mine just the day before yesterday. I bought #6 battery cables at Wal Mart; they are nice and flexible.. They are the type that have the eyelet on the end. Then it's just a matter of chopping the eyelet off of one end; connect the eyelet on the other end to the distribution block, route the wire where you want it to go; cut it to length (if needed) and connect it to the inverter. Do the same for the ground/common connection. The manufacturer cautions you NOT to over tighten the connections. Also, you need to run a ground wire from the connector on the side of the unit to the skin of the trailer; any #10 wire will work.
Since the old battery is shot and I didn't see the point in buying a new battery 6 months before I need it; I just pulled the 50 amp fuse on the positive side going to the house battery. Now I have DC power in the trailer as long as I have it plugged into shore power.
I couldn't find a white battery cable so I just used black and painted the ends of the negative cable white. It works for me. You could use red and black if you choose to. RED is positive and BLACK is negative.
Did you get the instruction sheets with the converter? If not, I'll be happy to run copies of mine and email them to you. I have the same converter.
I didn't get the remote pendant with my converter and agree with Chris; don't see much value in the thing myself. I plan to wire in a voltmeter sometime in the future.
Old 12-28-2010, 06:12 PM   #178
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
Mine didn't come with instructions but your instructions seem easy enough to follow. It will probably be next week before I can make it over to Wally-World to get the battery cables. That sounds like an easy way to do it. If I have any problems I'll get you to send me the instructions.
I still haven't installed my battery but might try to get that done this week. All I need to do is affix the battery box to the tongue, stick the battery in the box and hook up the wires that are just sitting there waiting to go to work.
Old 01-06-2011, 06:12 PM   #179
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
All done?
After days of single digit cold and a head cold to boot, I was finally able to work on the trailer again today.
I got my battery installed this afternoon and hooked up the converter and, amazingly enough, everything is working as it should. My overhead 12V light works, the converter is charging the battery and the water pump works - as well as its switch and indicator light.
I think I am now through with electrical work? Needless to say, I'm happy that its all done and all works but sad that now I won't get any more lessons from you guys.
Is there something else I need to learn from you? How to test the brakes?
How to install the toilet and black tank? How to build the dinette?
Again, I want to thank you for being such good (and patient) teachers. The lessons I have learned are invaluable and will serve me well on the next airstream that I redo (I'm looking at a 1960 14' Pacer that is SO cute but the guy won't sell - yet).
Old 01-07-2011, 05:37 AM   #180
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I did not solder the wires to my unit, I just tightened them down. The remote pendant will show you which charge state the converter is in and the button will allow you to manually change the current state. I mounted mine on the inside wall of a closet in my bathroom. I think the blinking could be annoying at night if it was mounted where it was in plane site. More information can be found here:
PD92201 Remote Pendant
Richard
Old 01-07-2011, 09:39 AM   #181
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Congratulations Lindy!!!!!
I was more than happy to help. When you get ready to do the brakes and dinette and toilet, let me know.
Old 01-08-2011, 09:14 AM   #182
Minno's Avatar
1972 31' Sovereign
WooHoo Lindy!!!!
Like TG, I was more than happy to help, and will be happy to help on future projects.
Chris
12v
12v Electrical Issues Clyde-2 Batteries, Univolts, Converters & Inverters 5 10-25-2009 08:12 AM
Univolt or 12v System Gone Wrong AustinAir Batteries, Univolts, Converters & Inverters 4 04-09-2009 11:10 PM
63 Overlander 12V system rvnpikes Electrical - Systems, Generators, Batteries & Solar 2 10-09-2008 09:53 AM
12V Electrical Questions Airstream 65 Batteries, Univolts, Converters & Inverters 4 06-07-2007 03:24 PM
12V System....Sudden Death! Help, please Alan and Mardel Electrical - Systems, Generators, Batteries & Solar 6 12-13-2003 11:04 AM
