Old 07-20-2014, 04:15 PM   #1
eld
rocky mount , North Carolina
electrical
possible cause of mild electrical shock when connected to shore power ?
eld is offline   Reply With Quote
Old 07-20-2014, 04:26 PM   #2
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
The electric wizards on the forum will likely ask for more detail about how, where, and how frequently you've been shocked.
Quite possible that you have a grounding problem. Very mild shocks could be as simple as static discharge.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 07-20-2014, 04:27 PM   #3
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
What year/model, converter arrangement, battery set-up? Are you getting the shock from the shell when you touch it?
<-----what TinTin said......
arktos55343 is offline   Reply With Quote
Old 07-20-2014, 04:29 PM   #4
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Watch this.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 07-20-2014, 07:56 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
electrical
The problem sounds like the hot wire and neutral are reversed. Start at the receptacle that powers the coach. If it is OK, then. Go to the shore power cable.
Then check the panel in the coach. The neutral should not be bonded to the ground.
You should also check to make sure the ground conductors are all tight and that there is a wire (bare # 6) going from the ground buss in the coach panel to the skin or frame. The attachment point on the skin/ frame should be clean and tight.
Also make sure the ground circuit goes all the way back to the house power panel.
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
I have made many electrical changes FrankR Electrical - Systems, Generators, Batteries & Solar 4 10-03-2008 08:53 AM
Electrical changes 120 volt ac FrankR Electrical - Systems, Generators, Batteries & Solar 5 03-13-2005 06:20 PM
New electrical in position FrankR Electrical - Systems, Generators, Batteries & Solar 5 05-18-2002 11:47 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 07:39 PM
