Old 04-09-2007, 06:33 PM   #1
nilesrob's Avatar
Marietta , Georgia
Images: 12
Electrical advice needed
I just pulled our AS out of storage and hooked up to electrical (we have 50 amp service), and I have an electrical challenge. We have a 2005 34' Classic Limited.
The refrigerator stays on "gas" - does not switch to "electrical". And the microwave does not display - seemingly indicating it is not seeing electrical service. On the refrigerator, I put an electrical tester on the outlet that it plugs in to, and it tests fine (all outlets test fine).
When I checked the electrical panel, there was one or two circuits tripped, so something definitely went awry. Unfortunately, I switched the circuits off and then on before really noting which one(s) had tripped.
The panel breakers are all on, the outlets all test properly, but the refrigerator does not sense electricity and the microwave does not display at all.
Any ideas welcomed!
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 04-09-2007, 07:14 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Brad,
You checked the outlet for the microwave AND the outside one for the fridge, and they both have 120VAC to them? If that is the case (and be sure that you actually measure the voltage with a good RMS voltmeter) then you have other problems that are not related to your AC supply wiring. Both of these appliances require a minimum AC voltage to operate, and a test light will not tell you if that threshold is reached.
If you remove the black cover on the control box at the back of the fridge, you'll see a fuse or two. Be sure that they are in tact by doing a continuity test, not just a visual inspection. Also check your owner's manual on the micro to see if it has an internal fuse or circuit breaker.
If the AC supply is good and the protective devices (fuses) are good, then you have control board issues.
PM me with the results if you need more direction.
Old 04-09-2007, 07:38 PM   #3
nilesrob's Avatar
Marietta , Georgia
Images: 12
Lew,
Thanks - I'll try this out. Unfortunately I can't do it until Thursday - about to go out of town, but I may get back to you after I check this out more fully. Thank you either way!
The Slowsky's
WBCCI #1271
Old 04-10-2007, 08:38 AM   #4
Dan@LED4RV's Avatar
Denton , North Carolina
Un-plug the fridge
If you unplug the refrigerator and it does not trip the breaker then you know it is the fridge. And from there it is most likey the 110 heating element. If this is the case then maybe you can change the element with out taking the unit out. You will need the model number and Ser# to get the right element.
Dan@LED4RV is offline   Reply With Quote
Old 04-10-2007, 08:53 AM   #5
2006 30' Classic
Farmington , New Mexico
Images: 14
Turn all the breakers off again--not just tripping them but push them PAST off then back on . I think you'll find them ok then. ---pieman
Mike Lewis is offline   Reply With Quote
Old 04-10-2007, 09:56 AM   #6
1975 24' Argosy 24
Burlington , Ontario
Try the AC outlet with a 100 watt light Bulb. That should tell you if the AC supply is giving current. Never measure your electricity with a digital meter . The are too sensitive A Radio crap meter should tell you.
Rae
raebaker06 is offline   Reply With Quote
Old 04-10-2007, 07:31 PM   #7
lewster's Avatar
Rae
Rae,
Could you please explain the logic of your quote above. Respectfully, I take complete exception to your statement!! Where did you get this information and what are your qualifications and training in electricity and it's measurements?
A large part of my RV Certification exams dealt with AC, DC and their proper and precise measurements, which are critical to correct diagnosis of electrical problems.
Are you telling me that my $400 Fluke 87V digital RMS multimeter is not to be trusted with the information that it is giving me? It is perhaps the finest, most reliable and accurate meter of it's type available! I'm afraid that your '100 watt light bulb' just won't match up!!!!!!!!!!!!!!
The point of my post was not to see if there IS current, but to determine PRECISELY HOW MUCH voltage is present, as a low voltage supply situation can be an indicator of other problems in the trailer. Your light bulb just can't tell me that!!
Please clarify...........................
I'll be glad to explain the process of RMS and why it is so precise when measuring AC voltage if you like.
Old 04-10-2007, 08:11 PM   #8
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are measuering voltage at the freg. and microwave outlet but neither work but a simple lamp will light when plugged into those outlets I would suspect you may have been hit by lightning and blown the controls or fuses of both.
Most microwaves have a fuse accessable once the case is removed. Also as mentioned above check the fuses in the freg control panel. Remove one end of the fuse, in the freg., from the holder to test to insure there is no secondary path
The controls for the freg operate off the 12 volt system. The 120 volts are only used for the heating element in the chimney.
If the fuses check out OK the last test would be power each by an extention cord plugged into a circuit outside the trailer.
2004 Excursion 4x4
Old 04-10-2007, 08:38 PM   #9
2005 22' Interstate
Afton , Virginia
Lew, old buddy, most of the analog multimeters I've had experience with have been RMS meters. I think what was meant was that the digital meter gives a bit too precise a reading for this application. I've got a 77A Fluke, and don't like to use it for T/S because I don't need to know that the line voltage is 122.23 volts. If it is 120 volts as read on my Triplett 630, that's just fine. I do agree that using a light bulb isn't a good idea, it's hard to estimate the applied voltage from looking at the brilliance of the filament.
But for a gross check, light or no light tells you if the circuit is energised. But, that's all.
regards
herrgirdner is offline   Reply With Quote
Old 04-10-2007, 09:17 PM   #10
Tinsel Loaf's Avatar
Just because you have the best meter in the world it only displays what it detects not what the voltage will do or the element in the refrigerator will do. Sometimes you may have 120 volts but the device wil not work under a load.
Tinsel Loaf is offline   Reply With Quote
Old 04-11-2007, 12:00 AM   #11
2005 22' Interstate
Afton , Virginia
RGR
I admit it!
The 100 watt light bulb will show if the power outlet will support it. A meter by itself will not do that. How about if we plug the light into one of the duplex outlets and use the meter to read the voltage at the other? If the light is dim, the voltage will be lower than the nominal 120/115 volts. If this is the case, unplugging the light bulb ought to increase the voltage reading, and it indicates wiring/breaker issues.
regards
Old 04-11-2007, 12:18 AM   #12
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Might be a long shot but you could check for a tripped GFI outlet. They feed other outlets down stream and can cause an outage.
-Tim
theVAP - Airstream Podcast
Old 04-11-2007, 06:11 AM   #13
nilesrob's Avatar
Marietta , Georgia
Images: 12
I was thinking maybe lightning - I'll check out some of these ideas when I return home Thursday. All good ideas - thank you!
The Slowsky's
WBCCI #1271
Old 04-11-2007, 07:03 AM   #14
lewster's Avatar
If you read post #2, I state that there is a voltage threshold for many appliances. This is a specific voltage and a light bulb will not will not provide you with that information.
Sure, a light bulb will tell you if a circuit is energized, but we're looking for a root cause for appliance non-operation here, and specific line voltage may be a contributing factor. It's just one more tool to troubleshoot a problem that may have multiple causes.
Advice needed, and perhaps a tip or two. Curtis-79MH Airstream Motorhome Forums 12 06-26-2007 01:43 PM
Computer / Accessories Purchase Advice Needed hex Forum Admin, News and Member Account Info 16 11-20-2003 11:54 PM
30 Footer Advice Needed JaceBeck Our Community 13 10-04-2002 11:51 AM
Small Clearcoat Repair advice needed JaceBeck Clearcoat, Exterior Paint & Trim 2 08-01-2002 07:01 AM
Advice please - Travels, Flags, Fuel and Caravans NickSowter On The Road... 6 06-27-2002 10:04 AM
